Old Jun 16, 2012, 02:23 PM
UniversalRC is offline
Find More Posts by UniversalRC
UniversalRC's Avatar
United States, OH, Fremont
Joined Dec 2001
Finally got to do a quick test with the GPS. Had a light breeze but it holds better than I thought, running the height up and down to see if it moved much. As soon as I get it dialed in I'll try RTH.
GPS Test 1.mp4 (7 min 11 sec)
UniversalRC is offline Find More Posts by UniversalRC
Site Sponsor
Old Jun 16, 2012, 02:34 PM
blade strike is offline
Find More Posts by blade strike
Free Bird
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Originally Posted by chuenwe View Post
I have a DX8. I have enough 3 position switches. I don't use the throttle hold for that purpose.
Yes I have same radio. Thought you were using throttle hold to activate your fail safe. If so please make sure it is set to 20% throttle. This will make sure motors do not shutoff in the air!
blade strike is offline Find More Posts by blade strike
Latest blog entry: Yunees Q500 4k
Old Jun 16, 2012, 02:35 PM
chuenwe is offline
Find More Posts by chuenwe
chuenwe's Avatar
United States, NY, Huntington Station
Joined May 2012
I am now. See few posts above.
Thanks for the reminder to set Throttle curve to above 15%. I almost missed it as well.
chuenwe is offline Find More Posts by chuenwe
Old Jun 16, 2012, 02:45 PM
Free Bird
Joined Jan 2006
Originally Posted by G-unit View Post
Thats cool, I need to figure out how to do that with my TX, its a 9-C so it is probable easy to do...
I did this walk through, maybe you can use the steps for the 9c.
http://www.rcgroups.com/forums/showp...&postcount=707
Old Jun 16, 2012, 02:54 PM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
I will take a look Thanks!!
Just did another test, lowered my V- gain to 120% and i had some heli LG on it, it still did it but not as bad, I had my TX in hand and switch it on before something bad happened, but it was much better this time...
G-unit is offline Find More Posts by G-unit
Old Jun 16, 2012, 02:56 PM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
Just read your post and that is quite ingenious to use Flight mode along with pitch curve to set different Control Mode! I'm going to do the same and I can free up my Gyro channel to control something else! Thanks for the tips!
G-unit is offline
G-unit's Avatar
AZ
Joined May 2006
Well i need to "BOUNCE" to the store now, so i will do more testing when i get home....
Old Jun 16, 2012, 04:03 PM
Capello1986 is offline
Find More Posts by Capello1986
Joined May 2011
Ok am sorry in advance but am still having an issue, I can now get my hex naza to enter fail safe by using the throttle hold and did the "preset bind" to save the transmitter settings with failsafe set but when I turn my transmitter off all it does on the DJI program is move my throttle to about 20-30% and stays in the mode I turned the transmitter off at, not failsafe.
Anyone send me in the right direction, recap
P1 Man
P2 Alt
P3 GPS
TH Failsafe.
Martin
Capello1986 is offline Find More Posts by Capello1986
Old Jun 16, 2012, 04:06 PM
shlomi4046 is offline
Find More Posts by shlomi4046
ישראל, תל אביב יפו
Joined May 2011
TEAM -ZION Sunset (3 min 21 sec)
shlomi4046 is offline Find More Posts by shlomi4046
Old Jun 16, 2012, 04:12 PM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
Martin
To get it to the failsafe region, you have to bind your TX/RX by sending that signal to NAZA. Do you know how to bind your TX/RX for failsafe?
Old Jun 16, 2012, 04:21 PM
Free Bird
Joined Jan 2006
I would try at 100..
Old Jun 16, 2012, 04:22 PM
goebish is offline
Find More Posts by goebish
I Void Warranties
goebish's Avatar
France, Aquitaine, Bordeaux
Joined Feb 2010
@Martin: or maybe your RX support FailSafe on the Throttle channel only (AR6000, OrangeRX 6Ch...).
goebish is offline Find More Posts by goebish
Joined May 2011
Yeah I thought it was turn on Receiver with bind plug installed, both leds should flash (one of receiver and one of Sat). Remove bind plug and set transmitter with switch layout which sets failsafe. Turn on Transmitter with bind button pushed until leds stop flashing and become solid.
I did the above but like I said when I turn off the transmitter the Naza only shows in the throttle setting of the throttle hold. Am I doing this wrong?
Old Jun 16, 2012, 04:27 PM
Free Bird
Joined Jan 2006
P1 Man
P2 Alt
P3 GPS
TH Failsafe.
Martin
You must bind predetermined failsafe now.. You need a ar7000 rx with data/batt port or higher..
Power the rx with bind plug, now remove bind plug. Lights should still be blinking.
Now power your tx with throttle hold ON and pressing the bind.
Now recycle power and check again in the software. All stick should center and U channel should show fail safe
Old Jun 16, 2012, 04:28 PM
Free Bird
Joined Jan 2006
just saw your post.. what rx do you have?
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 05:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 05:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 09:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 02:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 06:01 PM
