Lake Havasu, AZ
Joined Jun 2005
During the first year of business, we "lost" about 50% of the packages going to Europe. Now, I am sure that some were really lost - but nowhere near what we were seeing. So, we adopted the policy that everything had to be tracked. It's the same policy we have in the U.S.
The Villages, Florida
Joined May 2003
In short, I think that what you pictured previous would be great, it's small size means it could fit into smaller places... but then again I can also imagine something like this also being cool... ![]() but, of the feature list... - will need somewhere handy to solder some serious wires for plugging in some more serious wires. the giant scale dudes will appreciate larger soldering taps than needed just cuz size matters to them... - the mounting holes, smaller holes would be fine, but having the area around them be open enough to allow drilling out to add grommets... or simply have grommets for the gas engine crowd - auto-matching of servos will sell these things faster than you can imagine for the giant scale pin count... 10 channels would get the 80 of the 80/20... 16 takes care of everyone. if it's easy to have two of these working off the same Nano, could probably even bump it down to 8 or 9 channels... at the price point mentioned previously, none of these scenarios seem like much of a problem. 8-10 pins, two mounted side by side, the ability to output from Futaba's s-bus signal or Spek satellites, the only scenario I can think of is that this is going to be crazy popular. |
could even have two plugs up the signal end that could jump the signal over to a second expander....
...the power taps closest to each other could also be soldered to the other expander, so one pack plugs into one expander, one pack into the other... still has connection if one pack goes belly up. |
United States, AZ, Queen Creek
Joined Aug 2004
If you are going to have autotrim, I think the way it should work is; you press a button and the trim is adjusted to the value indicated by the stick position when the sticks are returned to their relaxed position. Its been a long time since I have programmed in assembly, but it seems to me that could be done. It just depends on the capability of the instruction set of the chip you are working with.
I understand the Ace autotrim does not work that way. |
Lake Havasu, AZ
Joined Jun 2005
Dirtybird, wrong thread! But, that is how my autotrim works.
theKM, I know the auto-match feature is something that you want and it has to be done in a form factor the size you are showing (big by comparison to a normal size receiver). The power wires (1 foot long) will come already soldered. I was planning on having 12awg wires. Maybe I should just make 1/2" x 1/2" tabs that can be soldered easily instead? I want a smaller type expander that resembles a receiver as well. Perhaps a few different options, but I want something quickly. The new Nanos will be coded so that they already have the new expander output. I added it to option for selecting either PWM or PPM outputs for the pins. Now you can have PWM, PPM, or XPS. XPS = super fast entire 16 channel packets. We get as many groups of 16 channels as we like with how the system is encoded, this is why making a transmitter with 32 or more channels is pretty easy - you just add another packet. |
all sounds great.
12awg doesn't seem excessive... but my guess would be that easily solder taps wouldn't pose a problem for people. There would be no other matching/related product that amount of wire for the 12awg though. Wolverine switches have two deans plugs with 16awg wire on them (if one selects the Deans option), and a depressing amount of switches (Booma RC, etc) with heavy servo wire of 20/22awg. I know you hate switches and regulators, but people will be using them. Taps may be the low bar for a good easier-nicer-cheaper ratio. I like the shunt style plug switches, currently wiring them up with 14awg... ...with the nekkid/rx-sized expander, that will take care of smaller planes that will be happy with the 20awg wires coming out of BECPro's and such. |
Lake Havasu, AZ
Joined Jun 2005
You won't need a regulator as this has one built in (500mA), and the Nano needs about 20mA max. You could use 2.5v to 25v for the input, but that voltage gets passed to the servos. I think pads are the way to go. I will just fill them full of vias (through holes) to prevent copper delamination. I will also use 2oz double pour (top/bottom) for power and ground to the servo pins.
Now, the question is, how many outputs per channel. I guess with the Nano, since you can do all of the servo reversing/matching in it I would only need a single output for each channel. Thoughts? |
| Thread Tools | |
| Sold JR Channel Expander | Clavin01 | Aircraft - General - Radio Equipment (FS/W) | 1 | Apr 13, 2012 06:48 AM |
| Looking to expand my operation... | CyberJay | Coaxial Helicopters | 14 | May 17, 2005 05:50 PM |
| PFM is looking to expand into the larger scale aircraft. | WJ Birmingham | Sport Planes | 12 | Jan 02, 2004 09:31 PM |
| Expand battery bay in flying wing? | navyflier | Foamies (Kits) | 7 | Apr 08, 2003 10:27 AM |
