Old Jan 28, 2013, 11:03 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
The receiver can have an ignition module glued to it and it won't care. The ignition module can affect the servos though... so, if you have an ignition kill plugged into the receiver, the receiver bus could be noisy because of it and pass that noise to the servos. If the servos don't have filtering, then they could have issues. Most digital servos don't have any issues... it's the older analog servos that could present a problem.
JimDrew is offline Find More Posts by JimDrew
Old Jan 28, 2013, 12:20 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Jim, what would you recommend for a simple, inexpensive telemetry setup with the expander - lets say all I want is flight pack voltage and RX voltage.
TTRotary is offline Find More Posts by TTRotary
Old Jan 28, 2013, 12:43 PM
tholmes345 is offline
Find More Posts by tholmes345
Fly inverted, it's more fun.
tholmes345's Avatar
United States, SC, Greenville
Joined Apr 2006
Good question, I would also like to have that with my A9 Hitec.
tholmes345 is offline Find More Posts by tholmes345
Old Jan 28, 2013, 04:49 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The Rx voltage is standard with the expander, but the flight pack voltage requires a sensor for that. I plan to switch the telemetry data stream to be the same as JR's DMSS... since it is basically our system anyways. This would open up the sensor availability for our customers, and also open a market for producing less expensive sensor options for JR customers.
Old Jan 28, 2013, 05:10 PM
TTRotary is offline
Joined Mar 2010
So I will see Rx voltage on my A9 with the expander + RF?
Old Jan 29, 2013, 03:51 AM
Doffen24 is offline
Find More Posts by Doffen24
Doffen24's Avatar
Norway
Joined Sep 2008
JR do not have any Vario sensor, as Eagletree has. What about your ealier statement about i2c konverterer and Eagletree sensors....
Doffen24 is offline Find More Posts by Doffen24
Old Jan 29, 2013, 04:42 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Don't rush things. It's only four years since it was announced
Anyway, does the expander have any relation to telemetry? Does it have sensor ports and send data to the RF part?
Edit: Never mind. Found out that it does.
flarssen is online now Find More Posts by flarssen
Old Jan 29, 2013, 09:27 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
You can see the Rx voltage right now with our module and 8 or 10 channel receivers! This will be no different with the expanders.
Old Jan 29, 2013, 09:28 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
JR does have a Vario... but it's $89 MSRP - a reason to make one.
I heard that Eagletree is making a Eagletree->JR converter.
Old Jan 29, 2013, 09:29 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Yes, and people have been using telemetry for 4 years too.
Old Jan 29, 2013, 11:51 AM
TTRotary is offline
Joined Mar 2010
Great! I've used only Nanos since I switched over from the Hitec stuff, so I didn't know this capability already existed on your other RXs.
Old Jan 29, 2013, 01:31 PM
Grich is offline
Find More Posts by Grich
Grich's Avatar
Joined May 2002
if a servo shorts out connected to the expander, lets say signal to ground, will it set the receiver into binding mode, will it effect the other servos or receiver in any short config?
The most important part of telemetry to me is knowing the lowest cell voltage in my powered glider when the cell goes down to a user set limit. (a voice saying "battery cell at 3.7 volts",would be ideal). What combinations of receiver to expander would allow this and what selected outputs (XPS,PWM,PPM,or other)
Grich is offline Find More Posts by Grich
Old Jan 30, 2013, 01:33 AM
Son, Norway
Joined Sep 2004
Maybe, but not with Eagletree sensors, which was the topic.
In addition to JR and Eagletree, you should maybe consider the FrSky range of sensors. They even have 6S cell voltage sensors that can be chained for monitoring up to 12S.
Fred
Old Jan 30, 2013, 08:45 AM
tholmes345's Avatar
Joined Apr 2006
How does that work? Is it a direct communication that shows up on the A9 screen?
Tom
Old Jan 30, 2013, 09:01 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
If the signal wire shorts to ground, the only affect would be that the shorted servo would no longer work. We have a separate "B" (bind) port just for this reason on the Nano receivers. The expander has a physical push button that is required to be pressed in order to enter binding and programming modes.
I am not aware of any telemetry sensors that show independent cell voltages - and you are the first to request this. It's certainly possible.
Sold JR Channel Expander Clavin01 Aircraft - General - Radio Equipment (FS/W) 1 Apr 13, 2012 06:48 AM
Looking to expand my operation... CyberJay Coaxial Helicopters 14 May 17, 2005 05:50 PM
PFM is looking to expand into the larger scale aircraft. WJ Birmingham Sport Planes 12 Jan 02, 2004 09:31 PM
Expand battery bay in flying wing? navyflier Foamies (Kits) 7 Apr 08, 2003 10:27 AM
