Old Nov 17, 2012, 11:29 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Originally Posted by QUAD4EVER View Post
Regarding the metal duct tape (Reflectix Insulation tape) -
It doesn't block radio signal.
I had the same idea of using the metal tape. But, I performed a simple test first. I wrapped my cell phone with a layer of cooking aluminuim foil and tried to call my phone. The phone started ringing. Tried two layers of cooking aluminuim foil and the phone could not recieve a signal when I tried to call the phone.
Next, wrapped the phone with a single layer of the metal duct tape. Call the phone and it ringed. Crap. The metal duct tape is a lot thicker than the cooking aluminuim foil. I would estimate that the metal duct tape is the same thickness as three layers of cooking aluminuim foil.
Tried a double wrap of the metal duct tape. This is approx same thickness as 6 layers of cooking aluminuim foil (I estimate). The phone ringed. So, I decided that the metal duct tape is a FAIL for interefernce protection.
Awesome test, thanks
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Nov 18, 2012, 12:07 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
What about adhesive copper foil tape?
Allot of music shops sell it so you can shield the back of guitar pickups makes for a cleamer sound.
i bought some from amazon
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
im sure copper would work better than aluminium foil
Ben
Borneoben is offline Find More Posts by Borneoben
Old Nov 19, 2012, 08:39 PM
mikemijal is offline
Find More Posts by mikemijal
Westland Michigan.
Joined Jan 2012
Originally Posted by yosemitez View Post
just make a shield out of aluminum foil and duct tape. my gps is about 2" away from the gopro and i get full lock. you can see the tray the gopro goes on right in front of the rubber bands.
i also have all the gps mounting on velcro per another persons suggestion and it works fine. i can easily adjust to get rid of toilet bowl
I was curious if the GPS was any more or less sensitive to the GoPro 3 than the GoPro 2? Or are they about the same.
mikemijal is offline Find More Posts by mikemijal
Old Nov 19, 2012, 10:22 PM
yosemitez is offline
Find More Posts by yosemitez
yosemitez's Avatar
United States, CA
Joined Nov 2010
Seemed about the same, each would cause loss of GPS signal when in close proximity to the antenna
yosemitez is offline Find More Posts by yosemitez
Old Nov 20, 2012, 07:29 AM
labcopilot is offline
Find More Posts by labcopilot
labcopilot's Avatar
United States, OH, Cincinnati
Joined Aug 2011
Testing out the new green vibration pad from vibrationmounts.com. I went from horrible jello-filled 1080p using earplugs to crystal clear 1080p using the green vibration dampening pad. These things are expensive but worth every penny (especially if you have a friend that is willing to split the cost with you).
FPV - At the Park / TBS Discovery (3 min 0 sec)
labcopilot is offline Find More Posts by labcopilot
Old Nov 20, 2012, 07:44 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
I've had success with fairly inexpensive dubro foam rubber from the LHS. Here's some of my footage from over the weekend.
New Park Adventures (3 min 30 sec)
Cervanchez is offline Find More Posts by Cervanchez
Old Nov 20, 2012, 07:57 AM
labcopilot's Avatar
Joined Aug 2011
https://www.youtube.com/watch?v=8iFw...e_gdata_player
Looks good. And a hell of a lot cheaper than the green vibration pad. May have to pick some of that up for the frakenquad I'm going to build this winter.
Old Nov 20, 2012, 08:55 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
http://www.youtube.com/watch?v=PixAwTktptc
Do you mean this one? You weren't kidding about the cost but the video looks great. I've had pretty good luck using the foam earplug method... it's not perfect but it drastically reduces the vibration.
**edit** I've also tried Moon Gel but didn't have much luck with it.
Mike_Then is online now Find More Posts by Mike_Then
Old Nov 20, 2012, 09:04 AM
labcopilot's Avatar
Joined Aug 2011
Actually , this is the one I use. The web page shows a blue one but the bottom of the page gives you different options. The green one is supposedly tuned to the types of vibrations produced by motors in the 900 kv range. $90 is steep though. The pad is big enough for 2 gopro cameras though so you could split the cost with a friend.
http://www.vibrationmounts.com/RFQ/VM08009.htm
Old Nov 20, 2012, 09:09 AM
lakis21 is offline
Find More Posts by lakis21
lakis21's Avatar
Greece, Makedonia Thraki, Nikiti
Joined Dec 2006
Hello,
does anybody now if there is replacement part, the top cover of the Naza GPS. After a serius crash , by a mistake I did, Destroyed many things in my f550. The top cover is Scratched ... and I like to change it... if anybody knows something let me know!
Regards to everyone
lakis21 is offline Find More Posts by lakis21
Old Nov 20, 2012, 09:16 AM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Originally Posted by lakis21 View Post
Hello,
Regards to everyone
If it still works, sand the scratches and paint it. I do not think you will be able to find a replacement unless someone has one that is dead.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Nov 20, 2012, 09:34 AM
Mike_Then's Avatar
Joined Apr 2001
I was going to say... the scratch shouldn't affect the operation, correct? If it works, the scratch is cosmetic. But if that's not good enough, then yeah, sand it down and paint it. I'm not aware of just the cover for the puck being available for purchase.
Latest blog entry: F-14 resurrection
Old Nov 20, 2012, 09:42 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Battle Scars
As long as they don't look like my cat chewed them, I like to leave my dents, dings, scratches as is.
The airframe looks like it's well broken in, and not babied.
The white finish on My GPS has the black plastic showing through in a couple of spots.
A nice, shiny, new looking rig is nice, but it won't stay that way long if you plan to fly it.
T J Gilbert is online now Find More Posts by T J Gilbert
Old Nov 20, 2012, 09:55 AM
lakis21 is offline
lakis21's Avatar
Joined Dec 2006
Ok I have a question, if I connect ony naza + gps + receiver, without out any esc on the naza, and I go out. If I will open it on gps mode, can it lock the satellites and light green? because I see 3 reds one Green...
Is there anyway to check the gps module if it is ok with out frame?
Old Nov 20, 2012, 10:13 AM
Empire Support
Joined Feb 2009
GPS Test
Based on testing I recently did trying to debug a new Naza (which turned out to be bad), I'd say you're fine testing without ESCs connected.
You're getting communication since you see 3 reds & 1 green LED flash.
I'd try another location to test GPS.
Remember that you pretty much need open sky above and around your test site.
Finding GPS satellites won't happen if conditions are marginal.
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
