Time to drag out the sheets of depron make yourself a knock-yourself-dead design. Wokiging on a KfM-3 Depron version of the RCM Shrike Commander design.
http://www.rcgroups.com/forums/showt...0#post23609718 |
Thanks scirocco,
Yes, I am getting closer. I will replace the wheels before the maiden since they are woobley and turn poorly. Also I need do some patching on the monocoat covering. I feel that a lower pitch is better on the Lt-40 since it is designed for slower flight for beginners. I have tried to find where I read it but the way I understand this is that the pitch is like gearing on a bicycle or car. In high gear it is hard to get going vs low gear and this massive wing wants to cause "ballooning" if coming in too fast for a landing. Can't forget to mention the drag the wing creates at higher speed. This baby is a floater and gentle flyer so I feel slower is better and have the power to spare. If I wanted, I could easily fit a 14 x 7 inch prop on it with the way I built the new motor mount since I have 8.5 inches from the centerline of the motor to the ground. If and when I get my donated (free ) Sig King Kobra going I fully agree with the higher pitch prop that you are recommending.I did some playing around on the battery hatch and for people who do not know, there are some very strong magnets in hard drives. To remove them you need to bend the metal backing to remove them. The magnets are quite brittle and will break if you try to pry them off. |
| Thread Tools | |
| Help! Sig kadet senior aileron/flap servo mounting | memiry | The Builders Workshop | 1 | Nov 23, 2011 12:25 PM |
| Discussion Sig Kadet Senior dressed like a Cub | WMitchell52 | Fuel Plane Talk | 16 | Nov 09, 2011 10:01 AM |
| Help! Need Stabilizer Section of Sig Kadet Senior Plan | rikirinaldo | The Builders Workshop | 9 | Oct 30, 2011 11:27 AM |
| Discussion Converting a Sig Senior Kadet | N2RYD | Beginner Training Area (Aircraft-Electric) | 3 | Oct 10, 2011 04:48 PM |
| Discussion Sig Kadet Senior | Eclipse_7 | Crash Discussion | 0 | Oct 10, 2011 03:04 PM |
