Old Feb 16, 2013, 01:25 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Well, the flashing issue with the A9 is definitely our fault. That should not have been possible. I will look at that tomorrow when I get into the office. That really bugs me.
JimDrew is offline Find More Posts by JimDrew
Old Feb 16, 2013, 10:03 AM
tholmes345 is offline
Find More Posts by tholmes345
Fly inverted, it's more fun.
tholmes345's Avatar
United States, SC, Greenville
Joined Apr 2006
I can only imagine.
tholmes345 is offline Find More Posts by tholmes345
Old Mar 03, 2013, 10:13 AM
tholmes345's Avatar
Joined Apr 2006
The end of this saga is that I have modules for both my Tx's. One new and one reprogrammed. Both show the telemetry as they are supposed to. Thanks Jim and crew. What I need now is the Rx's that are not flashable upgraded. Sending them to XPS soon.
Old Mar 03, 2013, 12:10 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Good to hear that everything is working properly!
Old Mar 03, 2013, 03:56 PM
xfedex is offline
Find More Posts by xfedex
Joined Sep 2011
Throttle cut off
Jim, there has been a lot of water under the bridge and my memory is not what it used to be but will the new transmitter going to have a throttle cut switch? My A9 has throttle cut and it comes in handy when flying electrics and not having to worry about getting your fingers in the prop.
xfedex is offline Find More Posts by xfedex
Old Mar 03, 2013, 10:03 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Any switch can be assigned as a channel lockout. This means that you could have every single channel affected by a single switch or multiple switches affecting multiple channels (or no channels affected). I do this already with my retract switch... so when the throttle hold is enabled, the retract enable also uses the same switch. It's not possible for the retracts to work with the throttle control disabled. This prevents those 'accidents'.
Old Mar 05, 2013, 01:43 AM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
In the case of the A9, it would be nice for that feature to stay in the touch display, rather than have a switch assigned, to prevent confusion. I can see myself flipping the wrong switch. With the icon and tones, it is clear throttle lock is engaged. I agree that this is a key feature of the A9.
TTRotary is offline Find More Posts by TTRotary
Old Mar 05, 2013, 01:56 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Virtual switches are possible with the touch display.
Old Mar 09, 2013, 12:44 PM
Grich is offline
Find More Posts by Grich
Grich's Avatar
Joined May 2002
Jim, on the DivBee modules what are the operating voltages?
do u have an idea of the price range?
Is one of the antennas a receiver and the other the xmitter?
Grich is offline Find More Posts by Grich
Old Mar 10, 2013, 06:28 PM
xfedex is offline
Joined Sep 2011
Jim, does this mean that you will seen an indication on screen that the throttle lock is on? On my A9 throttle lock shows up on screen......
Old Mar 11, 2013, 11:30 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
DivBee spec is 2.5v - 3.6v, but it operates down below 1.6v just fine (with reduced power output) - no harmonics. Remember, the DivBee module is just an 802.15.4 (Zigbee) compatble RF module and so it is not the XtremeLink system itself. It just so happens to be used by the XtremeLink system for it's RF communications in our new products.
The DivBee modules are $28 each in single quantity. Both antennas are used for receiving, and either antenna can be used for transmitting.
Old Mar 11, 2013, 11:31 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Yes.
Old Mar 11, 2013, 12:37 PM
Grich is offline
Grich's Avatar
Joined May 2002
isn't the DivBee module the RFU in junction with the Channel Expander if u want full range telemetry? or for XPS will there be another RFU and if so what will be its price and specs?
Old Mar 11, 2013, 02:26 PM
xfedex is offline
Joined Sep 2011
Wow what a dream
Yes.
Jim, you are not going to believe this....I have been thinking about the new radio so much that last night I dreamed that I got a new magazine in the mail, I opened it up and there an ad ad of the new XPS3216 that took up two two full pages! That is one awesome dream that I want to come true and I believe that before long it will come true. The throttle lock feature was the icing on the cake, now I am really getting excited about the release of this radio. It will have everything I am used too and everything else that i could ever want, now about those XPS golf shirts.......
Old Mar 11, 2013, 03:12 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The DivBee module is a separate product that we sell in the Zigbee industry. This module is used on the RFU. We use to use the XBEE modules from Digi corporation.
The Expander has an auxillary interface. It can be used either as a telemetry port or even as an extra channel.
There will only be on RFU. It can output XtremeLink format, Spektrum format, Futaba S-Bus format, Multiplex SLRX format, or PPM format.
The Expander will accept any of those formats as well.
Sold JR Channel Expander Clavin01 Aircraft - General - Radio Equipment (FS/W) 1 Apr 13, 2012 07:48 AM
Looking to expand my operation... CyberJay Coaxial Helicopters 14 May 17, 2005 06:50 PM
PFM is looking to expand into the larger scale aircraft. WJ Birmingham Sport Planes 12 Jan 02, 2004 10:31 PM
Expand battery bay in flying wing? navyflier Foamies (Kits) 7 Apr 08, 2003 11:27 AM
