Old Oct 11, 2012, 09:28 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Hey folks,
Just having a bit of grief getting my quad to yaw properly. Every time i yaw either way, once i release the yaw stick my quaqd blips with power and bounces up about a foot high. Sometimes when using the yaw control the quad climbs too.
I have tried little gain, and ive tried lots of gain and tried a few numbers in the middle and i just cant tune it to yaw nice and smooth.
Any tips i should try?
Teamsherman is offline Find More Posts by Teamsherman
Old Oct 12, 2012, 12:33 AM
SCVJeff is offline
Find More Posts by SCVJeff
Joined Mar 2009
Originally Posted by wdelarme View Post
Will now be offereing the shielding to the NAZA GPS protector for a total cost of $15.00 shipped. I will shield it, you will need to supply the 22 awg +- to connect it to the aircraft ground
No soldering on the gps protector at all the sheilding is conductive on both sides I will also ship with extra piece of copper tape to make the connection to the shielding
Please excuse the meter it won't go to total 0 since the leads are about 10 years old but this is connected to the drain/ground wire and touching the meter to any part of the shielding
Good idea, but you are not creating a simple electrical ground, it's an RF ground that's way better off with a thin strip of flat copper. It needs to be a solid BOND, not just electrically grounded as reported by an ohm meter with a 22meg-ohm impedance. (and at RF that little wire could easily radiate parasitically. Take a piece of 14ga THHN and hammer it into a copper grounding strip. Either way I like the copper cup.
SCVJeff is offline Find More Posts by SCVJeff
Old Oct 12, 2012, 04:05 AM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Yaw twisting
Originally Posted by Teamsherman View Post
Hey folks,
I just move the yaw to the center slower. Sometimes I forget, let go, and it jumps. What is going on is the rotary motion of the counter direction of the propellers give it the yaw movement ability with a given rpm.
"Yaw is induced by mismatching the balance in aerodynamic torques (i.e., by offsetting the cumulative thrust commands between the counter-rotating blade pairs). " From http://en.wikipedia.org/wiki/Quadrotor.
This is a characteristic.
It would be nice to have a time dampening of the PPM signal that would be adjustable and make it smoother.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Oct 12, 2012, 04:12 AM
Joined Feb 2011
Anti Vibrating
Does anyone have any experience using Alpha gel or Sorbothane mounts to lessen vibration transfer to a camera? A little research regarding such mounts along with balancing props is the way to go. Alpha gel is expensive.
Old Oct 12, 2012, 07:25 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Mike_Then...
I'm glad that things have improved.
You are taking the approach that will yield success.
As a technical person, you know that a technical hobby can't escape being technical...
Damn, I sound like Yogi Berra!
T J Gilbert is online now Find More Posts by T J Gilbert
Old Oct 12, 2012, 07:31 AM
wdelarme is offline
Find More Posts by wdelarme
United States, WV, Harrison
Joined Jul 2012
That sounds like a great idea. Like I said I am not supplying the ground wire. the picture was more of a proof of concept. I was actually looking for a piece of braided flat copper but I haven't been able to find a small piece (low weight)
wdelarme is offline Find More Posts by wdelarme
Old Oct 12, 2012, 09:49 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
De-soldering braid?
Bill Glover is online now Find More Posts by Bill Glover
Old Oct 12, 2012, 09:53 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Where does the ground attach to the airframe, ie. what is "ground" on the airframe? Thanks.
u2builder is offline Find More Posts by u2builder
Old Oct 12, 2012, 10:00 AM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
The ground for the airframe is right next to the positive.
Mike Freas is offline Find More Posts by Mike Freas
Old Oct 12, 2012, 10:26 AM
wdelarme is offline
Joined Jul 2012
Looked at that too. The best way to run the ground from shielding I have found is to run a strip of copper shielding to the outside of the guard. ..then run it down the stand...I'm not sure the best way to connect it to the aircraft. I imagine each aircraft would be different. for example my quad is made of wood. I may have more of a run than say a user with a metal frame.
Any suggestions?
Originally Posted by Bill Glover View Post
De-soldering braid?
Old Oct 12, 2012, 10:27 AM
kd4wen is offline
Find More Posts by kd4wen
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
This would be considered the electronics ground in most cases due to most multi rotor airframes do not consist of an airframe ground. I guess if you had a pure all carbond fiber frame you could tap the electronics ground onto it some where.
kd4wen is offline Find More Posts by kd4wen
Old Oct 12, 2012, 10:33 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Some have used Moon Gel with good success. I tried it and didn't have much luck but admittedly, I only tried it once. I've had much better luck using foam earplugs. That's what I plan to use for mine.
Yup, just have to remember it takes patience... something that can be in short supply with me sometimes. The weather is beautiful today so I'm definitely going to try to fly it again.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Oct 12, 2012, 10:46 AM
jamac is offline
Find More Posts by jamac
United Arab Emirates, Dubai
Joined Aug 2012
I've picked up some .50 sorbothane (at amazon), recently. Didn't have time to test it properly yet but run some motor tests using the iphone vibration app. Looks promising. On average, it reduces motor vibes by 50%. The overall frame vibration measured at the center of the F550 top plate showed a 40% reduction. I hope to test it in flight today, late evening.
jamac is offline Find More Posts by jamac
Old Oct 12, 2012, 11:22 AM
kd4wen is offline
Just a yard bird
kd4wen's Avatar
Joined Mar 2007
Check out the new behemoth from Dex's frame line up Look out S800 lol
Old Oct 12, 2012, 11:26 AM
paulinfrance is offline
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
It looks like a Klingon warship,,,
paulinfrance is offline Find More Posts by paulinfrance
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
