Old Jan 23, 2013, 12:27 PM
The Devil Is In The Details...
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Next
Originally Posted by Testflight View Post
Thanks for your reply.. Yes GPS has been calibrated several times, don't believe there is any interference, it's well away from ESC, Battery, motors and camera however it is right next to the PMU module, will try and take a photo later..
And there's no FPV gear fitted
Is it balanced?
What is AUW?
Like MC said, we don't know your airframe.
You could be trying to fly a 2x4. (surprised someone hasn't tried)
We only know you're using Naza + GPS...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jan 23, 2013, 12:37 PM
I never finish anyth
United States, TX, Houston
Joined Jan 2012
If you have a TBS Disco... we know what is causing the YAW
MCrites is offline Find More Posts by MCrites
Old Jan 23, 2013, 12:41 PM
Have a nice day! Kristjan
kristjane's Avatar
Slovenija
Joined Jan 2006
Originally Posted by luisgcu View Post
This is the story of my DJI NAZA GPS, that felt into the water in a lake at 2.5m deep, the cause that I suspect, was a failure of one ESC, one friend jump into the deep of the water and he saw the led still blinking so he take out, incredible he take out and still 2 motor where running.. the following hardware was attached.
1-Gopro2 : dead... still in warranty.. so not big deal
2-Frsky rx w Telemetry: seems to be ok, I have to test at long distance.
3-E-OSD W GPS. not tested
4- 5.8ghz video TX. I am surprised that at least I have some RF out, I have to put video to see if its fully functional.
5-DJI 30A ESC. seems to be OK, I have to put new heat shrink, and test for long time to check for failures.
6-DJI naza controller: Seems to be ok, I have to do a test flight to make sure is fully operational.
7-DJI naza power-supply : OK But USB is not working, have to buy a new one.
8- 800kv tiger motor : Ok after drying and some good lubricant.
9-GPS DJI NAZA: I'll have to test it.
You can save almost all. I lost my model and after 5 months I got it back in my hands. Just open all and dry it on radiator os something that produces heat around 50-60°C and left it for two days at least. Mybe you will have to change microphone in go pro, but naza should work. I saved almost all gear from fpv model that way, only wideo link works strange and fpv camera, but I have to test them separate to see where is problem. now all components fly with dji clone frame. I wrote to DJI about my advanture and they were out of words...
http://kads-world.com/KADS_World/Blo...Dominator.html
kristjane is offline Find More Posts by kristjane
Old Jan 23, 2013, 12:54 PM
Testflight's Avatar
Joined Nov 2012
Lol..That's the one I sold complete with Naza and GPS and that one flew perfect!!!! What causes YAW on them?? Maybe I can look in to it on the one I have now... Unless you say because of the arms on the TBS as these ones are metal.
Testflight is offline Find More Posts by Testflight
Old Jan 23, 2013, 12:59 PM
Testflight's Avatar
Joined Nov 2012
Originally Posted by T J Gilbert View Post
Is it balanced? Not sure this would have any effect on YAW if it was or wasn't??
What is AUW? About 3kg
Like MC said, we don't know your airframe. Ecilop
You could be trying to fly a 2x4. (surprised someone hasn't tried) Just a quad running 4 x Avroto M2814-11S with 11x5 Graupners (balanced) on 4s
Answers in RED
Old Jan 23, 2013, 01:10 PM
Habitual Line Stepper
Cervanchez's Avatar
United States, CA, Orange
Joined Dec 2011
Damn, missed the fun. I hate when a post or video is pulled and all I get to see is the reaction.
Cervanchez is offline Find More Posts by Cervanchez
Old Jan 23, 2013, 01:17 PM
Southampton, Ontario CA
Joined Feb 2005
Originally Posted by ralfrcgroups View Post
I own an EZOSD but never thought about the Tracking ability...
Give me a hint: what is an iDevice and iTelemetry? iPad/Phone?
ipad,pod or phone. You need an adapter, for the audio out from your vrx, to your idevice. http://www.nghobbies.com/cart/index....roducts_id=395
The app is free and will work right away. It will also record your flight and will display it on google earth. Sorry for the off topic.
Buffythesaint is offline Find More Posts by Buffythesaint
Old Jan 23, 2013, 01:29 PM
Joined Feb 2009
Back At You...
Is it balanced? Not sure this would have any effect on YAW if it was or wasn't?? With that frame, I'm not sure how you'd balance it!
What is AUW? About 3kg >6lbs!
Like MC said, we don't know your airframe. Ecilop I've no experience with your unusual frame.
You could be trying to fly a 2x4. (surprised someone hasn't tried) Just a quad running 4 x Avroto M2814-11S with 11x5 Graupners (balanced) on 4s I might could be more help with a 2x4! A quick glance at motor specs says max thrust = 60 oz on 4S. You're probably okay with enough lifting power!
Answers in RED
Answers in BLUE
I'm afraid that your problems lie in the unconventional frame.
And that's not "just a quad".
Perhaps the best place to ask questions would be @ Ecilops manufacturer...
Old Jan 23, 2013, 02:28 PM
3D Flash Mob Member
mark_q's Avatar
United States, WA, Kent
Joined Sep 2003
Hi, I'm after a little advice.. I've got a new Naza and GPS (sold my last one as a complete package with a quad) But am experiencing a couple of things I've not had before.. The 1st is I get a constant yaw to the left as if a few clicks of trim had been added, but they haven't been..
The 2nd thing is I'm getting a bobbing up and down, this doesn't appear to be all the time and has got a lot better since turning the gains up for the vertical but it's still there.. Has anyone got any suggestions? Thanks
For the yaw - Motor alignment? (it matters!)
(BTW MC, my TBS Disco has no yaw issue, have I done something wrong? )
mark_q is offline Find More Posts by mark_q
Latest blog entry: TESTING! 9x6 Props for Penguin
Old Jan 23, 2013, 02:38 PM
Denmark, Central Denmark Region, Karup
Joined Aug 2012
Im building me an FPV quad, should i have problems using this frame with naza gps
http://www.hobbyking.com/hobbyking/s...ter_Frame.html
and where should Mc be mounted should i draw a line from motor 1-3 and 2-4 and where they cross the mc should be placed?
vartaz is offline Find More Posts by vartaz
Old Jan 23, 2013, 03:04 PM
Joined Feb 2009
HK Frame
I don't think you'll have any problems.
The frame is a variation of a flamewheel copy.
Put the MC where you are suggesting (intersection of 1-3 and 2-4 lines) on the middle frame to protect it.
Distasteful ad...
Never did like the dead cat quadcopter junk.
Old Jan 23, 2013, 03:15 PM
FixedWing172's Avatar
NJ
Joined Oct 2007
Hi, I'm after a little advice.. I've got a new Naza and GPS But am experiencing a couple of things I've not had before.. The 2nd thing is I'm getting a bobbing up and down, this doesn't appear to be all the time and has got a lot better since turning the gains up for the vertical but it's still there.. Has anyone got any suggestions? Thanks
It has already been suggested but I want to reiterate that putting black electrical tape on the LEFT side of the Naza controller should help your problem. Apparently direct sunlight will affect the vertical stability and the tape will fix the problem, it worked for me.
To test this, hover your quad preferably in the late day sun when there are distinct shadows on the ground. First hover while the left side of the Naza is in the shade, now yaw the quad until the left side of the Naza is in direct sunlight. You should see a sharp climb or descent which will get better when you yaw back into the shade.
Let us know if this helps as your experience will help someone else
FixedWing172 is offline Find More Posts by FixedWing172
Old Jan 23, 2013, 03:33 PM
Joined Aug 2012
Distasteful ad...
Sounds very good :-) i will try that, just thought about the that the X formation is not is line as the front arms are further apart then the rear.
No, idiots at hobbyking - you saw that moron with his deadcat video?
Old Jan 23, 2013, 03:35 PM
Joined Feb 2009
+1 to FixedWing172
If he's configured his quad like the Ecilops website pictures it, his FC is exposed to light.
At least he can start with tape on the FC.
Maybe that will cure some of his issues.
With the Camera and Battery on a pendulum, he's probably got more worries...
Old Jan 23, 2013, 03:47 PM
Joined Feb 2009
Not a True X
I noticed that X formation.
That's why I said do the 1-3 2-4 thing.
It should get you closer to the center of the rotor plane. (lift center)
To get it perfect, you'll need to do vector diagram of the frame to find the true center of force.
My gut tells me its where the lines intersect, but not positive.
And once you start adding things (camera, battery, etc) the asymmetrical frame might make the COG shift forwards or backwards.
Keeping the lift center and the load center close to each other may be difficult.
The longer moment arms that the two front motors enjoy may help compensate...
This may be one where you have to count on the FC to correct for the imbalance.
Dr. Kallend: What do you think?
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 216 May 04, 2013 06:03 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
