Old Jun 06, 2012, 08:01 PM
TheBlood+ is offline
Find More Posts by TheBlood+
Heavy thinker..I mean tinkerer
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Club Field Charging Station Set-Ups?
Hey guys we are trying to set up a charging station at our local club. We are going to be using two 12v car batteries hooked up in parallel to a solar panel on the roof. Now my question is what is going to be adequate enough(solar panel sizes, and whatever else) to do the job and what else is going to be needed to complete this whole project properly.
Maybe someone could chime in with some good details on what they have at their field already for a set-up.
It would be much appreciated.
TheBlood+ is offline Find More Posts by TheBlood+
Old Jun 06, 2012, 08:40 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
It would be interesting to see how long your 2 batteries last.
I wouldn't think you could put a large enough solar panel up to recharge them in a reasonable amount of time when guys are waiting to charge.
There is a guy over on Helifreak that uses 2 deep cycle batteries in the back of his car to charge his helicopter batteries in the field.
He would know how many charges you can get out of them.
Green is all well and good but sometimes not very practical.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jun 06, 2012, 08:57 PM
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
Ok, I can give you one tip. Run two 6volt golf cart/deep cycle batteries from Costco in series. You will get a whole bunch more amp per hour out of those. 12 volt batteries only give you the large cranking amps. That's why the motor home and large boat guys use the 6 volt batteries. It's still going to need a rather large solar panel, or multiples of them.
Underthetire is offline Find More Posts by Underthetire
Old Jun 07, 2012, 09:25 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
How many users are we talking? I think you would need quite the bank of deep cycle marine batteries and a good system to monitor their health. I know guys who fly large heli and use two deep cycle batteries just for themselves. You figure 110Ah deep cycle, you shouldn't discharge below 50% so 55Ah worth of charging out of it minus efficiency loss. You don't get too many charges. And not sure how you can keep people from draining them too low.
You're basically looking at an off-grid solar system like this:
http://www.wholesalesolar.com/solarp...er-system.html
grimbeaver is offline Find More Posts by grimbeaver
Old Jun 07, 2012, 09:36 AM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
MODEL AVIATION, Jan, 2010, has an article on a solar charging station for less than $500 that a Club in California built.
hwoell
gwinhh is offline Find More Posts by gwinhh
Old Jun 07, 2012, 09:46 AM
United States, MN
Joined Feb 2011
hwoell
I get the feeling some donations or discounted items were involved. Unfortunately I don't have that issue. Anyone care to share the details?
Well here's someone who did similar after that article:
http://www.sky-knights.org/solar.htm
And the important part:
They also allowed the club to purchase all of the parts at their cost.
Old Jun 07, 2012, 12:59 PM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
I think you should start with some data collection. As an example, I usually take 8-12 charged batteries to the field, and then use about 30ah on recharges from my 100ah deep cycle battery. I fly about 6.8 days per week so the solar needs to keep up. But am I "typical"? At my club I would say I'm one of the higher than average wattage users, but not the highest. At your club? No idea.
Dave H. is offline Find More Posts by Dave H.
Old Jun 07, 2012, 06:20 PM
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Some great points here to think about, thats why I posted the question. Thanks guys.
Old Jun 07, 2012, 07:39 PM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
--We are finishing up a charging station at our field. The overall cost of the system is
around $3000. $2500 just in equipment and shipping. I can send you details if you wish.
2 - 145 watt 12volt panels
1 - 30 amp charge controller
1- 60 amp load controller
1 - PV combiner/ breaker panel
4- 110 amp hour AGM (absorbed glass matte) deep cycle sealed batts
Misc, feeder wire, hardware, equipment mounting board, battery box, charge stations
8x2 ft counter top work shelf, etc
G-Forse is offline Find More Posts by G-Forse
Old Jun 07, 2012, 07:57 PM
United States, MN
Joined Feb 2011
That's enough to cover one iCharger 306b charging 6S batteries at 30 amp. You guys must not have any heli people, they will hit that 60 amp easy
Old Jun 07, 2012, 08:12 PM
RC Helicopter Pilot
Joined Mar 2010
And they can only replenish the PB at 290watts.
Old Jun 07, 2012, 11:38 PM
G-Forse is offline
Denver, CO
Joined Nov 2007
--The current setup is designed to be expandable. Initial cost is already $3k.
--We will see how the summer goes. Next year probably add another 60 amp load controller, more batteries, and two more solar panels. This upgrade will be about $1900.
--The two 145 watt panels put out 16.5 amps at mid day with no clouds.
--The load controller protects the batteries from over discharge
Old Jun 08, 2012, 05:16 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Me, or whoever has one, plugs a generator into an outside outlet of the clubhouse. About half a dozen outlets on the inside for power supplies. There are lights on inside of the clubhouse to let you know not to plug another one in.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jun 08, 2012, 08:55 AM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
People with those kinds of power needs should be able to provide it themselves. That, or they should be willing to contribute a proportionate amount of funds towards a club-owned system.
Pete
PGR is online now Find More Posts by PGR
Old Jun 08, 2012, 09:13 AM
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Pete
Holy crap no kidding! That's a killer set-up though.
Our club is small and only charge mostly 3s 2200ma packs, about 4-5 guys on a busy day.
Rant UPS actually charges double website quotes. Stall'n_N_Haulin Trader Talk 20 Jan 11, 2012 12:02 PM
Discussion I need a new field battery for charging at the field Wild Bill Batteries and Chargers 10 Oct 18, 2011 03:39 PM
Discussion DIversity plane and ground station set ups JustinONE FPV Aircraft 3 Oct 09, 2008 05:47 PM
