Old Nov 15, 2012, 10:07 PM
cooperd is offline
Find More Posts by cooperd
Joined Feb 2006
It's my understanding only the 7010 and above will support the proper failsafe for the Naza to function properly. And to engage that failsafe the operator must power up the rx with the bind plug installed and then REMOVE the bind plug, and then power up the TX in bind mode.
cooperd is offline Find More Posts by cooperd
Old Nov 15, 2012, 10:22 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
You are correct. However, you must have the mode in failsafe, the sticks centered and the throttle above 10%. With the throttle, you have to move the end point not the throttle stick.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Nov 15, 2012, 10:28 PM
cooperd is offline
Joined Feb 2006
RIGHT! That is the important part!
Old Nov 15, 2012, 10:44 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Originally Posted by cooperd View Post
I have a Gaui 300x and a DJI Flamewheel 450 with Naza/GPS using DX8 with AR8000 and AR7010 rx's. I have performed well over a dozen RTH's! Some initiated by shutting of the TX others with a programmed switch. I have aborted some in the middle of execution just to see if I could and allowed the rest to land. I have NEVER encountered a problem with the RTH function in either installation. I have flown the Flamewheel over 50 full battery cycle flights and the Gaui over 20. They both have alway flown flawlessly.
I have a friend with a Flamewheel 450 controlled with a Futaba FASST setup, he routinely shuts off his TX to perform RTH, also flawlessly.
Just reporting my experience, yours may very!
While I am glad to hear of you and your friends successes with RTH, I would respectfully request you stop, really think about what it is you are doing and understand it could and likely will at some point become extremely dangerous. It makes no difference you have never encountered a problem. Please understand, when you turn off your transmitter your are giving up 100% of your control to a system which is not designed to fly reliably as an autonomous aircraft. RTH is not a flight mode designed for normal flight, it is provided to accomodate a potential emergency situation.
This aircraft is built from consumer grade components and it is designed to be flown by a human being, start to finish. Understand too, there are many component and system variables such as connector quality, temperature, pressure, battery quality, radio components, programming, etc. which must perform perfectly for this to be successful. One of them will fail at some point.
In a nutshell, when you turn off your transmitter, you are endangering yourself, the people who maybe nearby and the very hobby we all enjoy so much. Will your quad, while flying in RTH mode be the one which falls out of the sky and causes a severe injury to a friend , neighbor or young child? Will you tell them it wasn't your fault because you were not in control of your aircraft?
Again, please, think about what you are doing and what you are risking and fly more responsibly.
Thanks for your time - Mark
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Nov 15, 2012, 10:46 PM
ehx is offline
ehx
Find More Posts by ehx
ehx
Northern Minnesota
Joined Oct 2001
Rth?
The people that don't even want to test the RTH function should probably consider just disabling it. You never really know it is working until you actually try it. The NAZA is pretty simple compared to most autopilots, but there are still a lot of variables involved. Different transmitters, receivers, etc. not to mention a manual translated from another language for most users here.
Obviously you can test first with the Assistant software. If you really want to be careful you can then tie your copter down, maybe remove the props, power up, go to failsafe, and then quickly try to regain control so you can be sure how that works. If things don't go as expected just disconnect the copter's battery.
Eventually though you just have to do it for real.
As for NAZA RTH failures, it's probably just like anything involving humans. Most are likely "pilot error". But with untold thousands of NAZA RTH activations by now it certainly quite possible (probable) that hardware and/or software failures are to blame for some.
My first test of RTH was a failure. Upon turning off the transmitter my F330 immediately rose to ~20 meters, stopped, rotated to face me, and then took off in the exact opposite direction of what should have been home. Maybe it was going around the long way . Turning on the transmitter and toggling the flight mode eventually got it back under control. What if that didn't work? Well this was a remote area. The possibility of it doing any damage was essentially zero.
After that I went through the setup and manual again, couldn't find anything that I should do differently, and eventually went out to try again. This time it worked as advertised. I've done it more than 30 times since. All worked fine.
Was the first failure user error? It's possible, but I don't think so. The interesting part of that test - besides flying off in the wrong direction - was the immediate rise to ~20 meters. Every test since has had the ~3 second hover before starting RTH. This makes me think the NAZA was confused on that flight. Any RTH test I've done has always been under ideal conditions.
Just because something can fail, perhaps from no fault of your own, doesn't mean you should avoid it. Manned aircraft crash every day. Most people still fly. A few don't. Maybe in the context of the NAZA those type of people should just not set up RTH. For the rest of us do your homework and test it out. It's going to work fine almost always once you have it set up correctly. Do keep in the back of your mind though that the NAZA can, perhaps on very rare occasions, fail just like any other component associated with your copter.
ehx is offline Find More Posts by ehx
MOTOSTEIN is offline
Find More Posts by MOTOSTEIN
Joined Sep 2011
some nice early morning beach footage before i lost my #1 bird!!! dammit!!! never fly witout a DVR like my dumbass did! lost it in my own hood!
1080P HI BEACH FLIGHT! CARLSBAD CA (4 min 30 sec)
MOTOSTEIN is offline Find More Posts by MOTOSTEIN
Old Nov 15, 2012, 11:43 PM
cooperd is offline
Joined Feb 2006
I'm speechless! Wow!
Old Nov 16, 2012, 12:36 AM
DaveyWavey is offline
Find More Posts by DaveyWavey
Joined Sep 2011
Really Mark? This is based on what? Not the Naza Manual forsure!
Firstly every multicopter on the planet is flying under total control of the flight controlller. The pilot is merely politely ask the quad to move in X direction, climb and/or decent.if that controller wants to hold your copter at 45 degrees and fly off it can happen at any time.
Secondly, RTH is basically a one waypoint mission. Is DJI waypoints (ok Wookong not Naza but hear me out) for emergency use only? Of course not. Hell even position hold is computationally the same as RTH, it's juat that "home" is where you're at. Is position hold for emergency use only? I think most would say no. Then you have the chances of pilot error versus code/gps error (variable at best)....
With respect, you don't seem to know enough about computingor real-world objective risk assessment to be making such bold sweeping claims.
DaveyWavey is offline Find More Posts by DaveyWavey
Old Nov 16, 2012, 05:46 AM
phil_w is offline
Find More Posts by phil_w
Joined Sep 2012
... I would respectfully request you stop, really think about what it is you are doing and understand it could and likely will at some point become extremely dangerous. ... Again, please, think about what you are doing and what you are risking and fly more responsibly.
Nonsense.
It's easy to safely test the failsafe. If you don't test it then it probably won't work.
phil_w is offline Find More Posts by phil_w
Old Nov 16, 2012, 05:48 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Originally Posted by phil_w View Post
Nonsense.
He wasn't saying to not test... just stop using it "dozens" of times.
MCrites is offline Find More Posts by MCrites
Old Nov 16, 2012, 06:13 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
[QUOTE]With all being said, would I trust Naza?
The answer is Really not much. Every time I take off, I say this in my head "Will this come back in one piece?"
QUOTE]
+1. Man, I have EXACTLY the same feeling. I have started flying FPV with my machines. I put the goggles on, and stare at the beautiful scenery all the while wondering ifwhen I will see an uncontrolled fall from grace.
u2builder is offline Find More Posts by u2builder
Old Nov 16, 2012, 06:23 AM
MCrites is offline
Joined Jan 2012
Thats every flight controller guys, not just Naza. There are dozens of ways that a multirotor can fail and the FC is only one of them. Honestly I feel that out of all of the FCs that do what I want one to do the Naza is miles ahead of the others.
Old Nov 16, 2012, 06:52 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
The microcontroller that is in charge of your car ABS brakes is probably cheaper than your Naza controller, yet, you drive every days without even thinking about it even if your life depend on it.... I agree with MCrites, like a car, there's so many parts that can fail, that worrying about only one is pointless.
RealGambler is offline Find More Posts by RealGambler
Old Nov 16, 2012, 07:04 AM
MCrites is offline
Joined Jan 2012
I don't have ABS. When given the option I never choose it because it actually increases your braking distance. I'd rather control my vehicle myself and steer around a crash. Anti-Lock Braking System should have been called Anti-Lock Steering System because it exists just to keep the wheels turning so you can steer. I guess though the acronym for Anti-Lock Steering System wasn't PC enough.
I guess I just trust me more than the machines in most everything. The same goes for the Govt...
Old Nov 16, 2012, 07:17 AM
ralfrcgroups is offline
Find More Posts by ralfrcgroups
ralfrcgroups's Avatar
Germany, NRW, Langenfeld
Joined Oct 2011
Originally Posted by MCrites View Post
steer around a crash....
Hopefully you will be able to do that with blocked wheels. Most people tend to kick their brake pedal too hard in case of an emergency, so that the wheels are blocking and there won't be any possibility of steering then - that's what ABS is for.... I've driven sportcars without ABS for many, many years and I really like What ABS can give you in case of an emergency ( same with NAZAs RTH :-) :-) )
ralfrcgroups is offline Find More Posts by ralfrcgroups
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
