How long did it take to get your motor shipped?
I am worried it won't be here soon enough to get the rest of the build done. Headsuprc is in Florida and usually ships same or next day. Could you look at their site and recommend a motor, esc and prop from them. I would really appreciate it. http://www.headsuprc.com |
Mo,
http://www.headsuprc.com/servlet/the...ushless/Detail This is the motor I started with, moved up to a bit more power once I had the hang of it. A 7x4 prop and 18-20A ESC is okay with this. http://www.headsuprc.com/servlet/the...h-19%29/Detail This motor could be a bit juicy with a 6x3 prop. Save all the fussing, just get a 25-30A ESC and when you 'mod-up' you will only have to change the motor & prop
Rw how many of these have you built?
I still have not ordered a motor/esc from a closer place. I hope it doesn't take two to three weeks to get here. I won't be ready for the combat if that happens. My local hobby store only has two motors an neither are even close to what I need. You would figure with all the plane parts they would have a few more choices of motors. And the local RC hobby store we use to have closed about two years ago. |
Mo, it's not great here for model parts either ! Our LHS doesn't really do component parts (esc's, servo's & motors) just ARF kits and some airframe only. I get most supplies on-line, some of which I have to order from US, so you should be in a better position with a few on-line options. Funbat - just the one at present, but might be about to expand the squadron with a 16" wingspan version. Trouble is when I order bits, I feel the need to take more kit than I need to make best use of the postage scale ! The other-half hasn't figured yet that I sometimes have to order two servo's but to make up the weight I get a motor & two batteries as well
Talking 'combat', well a FB and I were going for it with our funbats a few weeks back and couldn't get close ! I even stayed slow, flat & straight while my FB tried to cut my paper streamer off the back, nope... it wasn't happening. 2 weeks later and I drive my simple delta up to the back of his flying wing, announce I'm coming in like a refuelling manoevre and I scored a hit. He carried on flying, mine without prop by now had a glide back down and I put it on the deck about 10ft from me, pleased with that considering![]() Can I post supplier links, or is someone going to be less than happy ? |
Would a 60amp esc work with a motor only requiring a 15 amp?
Motor C2822/25 Size KV(rpm/v) 1400 Power(W) 160 Wire Winds 25 Resistance(mO) 352 Idle Current(A) 0.7 Shaft diameter A(mm) 3 ESC(A) 15 Motor length B(mm) 23 Cells Ni-Cd/Ni-MH 6-12 Motor diameter C(mm) 28 Cells Li-Po 2-4 Basic length D(mm) 12 Prop 7.5x3.5/8x4/9x5 Total length E(mm) 36 |
| Thread Tools | |
| Discussion Which Parkzone flyer is the best for the money? | XxOoCoBrAoOxX | Micro RTF | 14 | Feb 01, 2012 07:08 AM |
| Discussion What plane for new plane flyer, familiar with helicopter | DennizMT | Beginner Training Area (Aircraft-Electric) | 25 | Apr 04, 2011 09:07 PM |
| Discussion which plane for combat? | jamesrini | Foamies (Scratchbuilt) | 6 | Jul 19, 2010 07:10 PM |
| Discussion which plane fro new flyer? | boos boy | Beginner Training Area (Fuel) | 7 | May 24, 2007 05:15 PM |
