Joined Jun 2011
On my 450, the agility is less than the MWC, but on my 250, the agility is INSANE. WAY more aggressive than the MWC... Like WAY, WAY more. Too much, in fact. The frame is a 12 inch from QuadAddict I purchased from tc3wins. When I bought the frame, I asked him what I needed to have this quad fly aggressively. He recommended 2822 motors with 8 inch props. So that's what I did. Man.... Oh man... I ask him for a setup recommendation for good performance. He set me up with a monster. As I was worried to lack good cyclic response to flip it, I set the end points to 150%, just like on my MWC... That did not work. I am not kidding, my first flip attempt resulted in a triple flip stationary. Did not even lose altitude. All I heard is a loud V V V V V V V sound and this thing flipped 31/2 times so fast I couldn't see it. Lost orientation and crashed. It's repaired now and I settled for 100% on the end points. It flips about the same as my MWC now but I still have A LOT of room to make it flip MUCH faster. As for the rudder, it's the same. It spins so fast the props colors all blends into one and you can't tell which way is which. I will show a video of that indoor today if I remember. For the rudder, I settled to 120% and it's manageable. That being said, I think the MWC can be programmed to have equal, if not even more aggressive rates. Just haven't tried yet. Quote:
Best, Chris |
United States, WA
Joined Apr 2012
Hey John, not sure about the spacers either. I omitted them. It is a 2mm allen wrench for the screws and 6mm wrench for the standoffs. Wish I could e-mail you flux! I use rosin core solder, don't use flux.
United States, WA
Joined Apr 2012
Wow Chris,I am sorry you are going through that. We had a really bad flood 3 years ago. At least I thought it was bad until I saw your photos. Hope it subsides soon. Take care and you'll be in my prayers, Earl
Joined Jun 2011
Thanks, Earl. Me and mine are resting safe in a dry house. The death toll has risen out there, though. And it's still raining hard....
Wasp, you asked about the difference between the KK board and the MWC. Here's a couple videos for comparison sake. Both flights with identical settings. I throw the small one around a bit more and that's because it is smaller, less powerful and safer indoor. You can see the piro rate doesn't compare, though. Below are also some pictures of both quads to see the size difference and a picture of my DIY cover over the electronics. I used the lid from a Skippy peanut butter jar. ![]() ESC's tucked in under the main board: ![]() Now here's a size comparison: ![]()
Best, Chris |
Richmond, Oh USA
Joined Feb 2001
Hi Chris,
Nice looking quads... ![]() I thought the piro/yaw rate was way too slow on the 250 also. Start MultiWiiConfig, then READ your PID settings. Now change the YAW 'P' to 4 (increases Piro Rate). Change the RC Rate to 1.0 (increases all control throws). Now WRITE them to the quad. Your piro rate will be much better, it helped mine. Later John L. |
Joined Jun 2011
Best, Chris |
Increasing Yaw 'P' affects the P-term of the control loop, not the yaw rate.
You can either increase Yaw rate (last field after YAW P-I-D) and/or RC Rate. See here Quote:
Hey guys, just thought I'd let everyone know that if you've broken or bent a prop on this quad - it can be fixed!
![]() I had one blade completely snap off and another that had a fatigue bend in it. I thought that if I used som CA on the broken prop and coated the bend of the fatigued prop it might be enough to hold it. Turns out it was. I was able to hover and do basic circuits with the patched props but I don't want to push it with 3D. I guess they're small enough that CA can withstand all the forces the blades undergo. |
I have a ? Is there any way to set stick sensitivity I can move my sticks about 1/6 in and it's moving are is that the best way for me to learn. And Btw chris Peter pan is better than skippy
Latest blog entry: Win a frame
Joined Jun 2011
Here's a good video that will give you a clear picture of what expo will do for you. It's for helis/planes, but it has the same effect on quads so this explanation is valid. If you watch his other videos, he will run you though other useful TX settings. This specific video covers expo.
Not sure about Peter Pan, mate. Plus, the real skippy is a very cool Kangaroo. ![]() Best, Chris |
| Thread Tools | |
| Discussion Butterfly X250 Frame Quick Review/Photos | flitelab | Multirotor Talk | 25 | Jun 25, 2012 09:35 AM |
| Discussion Any more concise and beautiful than this mini X250 quadcopter | goodluckbuy | Multirotor Talk | 13 | Jun 16, 2012 09:54 AM |
| Discussion X250 carbon fiber xcopter. | cyberbillp | Multirotor Talk | 0 | May 11, 2012 08:06 AM |
| Sold butterfly-x250 Quad 4 sale new or trade for um plane | crashdumby | Aircraft - Electric - Multirotor (FS/W) | 5 | Apr 11, 2012 02:15 PM |
| Discussion MWC Starfire | MWCores | Flying Wings | 7 | Oct 04, 2009 10:38 AM |
