Old Dec 08, 2012, 08:13 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by Bill Glover View Post
The Naza can't run the motors below that power setting. Your setup won't be efficient if it's almost hovering with the motors at slow idle anyway, so you have a fundamental problem and need to make some changes.
Agreed, you are grossly overpowered if your copter is taking off at the lowest idle setting. If you are having these sort of issues the most logical thing to do would be to simply add a 2nd 5S lipo. It should give you enough weight to keep you on the ground and also you'll see the benefits since your copter clearly has the power reserve to fly it.
If you don't want to try that you can recalibrate your ESCs with about 5-8 clicks of up trim on your throttle. That will tell your ESCs that the higher pulse from the Naza is actually a lower throttle setting in reality. So before 1150us pulse would essentially be 15% motor speed for example, where now calibrating with uptrim could make it 5% motor speed.
You'll lose throttle range but it might give you a slower rotation to not worry about take off.
Sid3ways is offline Find More Posts by Sid3ways
Old Dec 08, 2012, 08:36 AM
crash8384 is offline
Find More Posts by crash8384
crash8384's Avatar
United States, OK, Erick
Joined Aug 2011
Originally Posted by Maxedout View Post
This might raise some eyebrows, is there anyway of reducing the motor idle speed below the min setting in NAZA assistant ?. My DIY hex is trying to hover at the lowest idle setting which clearly isn't ideal. Is there some sneaky way of lowering the idle speed that someones come across ?
Yes, reducing the prop size will get around this vexing problem, but then I'm already running smaller props than optimal for the motor combo, dropping down to 4s batts from 5s will also help but again this will decrease the efficiency of the power system. A way of programming in a more controllable throttle curve to suit the power system is what I'm looking for if anyones got any suggestions.
Just read you post regarding idle speed. Have seen this quite often with old simonk firmware or an incorrect fw match to esc. To resolve this issue reflash escs to newest fw. Apropriate for esc. Make sure that you dont flash wrong fw or esc will be dammeged with a lipo plugged in. AlwYs test newly flashed esc with a 4.8 rx batt first.
Fwiw .......this has happened to me a few times and is not limited naza.. a simple lookup at the wiki rapidesc data base will show info regarding most common or like escs.
I bought a few newly flashed escs from ppl online and this happened. I simply found correct simonk fw file and reflashed and alls good. Theres a 99%chance this is the case. Pm me for more info and i would be willing to help you anytime .
Steve
crash8384 is offline Find More Posts by crash8384
Old Dec 08, 2012, 01:37 PM
panos2408 is offline
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Hello,
I am facing a rather strange problem with my Gimbal outputs. F1 output will not move the servo which is already passing through another gyro. (Ecilop style gimbal) If i connect it to port F2 it works ok. My reciever has 7 channels. first for are the basic A E T R the fith goes on the U 6 channel goes on X1 and 7 channel on X2. X3 port is occupied by the Naza Ubec.
Am I doing anything wrong here?
panos2408 is offline Find More Posts by panos2408
Old Dec 08, 2012, 01:40 PM
Maxedout is offline
Find More Posts by Maxedout
Maxedout's Avatar
New Zealand
Joined Dec 2011
Yea, looks like I built it to light !
Maxedout is offline Find More Posts by Maxedout
Old Dec 08, 2012, 01:45 PM
Maxedout is offline
Maxedout's Avatar
New Zealand
Joined Dec 2011
Originally Posted by T J Gilbert View Post
You have not told us much about your set-up other than it's probably large because you're running 5S.
That being said, you're probably not running DJI ESCs.
Have you calibrated your ESCs?
I'm running Dualsky ESC's and have calibrated them, but maybe they aren't that compatible with the NAZA.
Thanks for the other suggestions folks, I'll give them a try and let you know what happens.
Jim
Old Dec 09, 2012, 12:01 AM
Maxedout is offline
Maxedout's Avatar
New Zealand
Joined Dec 2011
It's already got two 5s lipo's strapped to it & increasing the throttle trim just exacerbated the problem. Dropping down to 13' props from 15" didn't help so I strapped 2kgs of lead to it, that did the trick, but clearly not a suitable solution.
Re-flashing the ESC's with a suitable fw looks like what's needed.
Old Dec 09, 2012, 10:12 AM
AliB is offline
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
if i fly around in atti mode, with throttle lock on 50%, should it hold the same altitude?
or does this only work while hovering?
mine always seems to decend as i start going forward.
AliB is offline Find More Posts by AliB
Old Dec 09, 2012, 10:44 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Try upping your Atti gains 10%. If it gets better go up more till it gets worse or makes other negative changes to the way it flies. If it gets worse the drop it 10% from its current numbers.
You should expect a little change esp when in prop wash. If you are getting a big change in altitude the put a piece of black elec tape on the side of the Naza. It's barometer is sensitive to light and this sometimes helps
MCrites is offline Find More Posts by MCrites
Old Dec 09, 2012, 12:18 PM
mikemijal is offline
Find More Posts by mikemijal
Westland Michigan.
Joined Jan 2012
Originally Posted by zokizo View Post
F1 and F2 its for 2-axis gimbal but it is possible to make some mixes and when you click switch that you have manual movement of your gimbal?? (that i control camera )
and question no 2
when i wanna set new home point do i need to switch few times fast from HOME LOCK to COURSE LOCK or
from HOME LOCK to OFF or COURSE LOCK to OFF
Regarding the Gimbal. I think this guy on YouTube has what your looking for because I'm looking for the same thing... http://www.youtube.com/watch?feature...&v=IhxHZd-dhQs
mikemijal is offline Find More Posts by mikemijal
Old Dec 09, 2012, 01:01 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Drop it to 4S. 5S is only more efficient if you are running in the sweet spot of the motor and the ESC as a system. Idle is not the sweet spot which is, as a rule of thumb, 40% - 50% of max current. So 4S will be far more efficient and controllable running where it is happy than 5S struggling to control near idle.
Pictures and specs would be cool!
mark_q is online now Find More Posts by mark_q
Latest blog entry: X-UAV Mini Talon #2
Old Dec 09, 2012, 02:27 PM
Socratic is offline
Find More Posts by Socratic
United States, NH, Barrington
Joined Sep 2011
Naza - Strange behavior? Or not?
Been a while since I took out the Naza/Hex -so went to practice some FPV. Everything seemed okay, then the hex started acting very strange. Wasn't descending very quickly but started jerking around (around 2:40 in the video). Mode was GPS/Atti. Maybe need to lower roll a bit though not sure why it would have happened all of a sudden. ??
FPV with Naza and GoPro (4 min 16 sec)
Socratic is offline Find More Posts by Socratic
Old Dec 09, 2012, 03:30 PM
bobthenuke is offline
Find More Posts by bobthenuke
70 is the new 50
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
Clear Air Turbulence? Some conditions will allow this to "hang around" for a remarkably long time. I noticed that when you dropped below tree level it smoothed out.
Just a guess
bobthenuke is offline Find More Posts by bobthenuke
Old Dec 09, 2012, 03:35 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I've had that happen.
One thing that seems to be comforting, is that it does not flip like the Wookong.
(I have personally witnessed a Wookong flip, and it is frightening)
The thing about this glitch, is that the copter can fight you, and you wonder if you will be able to get it back.
It only happens a very small percentage of the time, but it is enough to make you so that you cannot completely trust it.
The rest of the time it seems to be fine.
One thing that I started doing, and I noticed others are doing, is to plug it in, and get a good gps fix, and then unplug it, and do it again before flight.
That seems to help.
http://youtu.be/3zbXTQTb_us
m_beeson is offline Find More Posts by m_beeson
Old Dec 09, 2012, 06:18 PM
Socratic is offline
Joined Sep 2011
That seems to help.
I have to admit that I did not have a full Sat Lock before taking off - still had one slow red. Lots of trees and hill side here that blocks full sat coverage. Maybe that causes this behavior. Though, it should have locked onto all sats way before the wobble happened (I would think)? In any case, I will try in an open field soon and try your plug, unplug and plug process and see if all is well. I must say, overall, I have really liked the Naza. Easy to setup and easy to fly and very stable (usually).
Old Dec 09, 2012, 06:32 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
I often wonder about the hills and trees affect. My local field is in a "hole" with big hills all around and huge thick trees. I'd like to see some way to upgrade to a better antenna for Naza because the annoying thing for me now is Naza doesn't always get full lock but my Quadrino quad with the new Quadrino GPS typically gets at least 9 sats and very often 11 and very quickly. I've tried dis-abling the Vtx and camera and left the GoPro turned off to see if that helps but it doesn't seem to make a big difference.
Anyone heard of an antenna upgrade for Naza?
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
