Old Jun 10, 2012, 09:24 PM
TBone08 is offline
Find More Posts by TBone08
AirSurfer
TBone08's Avatar
United States, VA, Arlington
Joined Sep 2011
I saw that Vess sales 50cc Balancing Rings
http://www.vesspropellers.com/servle...ce-Ring/Detail
do you guys use them, is it needed ?
should I be expecting to drill or modify the prop or it should fit as it is ?
TBone08 is offline Find More Posts by TBone08
Old Jun 10, 2012, 10:49 PM
thedeuce is offline
Find More Posts by thedeuce
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
TBone08,
I personally wouldn't bother with the balancing rings. All my vess props have been great for balancing with minimal sanding. With all larger props you have to drill the holes for the mounting bolts. I bought a adapter for a few dollars that keeps the holes where they should be when drilling.
Cheers
thedeuce is offline Find More Posts by thedeuce
Old Jun 10, 2012, 10:55 PM
BladeScraper is offline
Find More Posts by BladeScraper
Custom User Title
Joined Jun 2011
agreed.
BladeScraper is offline Find More Posts by BladeScraper
Old Jun 10, 2012, 11:02 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
could you please send me a link, so I'll know exactly what to get ?
Old Jun 11, 2012, 06:49 PM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Here is one example from Hobbyking, great price. My friend bought this one where as I think I got mine from Troybuilt models. There was no difference in quality. Other than the HK one will work with a larger range of motors.
http://www.hobbyking.com/hobbyking/s...C51_DLE30.html
Old Jun 11, 2012, 07:11 PM
barracudahockey is online now
Find More Posts by barracudahockey
Multi-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Falcon 23x9 carbon is a great prop for the DLE, and i've tried a lot of props.
barracudahockey is online now Find More Posts by barracudahockey
Old Jun 11, 2012, 07:12 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
thanks !! and that's a must otherwise it won't fit the DLE55, right ?
Old Jun 12, 2012, 12:30 AM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
TBone08,
The adapter I added a link to just helps you make sure that the holes you drill in the prop for the mounting bolts are in the correct spot, all the time every time you drill. I know it can be done with measuring and a drill press but its way to much work.
Old Jun 12, 2012, 10:18 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
thanks, makes sense
Old Jun 12, 2012, 05:39 PM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Here's my Yak with the Vessprop and DLE 55. Working on making a video mount for it.
Old Jun 12, 2012, 07:29 PM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
I do look forward to seeing that !! that would shad some light on the subject, giant scale fitting.
Old Jun 12, 2012, 10:38 PM
Custom User Title
Joined Jun 2011
Great looking plane!
Old Jun 13, 2012, 12:49 AM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
Thanks for the comments. Once i get it figured out I'll post a pic.
Old Jun 13, 2012, 10:19 AM
TBone08 is offline
AirSurfer
TBone08's Avatar
Joined Sep 2011
I noticed on my current prop I got this ring with 4 bolts.
how do I go about using a 50cc Vess balance ring with a new prop -
do I still use the ring I currently have in conjunction with the vess balance ring
or just the vess balance ring without this one ?
Old Jun 13, 2012, 11:57 AM
thedeuce is offline
thedeuce's Avatar
Canada, AB, Okotoks
Joined Apr 2007
You would remove the ring you have and replace it with the balance ring.
Sold Aeroworks Rx Ready 50cc Yak 54 W/ DA 50,& Tuned Pipe, Awsome Power! gllucero Aircraft - Fuel - Airplanes (FS/W) 1 May 20, 2012 10:52 PM
Sold Aeroworks Yak 54 50cc Pipatone Aircraft - Fuel - Airplanes (FS/W) 2 Nov 08, 2011 08:13 AM
Sold Quique 50cc Yak 54 86" ARF, Brio scheme wfield0455 Aircraft - Fuel - Airplanes (FS/W) 3 Sep 14, 2011 07:18 AM
Discussion vendo yak 54 hangar 9 50cc. yak 54 quique aircraft 101" Ravelero Mexico 2 Jan 04, 2011 08:14 PM
Wanted 50cc H9 Carden Yak or 50cc AW Extra KenCz Aircraft - Fuel - Airplanes (FS/W) 2 Nov 19, 2010 11:11 PM
