Old Jun 06, 2012, 08:35 PM
Flyboy1958 is offline
Find More Posts by Flyboy1958
United States, PA, Lancaster
Joined Sep 2008
Need help with charger settings on my Lead Acid battery
I was just wondering what settings I should be using on my icharger 206B with my Hanger 9 12v 7Ah sealed battery? I set the charger for PB and when I plug in 12V it comes up as a 6 cell battery, which I guess it is then. Now for the charge rate, should I be using .70A or 7.0 or what? I charged it for about 45 minutes using .70A and it still seems almost dead. I don't know much about charging or batteries. Thanks.
Flyboy1958 is offline Find More Posts by Flyboy1958
Old Jun 06, 2012, 09:09 PM
dmcquinn is offline
Find More Posts by dmcquinn
dmcquinn's Avatar
United States, MO, Chesterfield
Joined Jan 2004
Yes, it is 6 cells. Charge it at 0.70 A for 10 hours, if it is discharged. In general, don't let it get really discharged. Lead-acid batteries last longer if you don't discharge them too deeply.
dmcquinn is offline Find More Posts by dmcquinn
Old Jun 06, 2012, 09:29 PM
Joined Sep 2008
Old Jun 07, 2012, 08:34 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I've never gotten motivated enough to use my iCharger, I just use one of the 600mah wall wart pb chargers. Will the iCharger detect when the lead acid battery is full or is there really no benefit over the wall wart?
grimbeaver is offline Find More Posts by grimbeaver
Old Jun 07, 2012, 02:00 PM
Joined Sep 2008
Thanks, yes it worked. The icharger does detect when it is fully charged. So far so good. My wall wart charger is broken, that's why I decided to try the icharger.
Old Oct 30, 2012, 08:25 PM
FlyinKiwi is offline
Find More Posts by FlyinKiwi
Crashin RC planes since 2012
FlyinKiwi's Avatar
Australia, SA, Adelaide
Joined Oct 2012
Hey how did you get on with charging your PB battery with the icharger? I was going to use my icharger 106b to charge my sons 12v 9.6ah powerwheels battery. Can you give me any pointers on fast charging and peak detection etc?
FlyinKiwi is offline Find More Posts by FlyinKiwi
Old Oct 30, 2012, 09:00 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Pb (lead acid) do not use peak detection ,they use CC / CV same as LiPolys.
Set charger to Pb 6 cells and at 1A rate for 9.6Ah 12 Volt Pb battery.
Old Oct 31, 2012, 09:17 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
On Pb batteries, try to keep the charge rate at 0.1C or lower, especially if it is a sealed gel cell type. Sealed Pb batteries do not take kindly to fast charging and no Pb batteries will tolerate overcharge well. That is why you should always use a "constant voltage/ limited current " charger for Pb. The fact that it is a constant voltage (usually set at 13.6 to 13.7 volts for a 6 cell battery) prevents any overcharge. Also remember that deep discharge will also quickly ruin a Pb battery, always recharge as soon as the resting voltage drops to 11.9 volts.
Rodney is offline Find More Posts by Rodney
Old Oct 31, 2012, 11:20 AM
Southern Pride
Sorry but I have a sealded AGM 12V 48Ah battery which can be charged Rapid Recharge No Amp. limit as long as it does not exceed 15.6V and battery does not exceed 125F.
A more normal (?) charge to 90% starting fully discharged is 100 Amps. for 35 minutes.
Saying that all sealed Pb should be charged at 1/10c is the same as saying same about Nicads,NiMh and do not exceed 1C for Lipolys.
Charles
Discussion charging PB sealed lead acid batteries big_poppa4904 Fuel Plane Talk 25 Dec 18, 2013 01:50 AM
Sold Dumas Boats #2024 Lead Acid Battery 6V 5AH TGKconnectors Boats (FS/W) 3 Nov 15, 2011 10:38 PM
Question Question about Lead Acid Batteries for power supply Borneoben Batteries and Chargers 11 Nov 04, 2011 11:50 PM
Discussion charging PB sealed lead acid batteries big_poppa4904 Batteries and Chargers 1 Sep 28, 2011 12:51 PM
Running charger on mains with 'car charger' and 12V lead acid battery? Ben C Power Systems 7 Jun 08, 2001 08:56 PM
