Ajax, Ontario, Canada
>a third for the shirt.....
At least the flourescent lime-green socks are not visible .... as an aside the airplane was built to 'Creep' outlines but with geodetics, profile fuselage, Webra Mach 1. Lighter and better - just wish was Nostalgia-legal in this form. Model on ground one of the early Applehoney 430's, either Oliver or Enya 15D powered. Now back to the Colonel's Ajax as normal service is resumed |
Well, as it was Father's Day - young Pippa Blinkette went out
. Having helped Lady Blink in the garden (she seems to be trying to grow grape vines for wine - I hope they are more successful than the unfortunate episode when she tried to distil her homegrown sloes into gin - her eyebrows have only just grown back), I managed to get in the loft for a short session.The results of said session were a sanded fin with the rudder seperated; only needs covering, hinging and a control horn added. Attacked the centre section next - I decided to notch the ribs into the TE, and so I had left the ribs slightly over length. I wasn't happy with the original butt joint of the end of a 1/16" rib to the edge of a piece of 1/16"x1/4"!!! Added my extra 3/32"sq spars as well. Not 110% happy, but I'll see what it's like when I get it off the board and with some gussets added. ![]() ![]()
Really impressed with the progress Colonel - for a man who had to be coerced back to the building board you seem to be taking to it rather well! I reckon your centre section will be OK with a few well placed gussets (cut with the grain parallel to the hypotenuse in the approved manner of course!)
Re Jim's dayglo lime green socks; he wasn't joking you know, we were all snappy dressers on the F/F scene back then!! My own personal affectation was cravats in nice shades of green and pink with flowered patterns! |
Suffice it to say that when once arriving to a Northern Area dinner venue I momentarily failed to recognise the suave nattily-suited gentleman standing by the door until he started to nibble dried balsa cement from his fingertips. 'twas George .....
No, it has all been perfectly top hole - though I know that I can be a little prone to giving up when something goes wrong! The other concern is always whether something domestic will crop up, meaning that attention will need to be directed elsewhere.....which is the main reason that I have been Armchair Modelling for years (see my blog).
Hmmm.... leaving aside Applehoney's reminiscences of Forgotten Fumbles of the Fifties, back to the case in hand....
![]() The centre section is now complete and the LE & TE have been sanded to a shape approximating to the aerofoil. Gussets (I have always found that word a little unsavoury!) added - with the appropriate grain direction, George! ![]() I have added some 1/64" ply braces in addition to Mr Hatfull's 3/32" balsa ones (the Amerang version only has 1/16" balsa braces) - possibly overkill with hindsight, given that if a wing is going to fold it is more likely to happen at the LE to rib joint rather than where two ribs are sandwiched with adhesive.Started work on the outer panels next - tip pieces glued together and left overlong for furtling to fit at an angle between the TE and the raised LE when the time comes; they will not be affixed to either until the rest of the wing structure is completed. Hope to get a little more done this evening whilst Lady Blink is at work and young Pippa Blinkette is at drama class - not that she needs it.......! ![]()
Well, construction has continued in half-hour portions in the West Belfry at Blink Towers.
Firstly, the wingtip issue seems to have been solved and by furtling it and adding it after the rest of the structure is almost complete has enabled it to look reasonable. Second outer panel framework is also completed but needs finish sanding including shaping of LE & TE. Then comes the joining of the wing panels, which I am facing with trepidation, as I very much doubt that both outer panels will fit at the same angle and neither will have the required 2 3/4" dihedral. I have been test fitting the first and it was miles out....... ![]() ![]() Now a question for you highly experienced chaps - when I tape the plan down to begin building, I have it luvverly and flat. Within a day or two (I'm not a quick builder), it is loose and ripply and any structure that is being built upon it needs weighting to keep it flat to the board. This is likely to be caused in part by temperature and humidity variations, but how do you chaps deal with it? Is it because I am stretching the plan too far to start with? ![]() ![]() Started on the tailplane this afternoon - laid out and glued the outline and spar and left to drive. Sitting downstairs an hour later, suddenly realised that I had started building it to plan - ie freeflight rather than with an elevator......Quack, quack, oops.... . Luckily it's adaptable!
United Kingdom, England, Lancs
Joined Sep 2006
Paper will change size quite dramatically due to humidity changes. I must say though it has never been a great problem for me, probably because most of my models are built over outlines drawn up on tracing film. On the occasions when I have used a paper plan I usually cut it up for convenience and hence each bit is built as soon as that part of the plan has been pinned down.
| Thread Tools | |
| Build Log KK Gipsy for Britkit build off | kkphantom | Vintage & Old-Timer Designs | 150 | Mar 30, 2013 08:37 AM |
| Discussion "Britkit" Build Off April 2012 - 31/12/2012 | Sundancer | Vintage & Old-Timer Designs | 303 | Jan 01, 2013 03:47 PM |
| Build Log Britkit build off (Senator) | Raf_Bob | Vintage & Old-Timer Designs | 128 | Dec 11, 2012 02:35 PM |
| Build Log Britkit Build Off May 2012-31/12/2012 - Keil Kraft Sportster x1.8 | Sundancer | Vintage & Old-Timer Designs | 64 | Jun 27, 2012 02:16 PM |
| Build Log "BritKit" Build Off 2012 - Veron Phoenix | RFJ | Vintage & Old-Timer Designs | 37 | Jun 08, 2012 05:28 AM |
