Old Jun 06, 2012, 09:27 PM
Mopower71 is offline
Find More Posts by Mopower71
Corsir Crasher
Mopower71's Avatar
United States, NY, Poughkeepsie
Joined Oct 2011
Question
Which combat plane for a new flyer
I have been looking at three combat planes to build. All are similar.
Which would be the easiest flying one for someone that has not been flying long.
The Muncie F&F http://www.rcgroups.com/forums/showthread.php?t=1061750
The Blue Funder http://www.rcgroups.com/forums/showthread.php?t=363570
Or the Funbat http://www.rcgroups.com/forums/showthread.php?t=1385215
Mopower71 is offline Find More Posts by Mopower71
Old Jun 07, 2012, 01:49 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
The SEMFF StingRay is a flying combat wing with sleek organic looks and outstanding flight envelope performance. This plane has delighted low time pilots with its gentle characteristic by limiting the control throws, and satisfied the performance freak with an outstanding power to weight ratio and a 3s battery. http://www.rcgroups.com/forums/showthread.php?t=1542672
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Jun 21, 2012, 05:11 PM
Mazzepa1 is offline
Find More Posts by Mazzepa1
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
I built one of these.
http://www.rcgroups.com/forums/showthread.php?t=926637
My 1rst scratchbuilt foamy, and I'm a fairly new flyer. It went together fast and easy, inexpensive to equip.
I'm astounded at how well the MiG3 flies. Simple and robust, stable and smooth, but very agile when asked to be so. Slows down very well, almost ridiculously easy to land.
After seeing, mine fly and trying it out for themselves, 2 of the long time rc'ers in my club are building MiG3s as we speak.
Great fun, highly recommended.
Mazzepa1 is offline Find More Posts by Mazzepa1
Old Jun 22, 2012, 12:59 PM
RWData is offline
Find More Posts by RWData
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
It has to be the funbat for me, super stable like it's on rails. Can be a gentle & smooth flyer or you can juice it up for exciting performance. Flie's in wind very well, I'm not that long in the hobby, but the funbat get's my vote for newb's and 'articulate' pilots alike.
RWData is offline Find More Posts by RWData
Old Jul 02, 2012, 01:57 AM
Mazzepa1 is offline
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
So what did you wind up building, Mopower?
Old Jul 02, 2012, 06:55 AM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
In the process of cutting out a fun bat. Used dollar store foam board. This is the first plane I am building like this and the funbat looked like an easy first attempt
Old Jul 02, 2012, 09:56 AM
RWData is offline
PowerTower
RWData's Avatar
Joined Aug 2009
Mo, good choice Mine is a treat to fly and can cope with windy conditions really quite well, so a good all-rounder when conditions are a bit difficult. If you have not already done so, consider putting a balsa leading edge on wing, it makes the bird a bit tougher saves time sanding a LE too. Pic's when finished please
Old Jul 02, 2012, 12:11 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
pictures of where it's at right now coming very soon. I'm sitting in the back yard cutting this while the kids swim in the pool.
Old Jul 02, 2012, 12:21 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Here are a couple shots of where I am now.
I need to find a power system for this, and money is tight.
Thinking about using the motor/esc out of my ArtTech Corsair.
Old Jul 02, 2012, 12:55 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
How do you fold the front of the wing over?
I cut the section out at an angle, but it only folds half way.
Should I flip it over and fold it with the cut side out?
Old Jul 02, 2012, 03:19 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Front of wing is done.
CF or wood dowel for the spar?
Almost time to break out the glue
Old Jul 02, 2012, 04:15 PM
RWData is offline
PowerTower
RWData's Avatar
Joined Aug 2009
Mo, it's taking shape well. I did build mine with sheet depron and didn't have a fold-over, just laminated two 6mm sheets together giving KF step. My spar is carbon flat, 6mm x 1.2mm bonded to back of upper sheet. You can build so many ways and I don't think there's a wrong way. Mine is perhaps not as conventional as the plan version, I cut from a limited material stock so made some 'poetic' build changes. Hopefully if I did it right, ther could be some photo's of how it turned out.
Old Jul 02, 2012, 04:31 PM
RWData is offline
PowerTower
RWData's Avatar
Joined Aug 2009
Funbat photo's and power options
Mo, not sure where the photo's are !
Power options, I had an e=max 1650kv motor to start with and 18A esc, 7x4 prop. Taking a 3s/1000 battery pack up for around 9mins. Not bad for a starting point. I have 'juiced-up' a bit since, now running a 1900kv with 7x4 prop to try and keep up with my FB. Photo's this time
Old Jul 02, 2012, 04:32 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
What Glue should I use on the $ foam with the paper still on it.
Only one person told me to use hot glue or Tarzan grip.
I wonder if the hot glue would penetrate the paper and hold, or if the paper would just peel off.
Old Jul 02, 2012, 04:34 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Wow, Yours came out real good RW
Discussion Which Parkzone flyer is the best for the money? XxOoCoBrAoOxX Micro Ready-to-Fly 14 Feb 01, 2012 07:08 AM
Discussion What plane for new plane flyer, familiar with helicopter DennizMT Beginner Training Area (Aircraft-Electric) 25 Apr 04, 2011 09:07 PM
Discussion which plane for combat? jamesrini Foamies (Scratchbuilt) 6 Jul 19, 2010 07:10 PM
Discussion which plane fro new flyer? boos boy Beginner Training Area (Fuel) 7 May 24, 2007 05:15 PM
