Old Feb 18, 2013, 09:34 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Originally Posted by gadorey View Post
Thanks, but is that a must? Like I said I am completetly clueless how to wire a proper FPV set up. I know ( I think) what components are needed and more or less how it works, but what I am really looking for is something like a wire diagram for electronically challenged people showing what is connected to what. I know electric motors, ESCs BECs, Lipos, soldering, but video transmission is still chinese to me, and I'm alone here so no one I can ask to show me. So if anyone has a link or post something here I'd be very grateful.
I will have a Gopro 3 black edition and a 5.8g 500 mW vTx. On the ground I have a 7" monitor with integrated vRx for 5.8g. I want a simple set up just to play around and flying LOS. No long distance FPV flights in mind.
7578 miles from you in
China, Shanghai
I just needed to point out this made me lol.
Yeah most FPV equipment can only handle 3S. If you want to fly with 4S you'll need something like TJ posted to bring down the voltage OR a small 3S batter for your FPV equipment only. I use 3S 1000-1300mah batteries for my FPV and it only needs to be charged every 10ish flights. There is a few reasons why this is a good idea but the biggest is that if your multi puts a lot of stress on your battery or the voltage sags you will loose video which as you can imagine is bad.
Here is the basic flow of video/power for most setups
Power
Battery -> vTx -> Camera
(I don't have a ton of experience with different brands of vTx's but I know Immersion vTx's supply out 5V of power to your camera. My old FPV camera was a 5V so this worked fine but my new one demands more power (12V) so I had to buy a 5V to 12V Step-Up to put between the vTx and the camera. Simple)
Video
Camera -> vTx -> vRx -> Monitor/Goggles
If you are interested in flying with goggles for short distances I recommend you look into the FatShark Predator system over at HobbyKing. I started with that and it is pretty easy to use when first starting out. I since have upgraded the antennas twice and the vTx to get a better signal regardless of outside interference.
MCrites is offline Find More Posts by MCrites
Old Feb 18, 2013, 09:36 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
@gadory
You asked this:
Still one question though. Do you connect the the vTx to the battery mains or balancing plug? The vTx I ordered operates from 7.4V to 13V, so with a 3S Lipo it's fine. But what if one day I decide to use a 4S? Goes pooof with a fully charge batt?
I answered this:
You'll need something like this...
http://www.dpcav.com/xcart/Adjustabl...EPIC-Type.html
To be more specific:
Some pilots tap off their balance plug to power things, I've read pro and cons.
You probably need to make up your own mind.
A 3S lipo will work fine for your vtx, but 4S will require a voltage regulator.
Or you can research tapping off the balance plug using only 3 cells of the 4 cell lipo.
I like the voltage regulator that I posted the link for...
It keeps your voltage constant if the lipo cells sag.
It can step output voltage UP from the input voltage.
Pretty cute!
Many of your questions can be answered by exploring around this site.
Their technical help area is pretty good.
https://hobbywireless.com/
T J Gilbert is offline Find More Posts by T J Gilbert
Old Feb 18, 2013, 09:45 AM
kallend is offline
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
I'll try tom weigh it one of these days. The scales I have at home didn't really work because I couldn't get the quad with the U/C on them properly.
Well, the current consumption does depend sensitively on the weight of the machine. In my tests on a 450, every additional 100g of mass requires an extra 1.4amps in order to hover.
kallend is offline Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Feb 18, 2013, 09:49 AM
kallend is offline
kallend's Avatar
Joined Sep 2004
Originally Posted by Gloon View Post
My suggestion is to take power from the main battery. If you carry a second battery only for your vTx you are caring dead weight sometimes. e corresponding BECs. Again, my suggestion is to leave the Gopro battery alone.
Something I learned many years ago is that every additional item powered from your main battery represents one additional point of failure that can potentially take out your entire very expensive investment. These days I ALWAYS power everything not part of the flight control system from a separate battery.
Old Feb 18, 2013, 10:13 AM
Gloon is offline
Find More Posts by Gloon
Joined Sep 2012
Originally Posted by T J Gilbert View Post
Yes, T J Gilbert has the best solution, I think.
I don't have access to such a good voltage regulator. So I settled with a L7812CV
http://www.datasheetcatalog.org/data...onics/2143.pdf
I guess Gilbertīs is better because it has more components and maybe the signal is cleaner.
Take the power from to the battery mains or balancing plug. Its the same. But If you take power from the balancing plug use all cells. Dont take only the cells you need (3 out of 4) for your vTx, otherwise you will end up with an unbalanced battery, take voltage from all 4 cells out of the balancing plug.
best regtards
Martin
Gloon is offline Find More Posts by Gloon
Old Feb 18, 2013, 10:19 AM
kristjane is offline
Find More Posts by kristjane
Have a nice day! Kristjan
kristjane's Avatar
Slovenia, Novo mesto, Šentjernej
Joined Jan 2006
Need help
Have clone of DJI 450 frame, naza with GPS, 4x blueseries 12A ESC-s and keda motors. So far model was flying perfectly. But when I flashed ESC-s I had crash ( no props were broken). I used same settings as before with stock FW. flight was ok, at beginning, but when I made turn and ad some throttle to speed up model it flew few meters normally and then just made 90° turn and fall in to snow at angle of about 20-30°. Should I turn gains up? At the moment they are at about 100-120.
In hovering and slow flying model was very stable and I had no oscillations.
kristjane is offline Find More Posts by kristjane
Old Feb 18, 2013, 10:30 AM
Empire Support
Joined Feb 2009
@Gloon
"I guess Gilbertīs is better because it has more components and maybe the signal is cleaner."
Mine's not necessarily better.
It just does more than yours.
Mine is adjustable via a pot.
Mine is a SEPIC regulator capable of a higher output voltage than input voltage.
That's why I think it's cute!
RF interference could be worse than yours.
The website recommends a filter they sell if there is a problem...
There are many ways to skin a cat...
Old Feb 18, 2013, 10:34 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
best regtards
Martin
Actually the difference is that your linear reg dissipates the extra voltage as heat whereas the switching reg switches the source voltage on/off to get the desired average output. The other advantage is that it can also act as a power filter for your vtx (so you don't get horizontal interference lines from the motors). Not sure if TJ's will filter, but I use this one and was able to remove my seperate LC filter.
http://www.dimensionengineering.com/products/de-swadj
edit: just read TJ's post and forgot to mention I have no RF interference issues (using 1280 or 5.8 video and 2.4 control), but that may be specific to my setup.
Cervanchez is offline Find More Posts by Cervanchez
Old Feb 18, 2013, 12:18 PM
kallend is offline
kallend's Avatar
Joined Sep 2004
Originally Posted by Bill Glover View Post
For those who can be bothered to read it a new version of the Naza manual was released today:
http://download.dji-innovations.com/..._Manual_en.pdf
No idea what has changed though!
Mostly additions. Page 6-7 expanded significantly, p8 has additional box, stick calibration expanded and clarified, failsafe section has been expanded, compass calibration section clarified, more information about IMU calibration, and some cleaning up of the Chinglish.
Old Feb 18, 2013, 12:36 PM
Empire Support
Joined Feb 2009
Naza Manual 2.5
One thing they changed was probably the result of our testing...
On page 21, they added "no matter what mode you fly" to the first sentence in Step 2: Enhanced Failed-Safe Methods.
This clarifies that enhanced failsafe works in Manual, Atti, and GPS like all of us observed.
Old Feb 18, 2013, 12:54 PM
Altimat is offline
Find More Posts by Altimat
FPV Recon
Altimat's Avatar
United States, TX, Liberty Hill
Joined Nov 2005
Originally Posted by petaks01 View Post
Give up? X2 error tells me that you have something set up for input on the X2 channel but
not connected the lead from the RX or RX not sending data for the X2 channel.
Primary channels connected ok?
Sticks calibrated?
X1 & X2 assigned to what in the Assistant?
X1 & X2 assigned to what on your TX?
The error seems erroneous. When it is present there is no communication and I can check nothing. When its working everything is fine. I have X1,2 assigned to my rotary knobs on the 8FG. Left is cam tilt, right is gains.
Altimat is offline Find More Posts by Altimat
Old Feb 18, 2013, 04:15 PM
Hewco is offline
Find More Posts by Hewco
Canada, BC, Langley
Joined Feb 2013
Question
Without having to read every page, I was wondering, does anyone have advice on the naza qith gps on a F550 that holds relatively still in attitude mode, but when I turn to gps mode the unit starts to fly away from me ? Before anyone asks, yes the switch is configured correctly and I have calibrated it several times.
Hewco is offline Find More Posts by Hewco
Old Feb 18, 2013, 04:34 PM
Gloon is offline
Joined Sep 2012
That may be true for planes, but for helis, that fly only because of the motors that take the power from the main battery... not so sure. If the main battery fails, everyting goes down no matter how many other systems you have powered by different batteries.
Old Feb 18, 2013, 04:46 PM
Gloon is offline
Joined Sep 2012
Before taking off, have you waited for the red flashes to stop?
Old Feb 18, 2013, 04:59 PM
PeterGriffin is offline
Find More Posts by PeterGriffin
Joined Jan 2007
Shot in the dark from a Naza novice, but have you calibrated your compass recently? I had a similar issue and this seemed to help.
PeterGriffin is offline Find More Posts by PeterGriffin
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
