Old Jun 08, 2012, 11:43 PM
boolander is offline
Find More Posts by boolander
boolander's Avatar
United States, PA, West Chester
Joined Apr 2007
Originally Posted by signal7 View Post
I know some folks were wondering what the Naza GPS came with in terms of mounting hardware.
Here's what's in the box:
- Naza GPS
- Upper and lower mounting brackets
- Mounting stalk
- 4 pieces of 3m mounting tape
- Stickers for alignment/measurement
What do you do with the alignment/measurement stickers?
boolander is offline Find More Posts by boolander
Old Jun 09, 2012, 12:02 AM
signal7 is offline
Find More Posts by signal7
signal7's Avatar
USA, VA, Merrifield
Joined Jun 2008
Apparently they're for assisting in the alignment of the GPS. The manual simply says "The DJI logo marked on the GPS should face the sky, with the orientation arrow pointing directly forward. The GPS/Compass is packaged with a special indication line for mounting for the first time."
I did not use them on my WKM, I just eyeballed it. These are probably not necessary but if anyone has a particularly good use for them I'd like to know
signal7 is offline Find More Posts by signal7
Old Jun 09, 2012, 12:30 AM
gww528 is online now
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
Originally Posted by blade strike View Post
Just so everyone is clear you will not trigger a pre set fail-safe on a 6200 rx.
You need a ar7000 or higher rx to trigger fail-safe with spektrum. Then you also have to bind twice. One to standard bind and then next bind with be with the TX in the config that will trigger the naza or wkm to trigger their Failsafe.
So for an example I use throttle hold to trigger failsafe on the wkm/naza. So I would power on rx with bind plug. Once power light is blinking pull bind plug. Now I power on my TX with throttle hold ON and bind button pressed. Recycle power and now test your failsafe via software.
Just to clarify, there are two AR7000, only the one that has "Data/Batt" listed on the label will work. Some have just have "Batt", they do NOT have Pre-set Failsafe.
gww528 is online now Find More Posts by gww528
Old Jun 09, 2012, 12:57 AM
BladeRex is offline
Find More Posts by BladeRex
Bladerex700
Joined Jul 2007
I am confused and it my sound ignorant but what's IOC
BladeRex is offline Find More Posts by BladeRex
Old Jun 09, 2012, 01:29 AM
repodog is offline
Find More Posts by repodog
United States, CA, Pacific Grove
Joined Jan 2012
GPS Features include: RTH (Return-To-Home); IOC (Intelligent Orientation Control) and Low Battery warning.
IOC means that no matter which way your copter is pointing, pulling the stick back makes it come back to you, forward goes away from you, etc. It's like the system reverses certain channel for you based on which way it's pointing, so you don't have to remember which way is forward/backward/left/right. This is helpful when you lose orientation.
repodog is offline Find More Posts by repodog
Old Jun 09, 2012, 01:34 AM
mewert is offline
Find More Posts by mewert
Team Armattan
mewert's Avatar
College Place, WA.
Joined Apr 2004
Inteligent Orientation Control , I believe.
I'm new to this myself. Just got my F450 kit today and have it built but not all hooked up and running yet. Will add GPS later when I'm in the groove with it.
Subscribed here also.
mewert is offline Find More Posts by mewert
Old Jun 09, 2012, 01:39 AM
paulinfrance is offline
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
Originally Posted by mandis View Post
maybe your gains are too high..
Thanks but i have gone from 50% to 150% and also re soldered the motor, a friend stripped the motor wires and re soldered them and his has stopped wobbling.
paulinfrance is offline Find More Posts by paulinfrance
Old Jun 09, 2012, 05:54 AM
Yammysho is offline
Find More Posts by Yammysho
Australia, ACT, Canberra
Joined Apr 2011
Home lock video test
Just did a "home lock" test, in the first half of this onboard video I flew out then left then spun the quad 180 degrees facing me and by pulling back stick the quad flies back to takeoff point. The second half I flew out then right then spun the quad 90 degrees and by pulling back stick it stills flies back to take off point. Hope this makes sense...
IOC home lock.MP4 (2 min 25 sec)
Yammysho is offline Find More Posts by Yammysho
Old Jun 09, 2012, 12:17 PM
tien8tien is offline
Find More Posts by tien8tien
Joined Apr 2011
http://youtu.be/wCuFjfmFEwo
Thanks Yammysho! and you have a really nice flying club field...
tien8tien is offline Find More Posts by tien8tien
Old Jun 09, 2012, 01:23 PM
BozSpeed is offline
Find More Posts by BozSpeed
S.Bus Driver
Australia
Joined May 2012
Originally Posted by Exploding Fist View Post
They really need to create a Naza + GPS package for a little less than both.
DJI list a Naza/GPS combo for the same price as buying the Naza and GPS module separately.
I'm sure you will see them available in the US after the rush of the GPS modules is over.
BozSpeed is offline Find More Posts by BozSpeed
Old Jun 09, 2012, 01:31 PM
blade strike is online now
Find More Posts by blade strike
Free Bird
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Very true! FYI If you do have an older one w/o the data tag, they will update it for free
blade strike is online now Find More Posts by blade strike
Latest blog entry: It's time....
Old Jun 09, 2012, 01:39 PM
azure is offline
Find More Posts by azure
Joined Mar 2012
I think you are saying that to assign a specific switch or button on your controller which initiates NAZA Failsafe directly, it's necessary to have an AR7000 or above. But what if I just turn off my transmitter while using an AR6210? Assuming that I created a controller mix that gave me the proper combination of inputs that highlighted the blue Failsafe field in the NAZA Assistant set up, wouldn't it initiate the NAZA RTH sequence as demonstrated in the videos that Signal7 posted?
azure is offline Find More Posts by azure
Old Jun 09, 2012, 01:46 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
The AR6 series only saves the Throttle setting, nothing else. Sorry.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Jun 09, 2012, 01:52 PM
Free Bird
Joined Jan 2006
^^^^Correct
This would only allow you to trigger the naza failsafe when still having control of craft. THIS WILL NOT give you a true failsafe incase of signal loss!
Old Jun 09, 2012, 02:10 PM
actionplus is online now
Find More Posts by actionplus
United States, CA, Rancho Cucamonga
Joined Mar 2005
Ioc
A quick question as this IOC is new to me.
How does the quad actually know if I am trying to back up or wanting it to change the direction for the front on the quad.
actionplus is online now Find More Posts by actionplus
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 05:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 05:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 09:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 02:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 06:01 PM
