Old Jun 06, 2012, 04:44 PM
crash8384 is online now
Find More Posts by crash8384
crash8384's Avatar
United States, OK, Erick
Joined Aug 2011
Help!
need arduino info for flashing this mwc board...PLEASE HELP...
here is the mwc fc board i have in an x copter
http://www.goodluckbuy.com/mwc-multi...opter-red.html
i have updated it to 2.0
problem is in arduino 1.0 when selecting the board i have no clue which one to select. it has the atmega 328 and thats all i can tell you. i have been selecting the arduino pro or pro mini 5v 16 hz atmega 328
and in the config h selection i have been selection var board types. my quad is sooo un stable. i cant get it to hover good at all.
im sure it just because i dont know what board i have or selecting the wrong board. all i know is i have the atmega 328 chip and its red and says multiwii 2012 on the bottom. looks identical to the crius mwc se kinda but red.
can someone shed some light on what board i need to select please
crash8384 is online now Find More Posts by crash8384
Old Jun 06, 2012, 05:21 PM
Camelboy is offline
Find More Posts by Camelboy
Prog Rocker
Down South
Joined Jul 2009
Update back to Multi-wii 1.9, and use older version of Arduino 0022.
pro-mini 5, 16mhz.
Camelboy is offline Find More Posts by Camelboy
Old Jun 06, 2012, 05:24 PM
crash8384's Avatar
Joined Aug 2011
ok ill give it a try
Old Jun 06, 2012, 05:26 PM
crash8384's Avatar
Joined Aug 2011
ok now which board do i define in the config h ?
Old Jun 06, 2012, 05:29 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
The site say it is compatible with FFIMUv2 (5883) and promini
pug398 is offline Find More Posts by pug398
Old Jun 06, 2012, 05:31 PM
crash8384's Avatar
Joined Aug 2011
ok. i am in the process of defining everything manually instead of choosing a fc board in the config menu. shold this work. glb site shows the board specs. sorry new to the mwc thing.
Old Jun 06, 2012, 05:36 PM
crash8384's Avatar
Joined Aug 2011
ok flashing 1.9 wit hnew settings now. will know. i also see what your talking about one the above comment. thank you
Old Jun 06, 2012, 05:37 PM
pug398 is offline
VA
Joined Nov 2009
If you have trouble with sensor orientation go back and try it as a FFIMUv2 module and see if it is preset for you.
Old Jun 06, 2012, 05:42 PM
Camelboy is offline
Prog Rocker
Down South
Joined Jul 2009
looking at the board you have, that is pretty much identical to mine, which I got off of ebay. the ftdi is the same, so what I mentioned should work. Also,, I notice you have an X525 frame, which is also the exact frame I have, so so I have the 'D' values, for pitch/roll @ 47,
the 'P' values, @ 2.6 & 3.1, the 'I' values @ 3.5 for both.
Old Jun 06, 2012, 05:43 PM
crash8384's Avatar
Joined Aug 2011
ok. new prob. after i went to mwc 1.9 my motors wont arm so i have to go in and re do something.
Old Jun 06, 2012, 05:50 PM
Camelboy is offline
Prog Rocker
Down South
Joined Jul 2009
did u calibrate your escs, do u have the Red wire removed from all but one, and is your motors plugged into the correct sequence, 3, 10, 9, 11 clockwise from left front.
Old Jun 06, 2012, 05:52 PM
crash8384's Avatar
Joined Aug 2011
yes yes and yes. i have acually flown this x525 before but i didnt like the baro so i updated to 2.0 and thats when everything went to s#%$
Old Jun 06, 2012, 05:54 PM
crash8384's Avatar
Joined Aug 2011
i forgot to define my thro.......duhhhhh re loading right now but it started blowing hard and raining now so i might have to wait a few hrs.
Old Jun 06, 2012, 05:56 PM
Camelboy is offline
Prog Rocker
Down South
Joined Jul 2009
Cool, I hope it works out for you.
Old Jun 06, 2012, 05:59 PM
crash8384's Avatar
Joined Aug 2011
do you mean 0.035 on i values ?
Help! Need help flashing the HK Control Board Easyrider717 Multirotor Talk 6 May 23, 2012 06:24 AM
Discussion Someone help me identify this MWC board WiseDuck Multirotor Talk 5 Dec 04, 2011 09:37 AM
Sold Paris MWC board Ready for flight w/Arduino Pro Mini 5/16mhz,Wii Motion+,Bosch BMA02 Z06 Tony Aircraft - Electric - Multirotor (FS/W) 16 May 27, 2011 08:56 AM
Sold Paris MWC board Ready for flight w/Arduino Pro Mini 5/16mhz,Wii Motion+,Bosch BMA02 Z06 Tony Aircraft - Electric - Helis (FS/W) 1 May 26, 2011 03:31 PM
Help! Pleas Help! Need info on USA car size quick! fooesboy Slope 9 Aug 04, 2008 12:23 PM
