Thanks chris that video helped a lot
Latest blog entry: The wicked V
Canada, ON, Ottawa
Joined Jun 2009
Glad to hear you are OK. Hope the rest of Taiwan also recovers soon. Your quads are great. Thanks for the videos. I've just put the Crius board on my plywood HK quad. My quad is totally out of balance if the level mode is switched off. It means more work and more parts. BTW, I came across this 250 frame with buildin WMC and LEDs. http://www.goodluckbuy.com/x250-mini...assembled.html That properly would be a better fit for the 2800kV motors came with my 445 plywood frame. Multicopter is more addictive than I thought... ![]() Best. |
United States, NV, Las Vegas
Joined Apr 2011
I guess what I am looking for is...If I want to update to MultiWii 2.01 or anything newer in the future then I will want to turn all of the origional sensors back on //define the same things that are already on and working good. I would hate to choose the wrong item and suffer with poor flying characteristics. I have only had 2 MultiWii boards and there are so many different accelerometers, baro, etc that I get confused with what has what |
Canada, ON, Ottawa
Joined Jun 2009
I also activated AUX2 on D8 so that I can use my idle up switch to turn baro on and off via the pitch CH using flat pitch curves. That is another option. AUX1 is default, no options. I use gryo gain to switch level and compass together. That is all I can do with my 6 CH RX. There ain't too many to choose from. Don't worry. popcorn: |
Richmond, Oh USA
Joined Feb 2001
Terri & everybody,
I picked up one of the CRIUS MultiWii LCD boards to use. I wanted to make changes to the stored settings at the field. Can't find anything on connecting from the MultiWii to the LCD. The TTL connections are different on this board than others.... Any ideas? OK, just found everything here in the PDF: http://www.rcgroups.com/forums/attac...mentid=4807249 Plug the 3 wire connector into the TTL port, start with the black wire on GND, red on VCC, and white on RXI. Check out the Control Stick Configuration Guide to enter the LCD Configuration Mode. Works great! Can make any of the changes I need then save them ![]() Later |
Does anybody have one of these http://www.multiwiicopter.com/produc...35537_zoom.jpg
Joined Jun 2011
Above my budget, I'm afraid. ![]() Chris |
I was thinking about getting one when i get my flying skills better with this 250 I had my first big crash today broke 3 props I lost control and hit a tree I was flying to fast but I an haveing a blast with this quad
Joined Apr 2011
Can you explain a little more? I understand AUX1, switch used to turn level and heading hold on or off. I am tracking with //defining D8 in the sketch and using a differnent switch for baro. But what is pitch CH and flat pitch curve? I have some collective pitch heli, so maybee I am over thinking it.
Are there different flight modes if so how do I change them the reson I ask is because I keep seeing people talk about arco mode
| Thread Tools | |
| Discussion Butterfly X250 Frame Quick Review/Photos | flitelab | Multirotor Talk | 25 | Jun 25, 2012 09:35 AM |
| Discussion Any more concise and beautiful than this mini X250 quadcopter | goodluckbuy | Multirotor Talk | 13 | Jun 16, 2012 09:54 AM |
| Discussion X250 carbon fiber xcopter. | cyberbillp | Multirotor Talk | 0 | May 11, 2012 08:06 AM |
| Sold butterfly-x250 Quad 4 sale new or trade for um plane | crashdumby | Aircraft - Electric - Multirotor (FS/W) | 5 | Apr 11, 2012 02:15 PM |
| Discussion MWC Starfire | MWCores | Flying Wings | 7 | Oct 04, 2009 10:38 AM |
