Old Jun 07, 2012, 08:06 PM
seeyalaterbye is offline
Find More Posts by seeyalaterbye
Joined Mar 2012
standard bolt pattern?
is there a standard mounting pattern size for parkfly brushless out runners? the two different turnigy motors i have are 16mm spacing and the dji motor i have is 16mm x 19mm
im designing a quadcopter frame in mastercam for a class projects and im down to just motor mounts now.
any input would be great. thanks everyone.
seeyalaterbye is offline Find More Posts by seeyalaterbye
Old Jun 07, 2012, 09:13 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Most 28mm-diameter motors I've got use a standard 16/19mm spacing. One of them (a 450 heli motor) has all four holes on a 16mm circle, and they're tapped for two different sizes of screw.
Piece is online now Find More Posts by Piece
Old Jun 08, 2012, 12:10 PM
Depronicus is online now
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
Infuriating, isn't it? There are several hole patterns, and some manufacturers even have their own "specials" that conform to none of the standard ones. Seems odd that the industry never got it together on this.
I can't find an online version of the dimension drawings for the standard C28, C35, and C42 motors (the ones included with so many motors) but if there is a "standard", that's it. I'll try to take some decent photos tonight and post them here.
Depronicus is online now Find More Posts by Depronicus
Old Jun 08, 2012, 01:04 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
16 x 15, 16 x 19, 19 x 19, 19 x 25, 25 x 25 seems to cover the variations on motors up through the 28xx and 40xx models. Some of the bigger motors are 30 x 30 and 43 x 43 I think.
Lots to choose from here as far as sizes and types:
http://www.headsuprc.com/servlet/the...NTS/Categories
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jun 08, 2012, 02:14 PM
Joined Mar 2012
Thanks for the info guys. I don't know why I didn't think about just slotting the bolt pattern so it would fit whatever in the 28mm range
Old Jun 09, 2012, 12:10 AM
Depronicus's Avatar
Southern California
Joined May 2009
Like I said, if there is a "standard" for 28mm, 35mm, and 42mm motors, this is it. Note that some manufacturers use the 25x25 hole pattern on their 35mm motors though, just to keep us guessing. Some also deviate slightly from the outer hole pattern dimensions too, for some unfathomable reason.
No, I don't know why the 19x16 and 25x19 patterns exist. I can't think of a reason why somebody would think the short axis would be a good idea. If a motor is big enough for the long axis, why not make both of them long?
This crap drives me crazy, in case you hadn't already guessed...
Question Rimfire Prop Adapter Bolt Patterns Chophop Power Systems 0 Apr 22, 2012 06:58 PM
Question Gold Big Screamer Bolt Mounting Pattern Help bri6672 Electric Ducted Fan Jet Talk 2 Apr 17, 2012 11:41 PM
bolt pattern Astro 010 and MiniAC 16 KenP Power Systems 6 Feb 26, 2003 07:26 AM
Bolt pattern on the 450 Turbo motor vs. Speed600 motors Scott C Power Systems 1 May 22, 2002 09:57 AM
