Old Jun 09, 2012, 12:18 AM
vineet_p is offline
Find More Posts by vineet_p
vineet_p's Avatar
India, Telangana, Hyderabad
Joined Aug 2011
Question
Carbon-fibre Vs. Aluminium for quadcopter frame
I've made my first quad using Aluminium beams and a central plate... It was pretty strong but was terribly heavy... The frame+bolts+nuts was around 450g!
So this time, I am thinking about using carbon-fibre square pipes (10mmx10mm) as the beams and will use a fiber-glass central plate.
1. How strong is Carbon fibre to use as arms/beams
2. I've heard cutting carbon-fibre is tricky... is it so? Can it be cut just the way aluminium is cut? And how about drilling?
3. I've read that CF is dangerous to health.. is it enough if I wear masks to cover my face while cutting and drilling it or is additional safety required?
Also, is there any advantage in using CF instead of Aluminium? Is it significantly lighter than aluminium?
Vineet
vineet_p is offline Find More Posts by vineet_p
Old Jun 09, 2012, 03:03 AM
sjak is offline
Find More Posts by sjak
Sweden Linköping
Joined Aug 2009
Hi! I cut and sand carbon in the kitchen-sink filled with water.What I can understand the dust can't get in the air doing so.Maybe I i'm wrong correct me then.
Drilling carbon I use a jar with water and insert a alu pipe or square pipe that have the same measurements as the inside of the carbon pipe or square pipe.Then the carbon pipe doesn't split inside.
sjak is offline Find More Posts by sjak
Old Jun 09, 2012, 04:15 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
Thanks sjak.
Anymore replies??
Old Jun 09, 2012, 04:32 AM
recep is offline
Find More Posts by recep
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
Carbon is lighter than aluminum. But with round carbon tubes mounting clamps add weight actually on my 16 mm boom y6 just mounting clamps add 120 grams if I build a hexa it will be 240 gr And this is just for the frame not legs and camera mount etc. With square aluminum tube you dont need that clamps you can mount motors directly on the arms and centerplates likewise so for a bigger frame carbon is better and more rigid but for a smaller frame aluminium has its advantages. You can use carbon for the center though.
recep is offline Find More Posts by recep
Old Jun 09, 2012, 04:41 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
Thanks recep.
I'll make a 550mm frame.
I've mounted my motors presently on Aluminium beams DIRECTLY.
I'll be using CF square tubes, not round, so I can mount motors directly, as I did on Aluminium.
Vineet
Old Jun 09, 2012, 04:54 AM
catlord is offline
Find More Posts by catlord
Villebon sur yvette, France
Joined Mar 2010
Hi,
Carbon and aluminium are VERY different materials.
carbon advantages: very light, very stiff
carbon problem: the major problem of the carbon is that it transmit ALL the vibrations. As it's a nonsense to make holes evrywhere in carbon (loosing the stiffness, the vibrations is transmited along the structure with no dampening).
Aluminium advantages: the stiffness of aluminium isn't destroyed by holes you can make along the structure. ALuminium 7075 is having impressive stiffness.
aluminium problem: it's heavier than carbon. In case of shock it will absorb the energy of the impact and will bend. As an aluminium structure is generaly more complicated than standard carbon boom, the replaement part cost generaly more than a simple carbon pipe.
About cutting carbon you can have a look at my youtube channel (catlord21) you will see several videos aout milling carbon fibers.
Cutting carbon is effectivey dangerous for the health. The µparticules of carbon goes inside your lungs and can provoke cancer on long term range.
The carbon particules are VERY thin and will go thru your mask even with higly filltering EPA14.
The solution to this problem I have found is to force the nanoparticules to go thru water where it will be "glued" in.
Another problem with carbon particules: it's conductive. If you cut it near an electronic device, you can have eletricla problems due to shortcuts.
Cutting carbon isn't just a piece of cake if you want to take care of your health.
catlord is offline Find More Posts by catlord
Old Jun 09, 2012, 07:12 AM
zerosight is offline
Find More Posts by zerosight
Deutschland
Joined Nov 2011
the usually pultruded and shinny chinese look-a-like wooven cfk tubes aren't that stiff related to their weight. You need pure wooven with different direction fibre with a high cfk percentage. They are really hard to find - and expensive. Actually I know only one smart construction, that is light, stiff and uses wooven cfk of good quality. Only negative point is, that it issn't available at the moment but expected for the next month.
Alu Square booms with light CFK centerplates and directly mounted motors are the way best bread today.
EDIT: cfk has two backdrafts. One is the chance of cancer if you breath the particles and second is that they can not carried out from your lungs via breathing out. You need class 3 breath protection and special vaccume cleaner that are able to fiter cfk particles. If you work with cfk under water you have no trouble with the paticles in your environment.
zerosight is offline Find More Posts by zerosight
Old Jun 09, 2012, 07:17 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
hmmm... thanks for the replies... i will go with aluminium at a penalty of extra weight..
Thanks.
Vineet
Old Jun 09, 2012, 07:18 AM
catlord is offline
Joined Mar 2010
Use aluminium 7075 or AU4G only
Old Jun 09, 2012, 07:25 AM
Deutschland
Joined Nov 2011
As catlord point it out, there are different types of aluminum available. Here in Germany, I've found two types at my homedepot. one 10x10 type with 1 mm walls and a 7.5x7.5 with 1.5 mm walls and not so stiff aluminum that is compared to the bigger tubes significant less stiff and have almost the same weight.
Old Jun 09, 2012, 08:09 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
I've found 10mmx10mm square pipes of thickness 1mm. It's pretty hard and four 30cm beams weigh 70g..
Old Jun 09, 2012, 09:45 AM
Deutschland
Joined Nov 2011
So you just need a really good Centerplate like those from here: http://ng.uavp.ch/moin/Shop. They are made of Aircraft CFK with a very high percentage of cfk and less resin.
Old Jun 09, 2012, 11:26 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
@zerosight
Thanks for the help, but you gave the wrong link.. it takes me to some "freeTibet"
Old Jun 09, 2012, 02:33 PM
cyberbillp is online now
Find More Posts by cyberbillp
cyberbillp's Avatar
United States, FL, Melbourne
Joined Mar 2012
carbon
Originally Posted by catlord View Post
Hi,
Carbon absorbs more vibration than aluminum. At least in cycling it does. It's one of the major selling points of carbon frames. Can't imagine physics changes that much between cycling and flying.
http://www.livestrong.com/article/86...-carbon-bikes/
cyberbillp is online now Find More Posts by cyberbillp
Old Jun 09, 2012, 03:16 PM
diakatche is offline
Find More Posts by diakatche
Joined Jul 2009
Alll of our frames are made with round aluminum tubes for two reasons... aluminum bends instead of breaking and aluminum round tubes are 2-3 times stronger than square tubes. Carbon may be lighter, but its failure mode is to basically disintegrate.
We've had crashes from 50m with no damage to the tubes which only required re-alignment of the base plate (also aluminum) to be back flying again. If the same frame was all carbon or with square arms it would have required a base plate and at least 3 booms to be replaced.
FWIW, one of our quads and our small Y6 design mount the motors directly on the round arms. The bolts maintain the angles just find for small aircraft loads. Requires precision drilling of the arms but that isn't a problem with the right jigs and a drill press.
For higher loads we use plastic PVC clips to attach the motors. Works quite well.
See my blog for details.
diakatche is offline Find More Posts by diakatche
Discussion Fibre glass Epoxy sheet vs Carbon fibre sheet for multirotor centre plates.. joy4u Multirotor Talk 4 Aug 16, 2012 10:14 PM
Discussion Vortex folding carbon fibre frames - has anyone used one? slidins15 Multirotor Talk 1 May 25, 2012 11:44 PM
Sold ARF Micro Quadrocopter with Carbon Fibre Frame spbalaj Aircraft - Electric - Multirotor (FS/W) 0 Mar 26, 2012 07:42 PM
Discussion carbon fiber frame vs fiber glass frame? ChatXT Multirotor Talk 1 Feb 09, 2012 02:38 AM
Discussion Carbon fibre frame at decent price? Teamsherman Multirotor Talk 1 Jan 24, 2012 07:08 AM
