Old Jun 08, 2012, 04:29 PM
rubenhak is offline
Find More Posts by rubenhak
Joined May 2009
Turnigy Talon Quadcopter V2 Build
Hi Everybody,
This is my first multi rotor build. Just want to share items I purchased and to get a feedback in chase I need to get some extra or use a different parts until the package arrives from HK. Here they are:
With those electronics which of the props would you guys suggest to use on the quad? I'm planning to build it in X configuration. 10x6 or 11x4.7? Also as much as I'm aware the stock controller board comes with "+" configuration firmware, right? Which firmware(and version) would you recommend for me to use?
Also, when resoldering ESC wires would you recommend using 16, 18 or maybe different gauge wires ? The stock wires would definitely not be long enough since I'd prefer to route the wires through the carbon fiber tube of the frame.
Any feedback is appreciated!
Thank you,
Ruben
rubenhak is offline Find More Posts by rubenhak
Old Jun 08, 2012, 04:31 PM
rubenhak is offline
Joined May 2009
Could not find a suitable cover for my quad to protect the controller board. What would you recommend to use and where to buy it from? I'm in US.
Old Jun 08, 2012, 05:22 PM
oesti is offline
Find More Posts by oesti
Joined Jun 2011
Ziploc bowls!
http://www.diapers.com/p/ziploc-cont...all-bowl-51210
oesti is offline Find More Posts by oesti
Old Jun 08, 2012, 05:36 PM
rubenhak is offline
Joined May 2009
what would be the best way to mount it to the frame?
Old Jun 08, 2012, 08:49 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
look at the guage chart here: http://www.powerstream.com/Wire_Size.htm
find amp draw max for motor and then find which wire will work. also, you should know that a wire that is too small will produce heat from the extra current, but the heat lost will wont be as bad as loosing flight time from heavier wire.
sirbow2 is offline Find More Posts by sirbow2
Old Jun 09, 2012, 10:51 PM
rubenhak is offline
Joined May 2009
I've got a 55Amps ESC which is definitely not using 10 gauge wires. Is this table applicable for short wires?
Old Jun 09, 2012, 11:01 PM
sirbow2 is offline
Emress
Joined Nov 2011
you mean 25amp, right :P
yeah, i always found that strange. if you are extending ESC wires, use the wire that the ESC already uses, i guess...
Old Jun 09, 2012, 11:04 PM
rubenhak is offline
Joined May 2009
no, actually I meant 55.
for instance:
*) Turnigy Thrust 55A is using 14AWG
*) Towerpro Mag8 30A is using 16AWG
*) RcTimer 40A is using 16AWG
but if I look to that table, that would recomment using 10AWG, 12AWG and 14AWG wires instead.
rubenhak is offline
Joined May 2009
Regarding the props, which ones would you recommend to use?
Old Jun 09, 2012, 11:09 PM
sirbow2 is offline
Emress
Joined Nov 2011
10x6 on 3s
9x5 on 4s battery
Old Jun 09, 2012, 11:18 PM
rubenhak is offline
Joined May 2009
how do you know, do you have access to some manual? Cant see any information on the web site...
Old Jun 09, 2012, 11:59 PM
sirbow2 is offline
Emress
Joined Nov 2011
amp draw data from the reviews and discussion on the HK page for the motor
Old Jun 10, 2012, 12:02 AM
rubenhak is offline
Joined May 2009
by any chance do you know how much of thrust would this motor with 10x6 prop provide?
Old Jun 10, 2012, 12:11 AM
sirbow2 is offline
Emress
Joined Nov 2011
oohhh NVM i actually found some real test data http://www.flybrushless.com/motor/view/590
10x6 on 4s(this would be best option) with most power/flight time.
1x7/12x6/12x8 on 3s-- less thrust for same or more amps as 4S
Old Jun 20, 2012, 03:05 AM
rubenhak is offline
Joined May 2009
Need Help!
Today received the parts from hk. Put everything tougher and flashed the board with XCopter 4.7 firmware. There is just one problem.
When trying to lift the copter from the ground its front left (number 1) motor does not raise from the ground, though the rest of the motors are already in the air. If I push the throttle more it feels like the copter would flip. It is also noticeable that first motor is spinning slower than other once. Spinning directions are correct and I'm using counter rotating props.
Please help to fix this problem. I've calibrated quad throttle range and also reversed incorrect gyro with transmitter. All motors and ESCs are identical.
Thank you, Ruben.
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Build Log Turnigy Talon Quad Build Question penz83 Multirotor Talk 21 Feb 14, 2013 11:16 AM
Sold Talon V2 Carbon Fiber Quadcopter Frame STILL AVAILABLE! Depron Dave Aircraft - Electric - Multirotor (FS/W) 7 May 22, 2012 05:37 AM
Discussion Turnigy Talon V2, weight help plz .Joel Multirotor Talk 2 May 12, 2012 08:50 AM
Help! What prop for Turnigy SK3 3530 with Talon V2? MitchellY Multirotor Talk 2 Apr 28, 2012 01:00 PM
