Old Nov 09, 2012, 04:44 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Originally Posted by windfou View Post
So i post also here, to see if some one can help me about this issue
my set up is FrSky D8R-II + stock 9x tx I just read a fews tread and the issue is not resolved and i don't want to try to fly the quad , i am very disapointed about this system already if I don't find the problem this week end monday this kit will be on sell for sure thanks everyone
Get rid of the cheap 9X and get a DX8i or JR module based radio or similar so you can keep using your frsky stuff. The turnigy radios are not user friendly one bit and you almost need a PhD to use them. I've found setting up my quads on either my DX8 or JR DSX9 very easy to do! And cause they are a common radio there is alot more knowledge on the in the forums and google searches.
Teamsherman is offline Find More Posts by Teamsherman
Old Nov 09, 2012, 05:16 PM
P  is offline
Find More Posts by P
Joined Aug 2008
I wish they can resolved the ppm issue
Whats the issue?
P  is offline Find More Posts by P
Old Nov 09, 2012, 05:20 PM
P  is offline
Joined Aug 2008
If you Flash your 9x with er9x or open9x you'll have a great radio.
Old Nov 09, 2012, 06:30 PM
Member #1
Joined Aug 2011
I tried that too with a smartie parts board and it still seemed like I needed a PhD in transmitter programming and that was just for basic 4 channel stuff! It did my head in so I bought a JR DSX9 and its been flawless. I only use my DX8 for my FPV long range stuff cause my rangelink UHF plugs straight into the trainer port.
Old Nov 09, 2012, 09:13 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Quick Question for you guys - I am seeing some new strange behavior with my NAZA - If while flying I quickly bump the the left or right alieron stick and let it spring back to center the quad will wobble out of control until it crashes - I am not compeletly letting go of the stick and letting it fall back to center just bumping it - Anyone else seen this? I am using a DX8 and Ar8000 rx - latest firmware on the NAZA as well -
cdi3d is offline Find More Posts by cdi3d
Old Nov 10, 2012, 01:30 AM
Member #1
Joined Aug 2011
Can someone suggest a nice smooth servo for a camera gimbal? My pitch servo is very jittery. Something HXT900 sized metal gear would be good.
Old Nov 10, 2012, 06:06 AM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Hi Mike, did you recently upgrade the firmeware or has it been flying well for some time and this behavior just started?? I hate hearing these stories, this is not the first time I have heard of this behavior. I am sitting on the fence with the firmware upgrade until I know it isn't buggy.
Please let me know what you find out on a solution....
power is offline Find More Posts by power
Old Nov 10, 2012, 07:22 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I am not seeing this with my quad or hex, both on the latest firmware. Both machines rapidily go back to stable orientation no matter how I bump the sticks. Both are stock motors and escs, with a bit extra weight for landing gear and cameras. Both are using the gains listed on page 41 of the latest manual for all settings.
u2builder is offline Find More Posts by u2builder
Old Nov 10, 2012, 07:53 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
This is the one I was looking at.
http://www.hobbyking.com/hobbyking/s...06sec_21g.html
I haven't progressed on the gimball though, because I ordered a QAV500
m_beeson is offline Find More Posts by m_beeson
Old Nov 10, 2012, 08:41 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Sounds like the gains are too high.
Bill Glover is offline Find More Posts by Bill Glover
Old Nov 10, 2012, 09:44 AM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Hey Bill - No problem with gains at all - I have run them high and low - both times it did the same thing- That was my first test Now I am finding another weird issue - I have one NAZA controller on 1.6 and one on 1.8 - The 1.8 works fine with my setup but the 1.6 firmware will not recognize my esc's - very strange -
Old Nov 10, 2012, 12:11 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Here are a couple bits to consider:
1. Of all the gear types, metal is the least precise and the noisiest. Metal is great on a 3D application because it is the most resistant to failure.
2. Karbonite (or Carbonite) is the most precise gear material and is quite strong, nylon the quietest.
3. Go for slower. You don't need a high speed servo (<.10s).
4. If you want smooth, try a high quality analog unit. Digital servos in the mini and micro size are jittery because they depend on being pre-loaded to quiet them down and they spend huge energy finding center!. So if your gimbal is near balanced at rest, the servos will jitter. Digitals can also be quite noisy (electrically).
5. Don't hard-stop your gimbal, set your endpoints to avoid overloading the servo.
Maybe give these a try:
Hitec HS55HB or HS65HB
Blue Bird BMS-373BB
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Nov 10, 2012, 12:56 PM
windfou is offline
Find More Posts by windfou
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
ok could you buy me dx8 ? my frysky module is more advance then a dx8 and why naza can even make working ? i build multirorotors since 2 years and i been using , fh-x46,kk board ,FF borard,hoverflypro , and never have any problem ,
why pay 400$ + another 400$ tx to make running this system lol!
windfou is offline Find More Posts by windfou
Old Nov 10, 2012, 01:16 PM
windfou is offline
windfou's Avatar
Joined Dec 2008
so anyway the quad is ready i put the setting to tradition with my frysky module
and look like it work , i dont have any error , but i want to know how to calibrate the compass but i don't use the gps for now ,
so i need to use the 3 way switch ? i never used these before so its around 30% for each mode? i use the acro mode and i don't have the pitch curve and some use it with heli mode but i already try but i can't start my motor .
Old Nov 10, 2012, 02:00 PM
power is offline
power's Avatar
Joined Apr 2003
From what I understand, Naza took care of the not recognizing third party ESC's with the 1.8 firmware. Try upgrading and see if it helps.
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
