Old Jun 07, 2012, 07:40 AM
copterfilms is offline
Find More Posts by copterfilms
Close Range Aerial Imagery
copterfilms's Avatar
Argentina, Autonomous City of Buenos Aires, CF
Joined Feb 2006
DJI NAZA GPS v2 Tests - Southern Hemisphere
We have been test flying the new Naza GPS v2 with significant results for those here at the Southern Hemisphere (SH) of the globe.
We are located in Argentina, South America.
Here a short video with a few tests on improved GPS lock, more complete set of tests to come.
DJI NAZA GPS v2 Hexacopter Test in Southern Hemisphere (3 min 15 sec)
Victor
www.copterfilms.com.ar
copterfilms is offline Find More Posts by copterfilms
Old Jun 07, 2012, 11:25 PM
Velociraptor73 is offline
Find More Posts by Velociraptor73
SMILE you're being recorded :)
Velociraptor73's Avatar
Joined Apr 2010
Did you also have problems with WKM on original antenna?
Velociraptor73 is offline Find More Posts by Velociraptor73
Old Jun 07, 2012, 11:31 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Not to rain on the parade but you were flying in Manual. I saw no red flashes but it would be nice to actually see the GPS/ATTI performance. Red lights disappearing does not mean great GPS performance.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Jun 08, 2012, 08:58 AM
Joined Feb 2006
Yes, erratic GPS lock.
Tahoe,
Have you watched the video thoroughly? Last text clearly says "more tests to come", i should better say "more filmed tests to come" since we have been flying it before of the shooting of this video.
We shot this test on the rooftop of our office, Buenos Aires downtown, tight space with sorrounding walls, wires and a crowded avenue few meters away all during gusty winds and a mild drizzle, did not intend any auto mode for safety reasons.
The three filmed flights were reduced to what you see to avoid being boring since nothing interesting happens other than to show the strength of the GPS signal.
Old Jun 08, 2012, 08:55 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Understood. I will wait for you next videos.
Site Sponsor
Old Jul 19, 2012, 03:35 PM
Joined Feb 2006
Been flying the Naza GPS in many conditions during these past weeks.
I can conclude that the GPS issue has been fully resolved in the Southern Hemisphere, the system can be flown confidently.
Full GPS signal was acquired and mantained during 100% of the flights, long range GPS, day/night flights were performed with no droppings.
We flew long range FPV circuits confidently with the Naza GPS including RTH too.
Im very satisfied so far, uploading video.
Victor
Old Jul 19, 2012, 05:20 PM
djtibas is offline
Find More Posts by djtibas
djtibas's Avatar
Joined May 2011
My naza is perfect in Brazil !!!
Hexa travado no GPS!!!! (1 min 30 sec)
djtibas is offline Find More Posts by djtibas
Old Jul 19, 2012, 05:50 PM
Joined Apr 2010
Hi djtibas,
What part of Brasil do you live?
Did you have to do the magnetic declination compensation?
Old Jul 20, 2012, 02:14 AM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Hi guys whats the difference between this oner and the original one ?
Cheers
Adrian
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Jul 20, 2012, 02:16 AM
Adrian_M is offline
Joined Dec 2010
http://www.youtube.com/watch?v=-OXj5SgeJ-Q
what do you mean no GPS ?
Old Jul 20, 2012, 12:05 PM
Joined Feb 2006
In our case yes, we have been flying around Buenos Aires city which magnetic declination is 7 degrees. We needed to compensate for it by turning the GPS module counterclockwise 7 degrees, toilet bowl effect was eliminated this way.
We needed also to cover the NAZA CPU from direct sun hit to avoid issues with the altimeter sensor.
Old Jul 26, 2012, 09:56 PM
totality is offline
Find More Posts by totality
Joined Jan 2012
I live in New Zealand and have the toilet bowl effect using Naza and GPS. Few questions:
1. How long does it take to obtain a satellite lock the first time you turn it on? Mine takes a few minutes at least to stop flashing red
2. What do you mean by Naza GPS v2? DId they release it again?
3. How do I know how many degrees I need to turn the GPS unit?
totality is offline Find More Posts by totality
Old Jul 27, 2012, 12:30 AM
slidins15 is offline
Find More Posts by slidins15
Australia, NSW, Wollongong
Joined Aug 2011
1. Mine was taking about 1:30 to get full lock here in AUS, but after putting a carbon plate under the GPS that has dropped to about 30secc
2. Naza is the naza. Naza GPS is Naza GPS. THere is no V1 or V2
3. Look up the magnetic declination for where you live in NZ. If it is positive, you need to turn your GPS CLOCKWISE to compensate for the declination. So if declination is +10, then you rotate your GPS clockwise 10 degrees.
If it still toilet bowls, try a little more clockwise, or anticlockwise until you get it right. If it still toilet bowls, check your GPS mounting coordinates.
slidins15 is offline Find More Posts by slidins15
Old Jul 27, 2012, 07:02 PM
totality is offline
Joined Jan 2012
Thanks. Toilet bowl effect fixed with turning the Naza. Does this break course lock mode though as the arrow is pointing away from the front? I find that turning on course lock mode means the quad doesn't fly straight ahead now.
I left it to get a GPS fix again today and after10 minutes gave up. I am trying to find out if the FrSKY telemetry receiver could be causing the problem. I moved the GPS off the quad and as far away onto the grass as possible but it still wouldnt get a full lock. It would sometimes flash green only then drop and go back to flashing red or all the way back to three reds. It is a completely clear sky today.
Old Jul 28, 2012, 06:03 PM
Joined Feb 2006
Totality,
In spite of the mag declination correction i see no tendencies to fly out of track. Have you recalibrated the magnetometer after mag declination correction?
Here you can find an useful site which tells exactly your mag declination.
http://magnetic-declination.com/
You can also use a GPS application in your cell phone, most of them also include mag declination information.
GPS locks in less than a minute here, no red lights. Try restarting if you are not lucky the first time.
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Sold DJI Naza FC Mounted w/ 2 test Flights zuby1 Aircraft - Electric - Multirotor (FS/W) 7 Mar 26, 2012 06:02 PM
Mini-Review DJI NAZA Unboxing, Installation and Testing Lucidity47 Multirotor Talk 16 Feb 23, 2012 08:42 PM
