Old Jun 08, 2012, 01:15 AM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Idea
Channel Expander?
With the 32 channel transmitter coming, we are having to look at ways to get all of these channels available. I had an idea today that I wish I would have thought of and implemented already.
What is everyone's thoughts on a channel expander for the XtremeLink system? This would be a very small board (not much larger than an end pin servo connector) that would have a single input and multiple channel outputs. Perhaps something like 10 channel outputs. I could change the Nano (and other receivers as well) firmware so that one of the channels was a 250Kbps (or more) serial datastream output that would be fed into the channel expander. It would delay the expanded channels by about 1ms. So, a Nano + 10 channel expander would give you 15 channels. These expanders could be very inexpensive, perhaps in $25 range. They would have auxillary power inputs for power hungry servos. You could use a Nano with a single servo extension located anywhere you like (as THE receiver, with no servos connected) and the expander being used for all of your servo (10) channels. The expander would have channel map programming, just like our receivers do.
We could make 10, 12, 16, etc. channel versions of these expanders. In theory you could have two 16 channel expanders and a single Nano to get 32 channels + 5 extra copies. This is somewhat like Futaba's S-bus, except the data speed would be much faster (less latency), and you can use the other channels on the receiver for servo... and there would be programming capabilities on the expander.
Comments?
JimDrew is online now Find More Posts by JimDrew
Old Jun 08, 2012, 02:46 AM
_Peter is offline
Find More Posts by _Peter
Gotta Luv Gasser Helis..
_Peter's Avatar
Gold Coast, Qld , Australia
Joined Apr 2006
Sounds like this will be a very neat setup........
_Peter is offline Find More Posts by _Peter
Old Jun 09, 2012, 12:17 AM
Swen is offline
Find More Posts by Swen
Passion
Joined Sep 2009
+1 This will then be the best setup in the world.
Swen is offline Find More Posts by Swen
Old Jun 09, 2012, 05:35 AM
JuanRodriguez is offline
Find More Posts by JuanRodriguez
The Villages, Florida
Joined May 2003
JD,
Sounds like a neat idea but with all due respect, I think that you should focus 100% of your efforts on getting the transmitter to market..... Make that 110% !!
JuanRodriguez is offline Find More Posts by JuanRodriguez
Old Jun 09, 2012, 04:47 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I could one for sure.
Bob
bruff is online now Find More Posts by bruff
Old Jun 09, 2012, 05:59 PM
tande is online now
Find More Posts by tande
Joined Feb 2004
To a "layman" like myself....it sounds great!.....whats the downside?....(waiting?)
tande is online now Find More Posts by tande
Old Jun 09, 2012, 11:15 PM
Lake Havasu, AZ
Joined Jun 2005
There is really nothing to develop with a product like this. The coding is already done (it's in the receiver). I am using the telemetry data stream for the data transfer (also already in the receiver), and the PCB artwork is almost completely done by virtue of having receivers already done. The only work really is to change the PCB artwork and test it. So, things like this do not take away any real time from transmitter project.
There are no downsides. You get more channels than current receivers, with the ability to locate the antenna away from potential interference (wires, metal parts, etc.)
Old Jun 10, 2012, 08:18 AM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
Originally Posted by JimDrew;21836364 ?[/QUOTE
They would have auxillary power inputs for power hungry servos. You could use a Nano with a single servo extension located anywhere you like (as THE receiver, with no servos connected) and the expander being used for all of your servo (10) channels. The expander would have channel map programming, just like our receivers do. Comments?
I assume that the servo power on the expander could be totally independent of the Nano power. If so, then that would be a good reason to use the expander even if extra channels aren't needed.
ChuckA is offline Find More Posts by ChuckA
Old Jun 10, 2012, 09:47 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Comments?
awesome! if you can also bake in the auto-matching for ganging servos, it would be rather epic
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Jun 10, 2012, 09:53 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Single servo wire from the expander to the Nano to power the Nano and get the signal to the expander is sweet... basically replicating my usual power harness setup without needing a dozen channel wires. IMO, if you can't reliably power the servos the plane is lost anyway...
Old Jun 10, 2012, 11:57 PM
Lake Havasu, AZ
Joined Jun 2005
Yep, just like your setups, but with a single servo connection between the expander and the Nano. You can power the Nano and the expander electronics separately from the servo power, or from it.
Old Jun 11, 2012, 12:15 PM
tande is online now
Joined Feb 2004
OK, we're convinced!....Lets "Get'er/Done!....
Old Jun 11, 2012, 12:17 PM
Lake Havasu, AZ
Joined Jun 2005
Samples are in route right now. I put two screw holes in the PCB so you can attach it like a power expander.
Old Jun 11, 2012, 01:01 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I'm in!
Bob
Old Jun 11, 2012, 06:07 PM
E_ferret is offline
Find More Posts by E_ferret
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
add an optional opto-coupler connection and nobody will be able to blame noise from the digital servos to travel over the common ground wire to the rx.
E_ferret is offline Find More Posts by E_ferret
Sold JR Channel Expander Clavin01 Aircraft - General - Radio Equipment (FS/W) 1 Apr 13, 2012 06:48 AM
Looking to expand my operation... CyberJay Coaxial Helicopters 14 May 17, 2005 05:50 PM
PFM is looking to expand into the larger scale aircraft. WJ Birmingham Sport Planes 12 Jan 02, 2004 09:31 PM
Expand battery bay in flying wing? navyflier Foamies (Kits) 7 Apr 08, 2003 10:27 AM
