Old Nov 07, 2012, 01:27 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
I have nothing around mine and never seen the problem.
MCrites is offline Find More Posts by MCrites
Old Nov 07, 2012, 01:45 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
+1
Me neither...
And, as I remember, TahoeEd could not duplicate the condition when he tested.
The fact remains that the baro is light sensitive.
Maybe some more than others...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Nov 07, 2012, 01:48 PM
MCrites is offline
Joined Jan 2012
I do regularly apply sunscreen to my flight controller. Skin cancer is a serious issue with multirotors
Old Nov 07, 2012, 02:44 PM
MTHead4u is offline
Find More Posts by MTHead4u
Having fun again!!
MTHead4u's Avatar
United States, AZ, Queen Creek
Joined Aug 2012
Originally Posted by T J Gilbert View Post
Me neither...
Mine being one of them..
Anyhow, other then letting you know that your at half stick (50%) throttle, is there another point to the second part of this (after motor start) that I'm missing? The first part makes total sense, I'm guessing it will warn you if you move a trim enough to effect the calibration after bootup, but the second part seems irreverent. Just wondering if there is something I'm missing...
Sparking indications of Atti. and GPS Atti. are:
 Before motors start: Single blink, all sticks (except throttle stick) return to center; Double blinks,
stick(s) (except throttle stick) not at center.
 After motors start and throttle stick is over 10% in 3 seconds: Single blink, all sticks return to center;
Double blinks, stick(s) not at center.
MTHead4u is offline Find More Posts by MTHead4u
Old Nov 07, 2012, 02:56 PM
crash8384 is online now
Find More Posts by crash8384
crash8384's Avatar
United States, OK, Erick
Joined Aug 2011
Originally Posted by MTHead4u View Post
Their listening, to some extent..
Of course that's the Heli model.
omg a fbl controller for helis. where? when? how much? i must have a few !!!!
or is it a fbl ctlr ?
crash8384 is online now Find More Posts by crash8384
Old Nov 07, 2012, 02:58 PM
crash8384's Avatar
Joined Aug 2011
man what an awesome vid of the heli . it has a clear case though, will be installing one soon on my t-700n
Old Nov 07, 2012, 03:13 PM
troynh is offline
Find More Posts by troynh
No thrust...It'll bust...
troynh's Avatar
Troy, NH
Joined Sep 2006
Absolutely loving this Naza! Rock solid stability.
-Tim
troynh is offline Find More Posts by troynh
Old Nov 07, 2012, 03:25 PM
Empire Support
Joined Feb 2009
Double flashes
From MTHead4u:
"The first part makes total sense, I'm guessing it will warn you if you move a trim enough to effect the calibration after bootup, but the second part seems irreverent. Just wondering if there is something I'm missing..."
You've pretty much got it figured.
FWIW, don't use trims with Naza.
Each time you boot up, the "trimmed" center positions are set to zero.
And then you trim again when you fly.
Consequently, Naza adds your trims.
And you get frustrated continually trimming the same way each flight.
The CSC can eventually be effected...
The "relevant" part of the second condition is you'll know when you have the throttle at midpoint.
Also, when I'm flying in wind, I'm not always cognizant of whether I'm leaning on the right stick compensating. In a good breeze, you sometimes don't want to release the stick to find out.
And some of us have flown Naza in pretty stiff breezes!
Old Nov 07, 2012, 04:08 PM
MTHead4u is offline
Having fun again!!
MTHead4u's Avatar
Joined Aug 2012
Yep, read that about the trims quite a few times, good info.
Never thought about the wind and sticks though, I can see that being helpful. Thanks!
Old Nov 07, 2012, 05:07 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
This was prior to adding the GPS but yeah, some of us have.
2012 Wattfest01 (6 min 37 sec)
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Nov 07, 2012, 06:11 PM
joeb56 is offline
Find More Posts by joeb56
Australia, NSW, Mt Hutton
Joined Jul 2007
Saw the prototype of the Naza H at IRCHA
I hear the couple of guys who are testing are very happy with them
Can't wait
joeb56 is offline Find More Posts by joeb56
Old Nov 08, 2012, 06:32 AM
MCrites is offline
Joined Jan 2012
25mph gusts... Just testing out the gimbal (it wasn't level when i took off). I was using full stick in ATTI mode to keep it in one place. GPS couldn't keep up and it would just sail down wind. I hold my F550 after to show the 25ft trees blowing around.
Wind Test (1 min 32 sec)
Old Nov 08, 2012, 07:49 AM
Empire Support
Joined Feb 2009
The Wind Is Your Friend!
http://www.youtube.com/watch?v=FYs5gMhkhB8
I've been gutsy enough to try 30 mph gusts.
GPS was able to deal with it somewhat, but Atti flying was a blast.
I started out high wind flying with the wind coming from behind me to keep the airframe out in front.
Now, I like to push out into a headwind and let it bring the airframe back to me...
A LARGE time!
Old Nov 08, 2012, 08:09 AM
MCrites is offline
Joined Jan 2012
I wanted to try flying high but with over $2k in video equipment on board it wasn't worth the risk. It's the reason I want a FPV Quad setup.
Old Nov 08, 2012, 08:29 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I learned to fly r/c with just rudder/elevator (no throttle) ... so keeping upwind on a blowy day was pretty important. Run out of fuel downwind and you'd never get back
I had a bad moment with my first quad (non-DJI) drifting downwind despite full 'elevator' applied (luckily the wind then dropped a bit). I increased the maximum allowed tilt angle after that, for the Naza it's 45 degrees anyway which should be fine.
Bill Glover is offline Find More Posts by Bill Glover
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
