Old Jul 07, 2012, 06:25 AM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
Vtx 5.8 Ghz 500mw will be released in three weeks. Rx will be a few weeks later.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Jul 07, 2012, 08:12 AM
Mustflynow is offline
Find More Posts by Mustflynow
Mustflynow's Avatar
United Kingdom, Bures
Joined May 2012
Need some help on my y6 esc's......
I can calibrate the simonk esc's using wiring loom and all 6motors spin up at the same time however when I connect them back to the naza I have to throttle up pass half way to get motors to spool up and only the bottom 3 start up first and the the top 3 start one by one at about 3/4 throttle.......
Completely lost on this....
Any suggestions?
During calibration...
SimonK esc calibration (0 min 14 sec)
After calibration
SimonK esc connected to Naza gps (0 min 40 sec)
Mustflynow is offline Find More Posts by Mustflynow
Old Jul 07, 2012, 08:53 AM
Soldier53 is offline
Find More Posts by Soldier53
Joined Oct 2011
using Aluminum foil tape?
Hi, can you show me how to use using Aluminum foil tape use Aluminum foil tape?
Instead of using a torroid, do you think wrapping aluminum foil tape around the GPS cable would act as shielding? The tape would be grounded of course at each end. This tape is commonly used for HVAC ducts. I use it to protect the bottom of my foamies at times. As an example, none of the wires used for my IMRC 5.8 ghz tx is sheilded! It looks like normal servo wire. I wonder if DJI has shielded cable coming out of the GPS unit? Come to think of it, I don't think any of the wires used on my Quad/Naza/GPS use shielded wires/cables.
Aluminum foil tape is much lighter than torroids, and can be neatly covered with an appropriate length of heat shrink tubing
Reference:
http://www.newark.com/pdfs/techartic...haWire/USC.pdf[/QUOTE]
Soldier53 is offline Find More Posts by Soldier53
Old Jul 07, 2012, 08:54 AM
Joined Oct 2011
Old Jul 07, 2012, 09:35 AM
KevinBuckley70 is offline
Find More Posts by KevinBuckley70
KevinBuckley70's Avatar
Oxfordshire, UK
Joined Jul 2001
Originally Posted by Jack2010 View Post
If they do decide to add OSD functionality, I hope they include the barometric pressure to give height above ground as GPS height doesn't work so well.
I added the telemetry module + altimeter function for my Spektrum DX8 yesterday & the result seems very reproducible. Hovering at fixed heights (between 0 & 35m agl) the numbers stayed within around +/- 0.1m unlike the GPS which is often tens of meters out & lagging. I mounted the sensor on the same mast as the OSD GPS module as I was worried about downwash affecting the pressure and that seems to have worked (see attached pic's). Hovering inches from the ground (or on the ground) & at various heights from zero upwards don't seem to be affected by what the rotors are doing.
KevinBuckley70 is offline Find More Posts by KevinBuckley70
Old Jul 07, 2012, 10:41 AM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Any suggestions?
http://www.youtube.com/watch?v=_7Gp3...e_gdata_player
After calibration
http://www.youtube.com/watch?v=imuPjR-svmU
OK, so u did the full throttle wait for Beep then down to min throttle and hear Beepps?? What do u have your motor speed set at??
G-unit is offline Find More Posts by G-unit
Old Jul 07, 2012, 11:03 AM
Tetley is offline
Find More Posts by Tetley
AKA 3DJIM
Tetley's Avatar
Bournemouth Great Britain (UK)
Joined Jun 2004
Ok you have my full attention! when,where, and how much!? and do you need me to test one for you
Jim.
Tetley is offline Find More Posts by Tetley
Old Jul 07, 2012, 11:07 AM
Mustflynow's Avatar
Joined May 2012
Thanks ...all sorted now thanks the Adidas!
Had to increase my idol speed due to the Simon K esc!
Now need to work out vertical gain as it just doesn't want to hold .....it either goes up then goes down....all in one spot so I take its the V-gain that needs adjusting ....currently set at 125%
Old Jul 07, 2012, 02:54 PM
MattLarson29 is offline
Find More Posts by MattLarson29
Endangered User
MattLarson29's Avatar
United States, FL, Casselberry
Joined Jul 2002
Reference:
[/QUOTE]
Hi!
Aluminum foil tape will not work in place of a toroid for winding coils to inhibit common-mode interference. The specific physical properties of the toroid material are part of the reason they work. In fact, toroids are available in different materials depending on the desired inductance.
MattLarson29 is offline Find More Posts by MattLarson29
Old Jul 07, 2012, 03:05 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Nice Sidney, what frequencies does it operate on? Is it Immersion compatible?
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Jul 07, 2012, 03:12 PM
paulujvari is offline
Find More Posts by paulujvari
paulujvari's Avatar
United Kingdom, England, Derby
Joined Jun 2011
Hi all...Do you know that DJI have a Youtube account.
They are posting new features and help vids. for all us children mature grownups to get excited about.
New stuff about upcoming WKM firmware and Naza features etc.
Here is the LINK if you're interested.
Really pleased to see that DJI are trying to support its customers
paulujvari is offline Find More Posts by paulujvari
Old Jul 07, 2012, 03:23 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Great...something else to spend my whole day on vs cleaning house, trimming the shrubs, etc. Thanks for the link!!!
Sidney (or DJI if you're around). Any possibility on getting a Tricopter setup for the Naza. I wouldn't mink getting another unit IF I could install it on my FPV tricopter. No tricopter support no additional purchase...
Vantasstic is offline Find More Posts by Vantasstic
Old Jul 07, 2012, 03:26 PM
Tony97 is offline
Find More Posts by Tony97
Tony97's Avatar
Joined May 2004
Gps related crash?
I had my first crash with my hexacopter Naza/GPS today. It almost acted like that hexacopter that had that back right drift and went into the water. Reminded me of it exactly. I have only powered up the FPV gear and Go Pro a few times with the GPS but never had issues. I always power up the Naza first to allow a good lock (blinking green), then I power up the VTX. I never get any red blinking lights.
This was my 25th flight with Naza GPS installed. I have a 1.3GHz 300 mW VTX and a Go Pro 2 in use on this flight. Good GPS before takeoff. 18 seconds into flight, centered sticks to hover so I could put on my goggles. The Hexacopter started a hard drift backwards at a good rate. Could not correct this by giving forward stick. Should have taken out of GPS and went to MANUAL.
I looked over everything pretty good. No props broken, no props loose. All transmitter switches set fine. GPS MODE, FAILSAFE-OFF, HOME LOCK-OFF.
I did break the nylon swivel bolt that holds my camera gimbal on. I threw a spot tie in place of that bolt. Set the hexacopter in the same spot. Duplicated everything as I did before and flew. No issues. I flew 3 more battery packs FPV without any issues.
Any ideas here?
Tony
Text on title screen didn't come out. The info is written on this page about what happened.
Naza GPS Related Crash (0 min 59 sec)
Tony97 is offline Find More Posts by Tony97
Old Jul 07, 2012, 03:40 PM
paulujvari's Avatar
Joined Jun 2011
You're welcome......Trying to add some positivity to the DJI threads is like arguing with a woman.You will never ever win,ever!...Never i tell you!.........
Never
Last edited by paulujvari; Jul 07, 2012 at 03:42 PM. Reason: Trying to get the last word in.
Old Jul 07, 2012, 03:46 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Hmm, I don't think the issue is noise from the cable. More from other antennas and the GPS antenna. I would think DJI would have put shielding in their cable if it needed. I don't think I would try the aluminum tape. Just my 2 cents.
Originally Posted by Silverexpress View Post
Hi Tony,
Reference:
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 04:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 01:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 05:01 PM
