naza, loss of gps signal on throttle up
i boot the naza up and after 30 secs or so i get the gps lock, one yellow flash in atti, one green in gps. as soon as i give it throttle both go to 1 yellow + 2 red, 1 green + 2 red. when i land and throttle is off both go back to full lock.
could this be some kind of interference from the esc's? i have it mounted on a mast away from the camera which was also causing loss of gps |
Latest blog entry: TESTING! 9x6 Props for Penguin
thanks, the camera a nex 5n will cause the gps to go from 1 green to 1 green and 2 red when turned on. the gopro 2 will cause it to go from 1 green to 1 green + 3 red when turned on. it is a known issue with gopro 2 and i built a shield out of aluminum foil that goes around the gopro that solved that problem.
moved the gps from the front mount on frame to mast mount as seen i photo. i think i solved the loss of gps by moving the gps wire up on the upper part of the frame away from the wires feeding into the naza. does anyone know what 2 rapid green or orange flashes mean when flying? boot up naza and get solid gps lock, 1 green flash and when i take off i start to get 2 rapid green flashes. when throttle is center it goes back to 1 green flash. same in atti 1 orange then when flying it goes to 2 rapid orange flashes until throttle is centered. is this normal? |
Do your homework...
2 flashes = sticks not centered 1 flash = sticks centered (including throttle) Better read your manual more... ![]() It's on page 39. |
Trims & Subtrims
If your transmitter is not damaged, zero trims and subtrims should show your sticks centered on your transmitter's monitor as well as the Naza Assistant. BTW, this does not apply to switch channels. You may need to use subtrims to get 3 pos switches to respond correctly. I've recently answered a post about trims, so some explanation is not too far back. http://www.rcgroups.com/forums/showp...postcount=6143 There's some more on my blog about Naza trims. They mean "flasing" or "blinking" when they say "sparking". It's a Chinese to English translation thing...
Joined Feb 2012
But I've always read that you should keep ESCs as close as possible to the battery and not increase the length of wire running from the power source to the ESCs. Have you had any problems with that? |
Subtrims
I stopped fooling with all trims when, out of instinct, I used trims when I first started flying Naza. Things got all screwed up, and I had strange drift problems. That's when I was advised against trims and subtrims, and I've been passing that experience/advice on ever since. If you successfully are able to fly with subtrims used over a period of sessions, please post your success so that others may benefit... It may be that trims are taboo and subtrims work. Thanks! Be sure to proceed with a little caution here. If subtrims add like trims do each time Naza is powered up, soon your right stick will be trimmed to its max and CSC might not be recognized. Does the subtrim seem to stay set from power up to power up? Or do you find yourself needing to add more subtrim? |
TJ,
I use subtrims to center the stick in assistant. If you then change the subtrims again after you have successfully centered them in the assistant, then you will undo what you have achieved. So your first instinct was right. Quote:
This particular quad had two GPS antenna and a 1.5w Vtx @ 1.3Ghz so I wanted to push the Esc's out so they wouldn't mess with everything else and I got what I wanted, <30 sec to full lock on both GPS antennas and noise free video. If I had the time I would have moved the ESC's closer in to see where it might actually make a difference but I never did this and I have since dis-assembled this frame to build my TBS frame (which is awesome ). Oh and no, I did not crash the HT-FPV quad, it just didn't fit with what I was looking for.Mark |
| Thread Tools | |
| New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences | sap_2000 | Multirotor Talk | 216 | May 04, 2013 06:03 AM |
| Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news | Adidas4275 | Multirotor Talk | 195 | Sep 06, 2012 04:45 PM |
| Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller | skyhulk | Aircraft - Electric - Multirotor (FS/W) | 10 | Jul 20, 2012 08:47 PM |
| Question Question for Spektrum DX8/HF GPS owners | Wayno Complaino | Hoverfly Technologies | 13 | Jan 01, 2012 01:18 PM |
| Discussion Gps owner videos | jginsandiego | Hoverfly Technologies | 0 | Oct 04, 2011 05:01 PM |
