Old Feb 06, 2013, 02:02 PM
tholmes345 is offline
Find More Posts by tholmes345
Fly inverted, it's more fun.
tholmes345's Avatar
United States, SC, Greenville
Joined Apr 2006
How much are the expanders?
tholmes345 is offline Find More Posts by tholmes345
Old Feb 06, 2013, 03:35 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Originally Posted by JimDrew View Post
Sorry, but we do not ever have advance orders. I expect them in mid-March, and available after secondary assembly, programming, testing, and packaging.
Got it - thanks Jim.
TTRotary is offline Find More Posts by TTRotary
Old Feb 07, 2013, 10:04 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
I am not sure what the pricing will be yet for each different size (channel capacity) expander. You will have the ability to mix and match RF units and expanders to suit your needs.
JimDrew is offline Find More Posts by JimDrew
Old Feb 07, 2013, 02:18 PM
E_ferret is offline
Find More Posts by E_ferret
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
why go to the trouble of making various sizes? Just make it so that a standard size can be cascaded, if at all possible, that is.
E_ferret is offline Find More Posts by E_ferret
Old Feb 07, 2013, 02:37 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Some people don't want 12 channels or 16 channels. There is no way to simply cascade boards together. So, there will be different expanders boards with different features. Some of the future expanders will have 9 axis flight stabilizers and such built in. By separating the RF from the servo driver (expander), it makes the expanders much more affordable and allows people to actually 'borrow' RF units from an aircraft without having to worry about re-installing an entire system, setup failsafes, etc.
Old Feb 07, 2013, 04:14 PM
Bazz is offline
Find More Posts by Bazz
Bazz
Swift Current, SK. Canada
Joined May 2007
Jim will these RF and Expander boards be capable of telemetry? It looks like they will replace receivers as we know them now? This setup is new to me and I'm not sure how they work.
Bazz is offline Find More Posts by Bazz
Old Feb 07, 2013, 05:09 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
10 is a good size, and they can already simply be Y'd together to get more channels/outputs... but the bigger units will have more toys... the gyros like Jim mentioned, but most importantly the auto-match™ servo matching for the giant scale toys (which is where the real party is at... well, the expander in itself is a big party, but the auto-match will be the after-party party )
theKM is offline Find More Posts by theKM
Old Feb 07, 2013, 05:12 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
the new DivBee based RF units will be telemetry
Latest blog entry: Updated Hatcam - Apr2016
Old Feb 07, 2013, 06:28 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The expanders all have a telemetry input. The DivBee based RF can transmit telemetry data at full range. The Nano does not have super long range for transmissions (just reception), so it really is not a good option for telemetry - but you never know.
Old Feb 11, 2013, 08:13 AM
tholmes345's Avatar
Joined Apr 2006
If the device is not found, then you are not putting the device into computer programming mode. To do that, push and hold the programming button (original receivers) or PROG button (transmitter module) or attach the jumper (Nano) and then apply power. Once the LED is lit, release the button (or pull the jumper in the case of the Nano). The device can now be accessed from the XDP software.
Okay, got that part. I am able to program the Rx for telemetry. Saved the change. My A9 does not give me any kind of indication of the Rx voltage. Still missing a part of the process? I cycle the Tx and Rx and nothing. The servos work as they are supposed to. Do I need another piece of hardware? (sensor?) Thanks again for your help.
Old Feb 11, 2013, 09:20 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Just make sure that you set the telemetry type to be PC/Tx instead of PC only. That and a frame rate are the only two things required to enable telemetry back to a transmitter's display.
Telemetry was supported starting with v3.0, so the receiver's firmware should be fine.
Old Feb 11, 2013, 10:03 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Made a lot of progress with the RFU coding over the weekend. It now supports over the air flashing (as well as serial based - more on that in the future), and data formats for Xtreme (XPS), Spektrum low-res, Spektrum high-res, Futaba S-BUS, and PPM. I am working on VBar (VStabi) and a few other formats.
The Expanders also support the same formats, so these will be available to other brands of radio systems (Spektrum and Futaba initially).
Old Feb 11, 2013, 11:43 AM
JuanRodriguez is offline
Find More Posts by JuanRodriguez
The Villages, Florida
Joined May 2003
That's great, Jim !!
We all would love to hear the progress being made on getting the transmitter to market as well......
JuanRodriguez is offline Find More Posts by JuanRodriguez
Old Feb 11, 2013, 02:44 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
At the moment, I am focusing 100% of our efforts on new receivers and expanding into other brand markets. Just about any type of 2.4GHz receiver can be used with our expanders. For those that are not already using the XtremeLink radio system, this is a stepping stone to get there.
I am adding SRXL serial format to the list of supported formats. That covers Multiplex, BeastRX, and Hott-SUMD formats.
Old Feb 11, 2013, 04:29 PM
_Peter is offline
Find More Posts by _Peter
Gotta Luv Gasser Helis..
_Peter's Avatar
Gold Coast, Qld , Australia
Joined Apr 2006
Now I just need you to work out how to get a telemetry display on my JR 11X Zero !!!! ( with a XPS module of course!!!)
My poor old JR 9X11 got too unreliable of late , so the 11X is a stopgap 'till the XPS Tx is out ......
_Peter is offline Find More Posts by _Peter
Sold JR Channel Expander Clavin01 Aircraft - General - Radio Equipment (FS/W) 1 Apr 13, 2012 06:48 AM
Looking to expand my operation... CyberJay Coaxial Helicopters 14 May 17, 2005 05:50 PM
PFM is looking to expand into the larger scale aircraft. WJ Birmingham Sport Planes 12 Jan 02, 2004 09:31 PM
Expand battery bay in flying wing? navyflier Foamies (Kits) 7 Apr 08, 2003 10:27 AM
