Old Oct 03, 2012, 12:40 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
Agree Don. The complete wing setup is sooo much cheaper than a quad. Now you'll have the best of both worlds. If you have trouble setting up the eagle tree screen give me a shout. Either email like we do or skype, yahoo chat or phone.
seadog1967 is offline Find More Posts by seadog1967
Old Oct 03, 2012, 01:01 PM
Mrhydrox is offline
Find More Posts by Mrhydrox
FPV by mrhydrox
Mrhydrox's Avatar
Danmark, Sjślland, Jyderup
Joined Jun 2011
failsafe on my f550 with futaba 6 ex
Hi
Can I setup failsafe on my naza with my futaba 6 ex. My radio has failsafe on throttle.
I use channel 5 as switchmode between GPS and attimode, and channel 6 as orientation control
I think that I maybe can set channel 5, so I can switch between GPS and failsafe, or maybe GPS and Atti and when I turn off the radio, it goes on failsafe.
I will use the hexacopter ass a FPV platform, so I will like If failsafe is working.
I have heard that I have to set throttle at 50% when I setup failsafe, is it right???
Peder
Mrhydrox is offline Find More Posts by Mrhydrox
Old Oct 03, 2012, 02:42 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
It's in the manual - anything over 10% is fine, so 50% will be OK.
Bill Glover is offline Find More Posts by Bill Glover
Old Oct 03, 2012, 03:07 PM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Check Naza FC Thread
Hi
Peder
We have a similar conversation going on over on the other thread...
http://www.rcgroups.com/forums/showp...ostcount=14623
Maybe it will help...
Try to avoid using transmitter = off to trigger Failsafe...
Does the Futaba 6Ch support a preset or zero throttle Failsafe for transmitter off? (Just wondering...)
T J Gilbert is online now Find More Posts by T J Gilbert
Old Oct 03, 2012, 04:32 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Guys thanks again for the responses. The video that was linked was extremely informative and helpful. It explained more in the first three minutes than I've gotten from the Chinglish manual after reading it cover-cover several times. And the fact that the author of the video sounded a lot like Wilford Brimley, I was put at ease and a calm washed over me.
But seriously, I was thinking "why would I ever use use the IOC function" but I can see how they could come in very handy, especially if you lose orientation. I may never use it, but you best believe it's gonna be set up on a switch.
Now I'm excited... gotta install that GPS!
Mike_Then is online now Find More Posts by Mike_Then
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Originally Posted by mewert View Post
My new F550 was acting the same way until I re-soldered ALL the bullet connectors on the motor wires. I also put just a slight amount of solder on the back of the splines that spin on the bullet. If you get too much in there, it makes reconnecting very hard for the slip-in fit. This curred my twitching. Certainly worth the effort.
I did the same, except instead of soldering on the splines I soldered the tip of the bullet to the cage so the cage cold not rotate and is now electrically connected to the center part that the wire goes into. You definitely have to be careful not to use too much solder or bullet will be very hard to put in. Do this first, then resolder wire into bullet. If done in reverse order you could actually make the wire bullet connection worse! Ask me how I know! BTW I found several motor wires that seemed to be nice and tight, but when I removed the wires they appeared not to have been "tinned" and were possibly not bonded to the solder in the connector. This might explain why it worked for a while but then started to fail as oxidation developed around the wire. Just a theory.
u2builder is offline Find More Posts by u2builder
Old Oct 03, 2012, 05:29 PM
Joined Nov 2000
Well I maidened my new 2.1 kg F550 today - no drama, no issues, the recommended gain settings from the new manual seem a very good starting point (despite the higher AUW and the fact that I'm using 3S & 10" props). Nice solid GPS lock - in fact I got > 6 sats in my lounge!
As with the quad I had before I took a lot of care to keep everything separated as best I could. The big centre plates of the 550 are a help in this respect.
Old Oct 03, 2012, 06:05 PM
mewert is online now
Find More Posts by mewert
Team Armattan
mewert's Avatar
College Place, WA.
Joined Apr 2004
I think your theory is spot on, as I noticed the same situation with the wires.
mewert is online now Find More Posts by mewert
Old Oct 03, 2012, 06:51 PM
Joined Nov 2000
Couple of pics of my F550. The domes are cosmetic ... just cover the battery ... but they only weigh 20 grams each. Bet it's the only 550 in the world that uses balsa, ply, and beechwood (gee what are they, grandpa?)
Old Oct 03, 2012, 06:59 PM
DeltaPopper is offline
Find More Posts by DeltaPopper
United States, WI, Burlington
Joined Jan 2005
IOC Not Always Engaged
I have IOC setup with a 3-way switch. It works fine, most of the time. I use Course Lock quite often, as I am still "in training".
I sometimes have to flip the switch from off to course lock a few times to get it to work. Is there a procedure to follow prior to take-off to engage IOC?
Thanks to anyone.
DeltaPopper is offline Find More Posts by DeltaPopper
Old Oct 03, 2012, 07:06 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Yeah, for a 550 maybe, but talk about wood
http://onlyflyingmachines.com/product/the-widowmaker/
Old Oct 03, 2012, 07:36 PM
Empire Support
Joined Feb 2009
David Bott's Builder!
We've seen that guy before...
Old Oct 03, 2012, 08:04 PM
seadog1967's Avatar
Joined Nov 2010
Ahhhh yess Mr. Ali.. Entertaining reviews.
Old Oct 04, 2012, 01:45 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
LOL
I am a big fan of the BlueSkyRC Multirotor frames.
They are made from 1/8 lite ply.
www.blueskyrc.com
I am using carbon arms but many use bass wood arms.
I recently mounted my Gopro onto the front used some dense foam that was the packaging from my KK2 controller and there is no jello effect or visible vibes in the picture at all!
I am a fimr believer that the wood frame helsp to absorb the vibrations from the Motor/Prop
(i also balanced my props)
I am working on a 1/8 lite ply 2axis camer gimbal at themoment as it is cheap to get laser cut and easy to assemble and should be pretty lite.
cheers
Ben
Borneoben is offline Find More Posts by Borneoben
Old Oct 04, 2012, 02:10 AM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
Hi, Has anyone tried upgrading old v1.2 firmware straight to the latest v2.02 without ended up with a dead NAZA? Can I bypass the other versions of firmware which was released in between the v1.2 and v2.02? thanks.
I already installed the latest Assistant software on my computer but still afraid to click the firmware upgrade button.
No intention to install the GPS module anytime soon but I just wanna take advantage of the 400hz gimbal output.
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 05:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 05:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 09:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 02:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 06:01 PM
