Old Jun 08, 2012, 03:29 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Originally Posted by Rusty-Gunn View Post
Over the years I see a lot of postings of people saying something like, "I go with two degrees down thrust and right thrust."
But how do they know it's two degrees, ...
Personally I measure the distance from firewall mount to prop driver, then measure how much off-line the prop driver is, and simple geometry (tangent) will tell me how many degrees that is.
gwinhh's data in post #2 is probably near-enough if you're not into geometry; and you probably don't need to be too precise about the actual numbers because, as others have posted, you may want to make adjustments when you find out how your model actually flies.
abenn is offline Find More Posts by abenn
Old Jun 08, 2012, 09:00 PM
Dad_Roman is online now
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Ok...I think your wanting the "Cool Gizmo" solution
Heres what I do.
Easy enough to determine what suface you need to level your plane from, be it a nose section or side or tailfeather.
I use the cool little level to ....well.....level
Then your attached robart Incidence Meter will read out the degrees. Notice the cool little notch that I assume is for attaching said meter to motor
Read through the piccys!
Dad_Roman is online now Find More Posts by Dad_Roman
Old Jun 08, 2012, 09:09 PM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
....OR
You should have ya one of these cool protractors (mentioned earlier )
If you have your plane stable and just wanna "check" you can hold this on the shaft.
Observe.....
Old Jun 09, 2012, 03:23 AM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Originally Posted by Dad_Roman View Post
....OR
Observe.....
Wuw, this tool looks pretty cool. Where does one find them for sale these days?
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Jun 09, 2012, 10:49 AM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
I have two...ya want one? I dunno...say 13 shipped?
Old Jun 09, 2012, 04:40 PM
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I'll PM you.
Discussion Installing right thrust and whats the measurement Thermalin The Builders Workshop 10 Feb 17, 2012 09:05 PM
Discussion How do you measure 1S battery voltage? Denis54 Micro Helis 5 Dec 23, 2011 02:40 PM
Discussion How Do YOU Measure Power on Large EDF Systems A10pilot Electric Ducted Fan Jet Talk 20 Nov 02, 2011 01:50 PM
down thrust, right thrust, Whats the best way to do this? hawkeye_abm Beginner Training Area (Aircraft-Electric) 5 Feb 08, 2002 09:23 AM
