Old Feb 16, 2013, 08:22 PM
gromitvt10 is offline
Find More Posts by gromitvt10
gromitvt10's Avatar
United States, MD, Solomons
Joined Feb 2002
Help!!!
Originally Posted by Tahoe Ed View Post
Try changing the resolution on your screen.
Nope, that didn't work..What else ya got
gromitvt10 is offline Find More Posts by gromitvt10
Old Feb 16, 2013, 08:47 PM
rmorhan is offline
Find More Posts by rmorhan
rmorhan's Avatar
wasaga beach ont canada
Joined Jan 2004
gromit, have the same problem on my win 7 pc. my machine also did this on a flight sim, tried screen resolutions ect but no joy with the naza assistant or flight sim. just using my laptop for the naza till i find a solution. anyone else see this issue? any input appreciated...thanks..rob m
rmorhan is offline Find More Posts by rmorhan
Old Feb 16, 2013, 09:00 PM
HGT is offline
HGT
Find More Posts by HGT
HGT
United States, CO, Parker
Joined Jan 2013
Are there any pics of the inside of the DJI GPS, especially where the compass is mounted?
HGT is offline Find More Posts by HGT
Old Feb 17, 2013, 05:44 AM
isojed is offline
Find More Posts by isojed
Netherlands, ZH, Ridderkerk
Joined Aug 2010
timecop made some here.
isojed is offline Find More Posts by isojed
Old Feb 17, 2013, 06:30 AM
kristjane is offline
Find More Posts by kristjane
Have a nice day! Kristjan
kristjane's Avatar
Slovenia, Novo mesto, Šentjernej
Joined Jan 2006
Reinstall assistant.
kristjane is offline Find More Posts by kristjane
Old Feb 17, 2013, 07:31 AM
gromitvt10's Avatar
Joined Feb 2002
I got it to work, just had to change the screen font size to small. Thanks
Old Feb 17, 2013, 07:36 AM
gromitvt10's Avatar
Joined Feb 2002
I got it to work, just had to change the screen FONT size to small. Not the resolution. Mine was set to meduim but the Assistant box doesn't resize so the words got bigger but the box didn't. Its the simple things that bite me in the end
Old Feb 17, 2013, 09:24 AM
alty is offline
Find More Posts by alty
Joined Feb 2005
Any good folks out there ,know if the Naza-H can be reprogramed to be used in a quad Naza-M
Reason,no 500 hele no more
alty is offline Find More Posts by alty
Old Feb 17, 2013, 09:37 AM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Interesting question. My first response is no, but not knowing what differences are inside the box, who knows. Why not just sell the H and buy an M?
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Feb 17, 2013, 09:59 AM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
Originally Posted by jefbur View Post
One last question, I have an EagleTree GPS unit already on my quad. Will they conflict with each other if I add the NAZA GPS?
They shouldn't. They are independent systems and should have no effect on each other. I am running that configuration and don't have any issues on my DJI F450.
thekubiaks is offline Find More Posts by thekubiaks
Old Feb 17, 2013, 10:16 AM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
I have one on my F450 with GPS and have no issues. The Naza GPS is mounted on the left rear arm and the ET GPS is mounted on the right front arm. The eLogger and OSD Pro are on the top plate on either side of the lipo.
Site Sponsor
Old Feb 17, 2013, 01:54 PM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
Gimbal
What Frequency should the gimbal be set for. Is it the frequency of the servo driving the gimbal? I went with the middle range for now, 200hz.
Eternalflight is offline Find More Posts by Eternalflight
Old Feb 17, 2013, 02:30 PM
Kenpilot is offline
Find More Posts by Kenpilot
Kenpilot's Avatar
Joined May 2006
PROBLEM with NAZA / F550
Hello Experts! :-)
I have been flying an F450 for quite a while now with no problems.
Just got a new F550 from Atlanta Hobbies with stock motors, stock 10" props, NAZA M running 3S 3600 batteries. Completed first hover tests over the last few days. First impression was that my battery is not lasting like it should - only got 3 minutes out of the first test before blinking red.
Make a long story short, after changing batteries, M5 would not spool up... it does turn but very slowly. I thought it might be a motor problem. I swapped M2 with M5 and swapped the props (duh should have swapped 1 with 5 but anyway....) Ran again and same thing, problem did not follow the motor but rather M5 ran slow after a 2 or 3 minute hover.
What do you all think, is this an ESC problem? All connections to MC checked, solder to M5 controller checked, all solid. When it flies correctly, it does hover well.
Thanks in advance. I know there is alot of collective experience out there to draw from here on RCGroups....
Kenpilot is offline Find More Posts by Kenpilot
Old Feb 17, 2013, 03:14 PM
rhokita is online now
Find More Posts by rhokita
gardena, ca
Joined Feb 2003
Hello friends! I just recently upgraded my scratch built quad from a multiwii FC to the naza FC. When I start up the quad (motor idle), only 2 (M1, M2) of the motors are running and once I advance the throttle to about 25% all the motors run and I can hover. I know that all of the motors are supposed to be running at idle and they had done so with the multiwii FC. Therefore it seems to me that the motor and ESC are OK. According to the Multiwii GUI, the motor idle is at 1150uS and the Naza GUI default idle is at 1176uS, so it seems to me that the motor idle speed should be even higher with the Naza FC. Any explanations or recommendations? I'm thinking about setting the Naza motor idle to the next step (1192uS). Incidently, my quad uses Turnigy 2213/22 motors and 25A ESCs with 10X4.7 props and a nano-tech 11.1V 5A/hr lipo. Flight times are short a minute?, but based on my telemetry, the battery is sagging below 10.8V at 25-30Amps in hover, so I think I have a battery issue here. Battery is rated 25-50C? Anyway, any words of wisdom for my motor idle problem is greatly appreciated!
rhokita is online now Find More Posts by rhokita
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
i'm running stock F550 with this battery and i get 8-9 minutes flight time. What's the C rating on that battery of yours?
edit: sorry this was meant for kenpilot
CrashAffinity is offline Find More Posts by CrashAffinity
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
