Old Oct 14, 2012, 03:36 AM
SCVJeff is offline
Find More Posts by SCVJeff
Joined Mar 2009
Originally Posted by Cervanchez View Post
Here's the inside of mine.
Update on my gps: I got a new one and this time I'm trying the flush mount. So far tests are promising. Testing in my backyard, I got full lock even with it right next to my Contour cam. That is without my AV Tx plugged in. When I plug that in it drops to 1 red blink, 1 green, which is pretty much what I got before with the stalk mount. Hopefully today I'll be able to test in an open area. I'm hoping I don't have to do any shielding or use ferrite chokes or any of that. With this same setup and the gps mounted on the stalk, I never had a problem getting full lock.
Thanks.. It's too bad that the cable is epoxy'ed, but it appears the PC is clad on both sides, and that where the bond really needs to be.
SCVJeff is offline Find More Posts by SCVJeff
Old Oct 14, 2012, 05:27 AM
jetstuff is offline
Find More Posts by jetstuff
United Kingdom, Norwich
Joined Jun 2004
Double blinks?
Just noticed that I quickly get single green LED (GPS) flashing as usual after powering up....then when motors start I get double green blinks.....didn't notice on the old Quad....is it OK/normal?
jetstuff is offline Find More Posts by jetstuff
Old Oct 14, 2012, 09:33 AM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
danielnc06
don't know if you saw this video.
this guy has the same altitude hold problem with his NAZA, you had. Watch at the end, when it bounces up and down off the ground!
He even holds his Tx in front of the camera (like you did ) to show he isn't touching the sticks. And it's a cloudy day
Problem 2 modo Atti DJI naza (2 min 23 sec)
320pilot is offline Find More Posts by 320pilot
Old Oct 14, 2012, 09:43 AM
jetstuff is offline
Joined Jun 2004
I only get the double flash when motors run...not before.....think that's OK?
quote ........In AttiMode, after power on and before any motors start,
Old Oct 14, 2012, 09:49 AM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
jetstuff,
ok I thought that line in the NAZA manual was describing what you had..
Old Oct 14, 2012, 10:53 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Double flash simply indicates that not all TX controls are centred.
Bill Glover is offline Find More Posts by Bill Glover
Old Oct 14, 2012, 11:26 AM
danielnc06 is offline
Find More Posts by danielnc06
danielnc06's Avatar
United States, NC, Charlotte
Joined May 2010
Originally Posted by 320pilot View Post
danielnc06
http://www.youtube.com/watch?v=8SBRv...eature=related
Thanks 320,
that was very similar... only i guess with gps lock mine wasnt wandering about...for whatever reason, mine is not doing it anymore but its scary that it randomly popped up.. and i follow a fairly similar startup procedure in that exact location there are not too many variables that could have changed.. i will wait until DJI says some thing... maybe i can get it replaced... otherwise idk if i trust it as much...
Is this pilot on rcgroups?.
danielnc06 is offline Find More Posts by danielnc06
Old Oct 14, 2012, 02:23 PM
AAzerosix is offline
Find More Posts by AAzerosix
United States, TX, Dickinson
Joined Jul 2012
Upgraded to the latest software/firmare. Recommend removing props as mine went full throttle into my couch. If the front would have been pointed toward me, today would have gone in a much different direction. Thankfully, the front was pointed away from me and the only casualties were all 4 props.
AAzerosix is offline Find More Posts by AAzerosix
Old Oct 14, 2012, 02:39 PM
crash8384 is online now
Find More Posts by crash8384
crash8384's Avatar
United States, OK, Erick
Joined Aug 2011
ha ha ha , i did mine last night and my dumb a55 knew better and well lets just say graupners will cut you really bad, ive been flying for 32 years and i knew better but i did it anyways, yea that wont happen again, i have a 2" chunk of meat out of my arm, im still bleading and should go to the e.r. but what are they gonna do? theres meat missing AND NOTHING LEFT TO STITCH UP ! lol , lesson learned,
REMOVE YOUR PROPS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
crash8384 is online now Find More Posts by crash8384
Old Oct 14, 2012, 02:41 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
(+1)
Everyone, say it together!!!
mark_q is online now Find More Posts by mark_q
Old Oct 14, 2012, 02:42 PM
crash8384's Avatar
Joined Aug 2011
Originally Posted by mark_q View Post
(+1)
yes please remove your props
Old Oct 14, 2012, 03:07 PM
Joined Jul 2012
I'm pretty new to multirotor flying. I believed that if the vu was connected to the PC, it wouldn't power the motors....was I wrong! Live and learn I guess. One of those moments that reminds you that this "toy" can take your face off.
Old Oct 14, 2012, 03:17 PM
danielnc06's Avatar
Joined May 2010
Originally Posted by danielnc06 View Post
Thanks 320,
well i was naive to think it just disappered... just flew it again and after about 2-3 minutes of hover.. the bounce returned....it makes it simply unflyable in atti or gps mode!... to any troubleshooter it seems just like a vertical gain issue.. but no values make a difference..!
Old Oct 14, 2012, 03:38 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
So I am confused here. What actually happened.
When you actually plug it to fly it you turn on the TX, plug it in, and then do the CSC.
Indoors if you turn on the TX, and plug it in it shouldn't start the motors even if the throttle is not a zero without CSC. The next step is to plug in the USB. Is that when the motors started and went to full throttle?
While the advice to remove the props is very good advice, I think it is important to know what caused it to go to full throttle in each case.
u2builder is offline Find More Posts by u2builder
Old Oct 14, 2012, 03:46 PM
Joined Jul 2012
No, I was making adjustments to the gains and and GPS position settings. Took it outside to try the new settings, brought it back in to adjust. TX on, USB plugged in, then plugged in the battery....nothing out of the ordinary. When I opened the DJI assistant, I noticed that there was a new software and firmware download. After downloading the software, it asked me if I wanted to upgrade the firmare. I clicked "ok" Then it happened. Full throttle. Didn't touch anything. Then get a message on the PC to power cylce the FC. 4 busted blades and nearly a ruined pair of skivies later, I'm all upgraded.
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
