This thread is privately moderated by michaelghammer, who may elect to delete unwanted replies.
Old Jun 08, 2012, 02:36 AM
michaelghammer is offline
Find More Posts by michaelghammer
michaelghammer's Avatar
Denmark
Joined Dec 2004
The 5 th. manual axis and box
Hi All
The nature of the CNC Foam Cutter design dictates a raised work area. So I made a plywood box with the help of my CNC Router. The box contains the stepper driver board (cheap TB6560 type from Ebay), stepper motors powersupply (second hand from old thermo label printer) and hot wire power supply (home made). All wires exit two rather large holes and can be tucked back in when not in use. Holes also act as carrying handles.
When cutting foam fuselages you most likely need sections of different length. So you end up cutting foam blocks to the correct length, rotating, aligning and then cutting shape. A lot of time is "wasted" rotating and aligning. Not a big deal if your fuselage consists of 4 segments, but if you´re making a complex scale fuse you might have 20 segments or more...
So I made a removable 90 degree rotating top for the box. Built in plastic rollers (plastic beads from my daughters stash) reduce the friction of the top. A grid pattern of holes and matching pins help align the foam block. Works like a charm
- Michael Hammer
michaelghammer is offline Find More Posts by michaelghammer
Found Ikon N'wst Assembly manual for Stinson Reliant 1/5 th scale GLGofLB Aircraft - Fuel - Airplanes (FS/W) 5 Jul 27, 2012 07:35 AM
Fly-In Texoma RC Electric Extravaganza. May 5 th jed1d Electric Flight Events 20 May 06, 2012 10:06 AM
Sold Lightly Used Spektrum DX5e w/ OG Box and Manual NothinButThumbs Aircraft - General - Radio Equipment (FS/W) 4 Apr 01, 2012 03:16 PM
Discussion KK MultiWii Multicopter Controller Board V5.5 for Y3 3-axis 4-axis Y6 6-axis single-a disneytoy Multirotor Talk 2 Feb 10, 2012 12:21 AM
For Sale MP JET AC25/25/26 mk2,5:1 gear box trade for axi 2212/20 with radial mount heliguy Aircraft - Electric - Airplanes (FS/W) 5 Oct 07, 2005 11:26 AM
