Old Dec 12, 2012, 11:32 AM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
I run 12awg on all of my setups. I know that my 33% Extra 260 with 7 JR8711 servos pulls about 230ma sitting idle and peaks of over 60A when doing a snap to snap maneuver. People don't realize that servos draw 2-5 times their stall current during a direction change... albeit for a brief period of time, it still happens and can cause a lockout of systems that can't handle low voltage situations.
JimDrew is online now Find More Posts by JimDrew
Old Dec 12, 2012, 01:46 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Originally Posted by JimDrew View Post
You won't need a regulator as this has one built in (500mA), and the Nano needs about 20mA max. You could use 2.5v to 25v for the input, but that voltage gets passed to the servos. I think pads are the way to go. I will just fill them full of vias (through holes) to prevent copper delamination. I will also use 2oz double pour (top/bottom) for power and ground to the servo pins.
Now, the question is, how many outputs per channel. I guess with the Nano, since you can do all of the servo reversing/matching in it I would only need a single output for each channel. Thoughts?
Wasn't too worried about the Nano as it can take 16v as it is... more that people will solder switches and regulators to power the servos, cuz that's simply what they do.
If there were 16 outputs total, and could configure each pin to be the channel you want... that would allow 16 separate channels, or grouped channels as needed. needing more than 16 outputs to me seems like a pretty cool excuse to get a second expander. I have yet to see a full smartfly pro.
Servo matching in the Nano isn't capable enough for the giant aerobatic crowd... need to match end points and have some way to make settings changes with the servos powered and driving. Hitec's kinda-sorta give-the-servo-a-little-power is enough, but matchboxes are nicer to program as the servos have full power and driving as if they were flying; easier to use the ammeters, etc.
For the big expander, my thoughts would be that whatever makes it most useful for non-XPS receivers will help spread the XPS love overall. Reading S-bus or the Spek satellite, get the rx part up and out of the way, super setup for servo power and output value-adds... is wunderbar. Smartfly are bringing out a box that the 14 channel Futaba Rx simply plugs into that connects all the pins on the receiver, and is just a power expander. It's going to be expensive. But the xps expander would allow their full range 6/8 channel s-bus receivers to be up wherever, snorkel style like the Nano, and still get all the channel outputs and power expanding... this will save $100 for the Futaba dudes on the price of just the receiver let alone the expander.
...being able to snorkel the receiver is pretty sexy, but sales to the non-XPS crowd will be mostly about a sexy matching solution. Even just using an app on the PC to inc/dec values for any channel while the servos are driving would be a huge win.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Dec 12, 2012, 02:59 PM
E_ferret is offline
Find More Posts by E_ferret
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
Originally Posted by theKM View Post
...being able to snorkel the receiver is pretty sexy, .
I don't quite understand the advantages of using a miniature diesel to power the receiver.
E_ferret is offline Find More Posts by E_ferret
Old Dec 12, 2012, 04:21 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
snorkel is a much more amusing word than "remote" or whatever... the system needing a snorkel in order to breathe clean less-RF-noise air
Old Dec 13, 2012, 01:59 PM
E_ferret is offline
E_ferret's Avatar
Joined Jan 2004
I understand your train of thought; snorkel, diesel, submarine, torpedo, explosion,
ship, sinking, into the deep, bathycaph, James Cameron, remotes, Jim Drew,
XPS, 2.4GHz, receivers, Nano, single antenna, RF, noise, rejection, wife, ... but I digress.
Old Dec 21, 2012, 02:04 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
this sounds like a pretty cool idea, would definitely like to see pics when the time comes and see how a setup procedure would go
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 21, 2012, 04:25 PM
Lake Havasu, AZ
Joined Jun 2005
There is a picture of the original design on the 2nd page of this thread.
Old Dec 21, 2012, 04:44 PM
JuanRodriguez is offline
Find More Posts by JuanRodriguez
The Villages, Florida
Joined May 2003
Really ?? Do you expect people to actually read these threads ?? That would be a novel idea !!!
JuanRodriguez is offline Find More Posts by JuanRodriguez
Old Dec 21, 2012, 09:45 PM
flyingfever is offline
Find More Posts by flyingfever
Joined Jul 2009
RF filter use?
The great thing about 2.4GHz is that it is immune from virtually any type of noise, such as from ignitions, metal to metal contact, etc. The servos, however, are not. So, an opto-isolation circuit will offer no benefit.
Hi Jim, Does this mean that the RF Filters, such as the ring style JR PA029 that the esc wire wraps around several times at the rx end are not needed with 2.4 systems? If so, I've wasted a lot of money. Thanks, Bob.
flyingfever is offline Find More Posts by flyingfever
Old Dec 21, 2012, 11:10 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
not really wasted because the servos are not immune to that noise... receiver is fine, but that doesn't matter if the noise is making other components go crazy.
The problem with the other bands like 72mhz was that some of the noise was being picked up by the receivers and was turned into servo output commands... at least with 2.4 it means that the junk isn't turning into an actual servo command, but servos still have to deal with the junk on its own merits.
Old Dec 22, 2012, 11:00 AM
Lake Havasu, AZ
Joined Jun 2005
Correct... the servos still can be affected by the noise, although good digital servos should not be - analog servos definitely will be.
Old Dec 22, 2012, 12:28 PM
Joined Jul 2009
filters
Thanks guys, I'll keep using them. Not much weight gain, and maybe a little insurance.
Old Dec 27, 2012, 10:16 AM
Lake Havasu, AZ
Joined Jun 2005
Just an update... I finished the design for the new separated RF section. I am not sure what to call this yet. The unit can be bound using either a command from the servo port side (not sure what to call that yet either) or via the push button. This way you can bury the RF portion in the fuse and you don't need access to the button to bind it later. The RF portion can output a XPS, Spetrum, Futaba S-Bus, or PPM data stream. The servo portion will retain the failsafe, channel mapping, reversing, etc. information. This allows you to simply remove the RF portion and put it in a different airplane without having to change all of the settings again. The RF portion is what sends the telemetry data, but the servo portion will be the interface to the telemetry devices.
Old Dec 27, 2012, 12:36 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
that sounds cool. so are you saying the servo extension that would connect this channel expander can be used for binding as well?
Would you even need to bind it if plugging into a nano rx?
and i am assuming you are not far enough along to know this, but how long of an extension can you you use?
Old Dec 27, 2012, 01:16 PM
S_YORAM1@BEZEQIN is offline
Find More Posts by S_YORAM1@BEZEQIN
Israel, Jerusalem
Joined May 2007
How robust is the RF link regarding number of antennas and diversity? And what is the maximum distance between the antenna and the RF section?
S_YORAM1@BEZEQIN is offline Find More Posts by S_YORAM1@BEZEQIN
Sold JR Channel Expander Clavin01 Aircraft - General - Radio Equipment (FS/W) 1 Apr 13, 2012 06:48 AM
Looking to expand my operation... CyberJay Coaxial Helicopters 14 May 17, 2005 05:50 PM
PFM is looking to expand into the larger scale aircraft. WJ Birmingham Sport Planes 12 Jan 02, 2004 09:31 PM
Expand battery bay in flying wing? navyflier Foamies (Kits) 7 Apr 08, 2003 10:27 AM
