Old Jun 15, 2012, 06:04 AM
thorsten5 is offline
Find More Posts by thorsten5
Joined Jun 2012
Originally Posted by wic View Post
Pictures and more informations I can send on monday, because I go over the weekend sailing.
OT: Habt ein schönes Wochenende und liebe Grüße aus Finnland
Andy
Hi Andy,
what´s about the cell voltage?
Do you have some pictures?
@all:
Really quiet here even the download of the app really inreased?
No Issues/ Bugs to report. If so, very fine!
Your Input is apreciated.
Regards,
Thorsten
thorsten5 is offline Find More Posts by thorsten5
Old Jun 15, 2012, 07:00 AM
dang is online now
Find More Posts by dang
USA, WA, Olympia
Joined Jan 2001
Originally Posted by thorsten5 View Post
Hi Andy,
@all:
Regards,
Thorsten
I'm excited. I just have to wait until I gather the BT hardware.
dang is online now Find More Posts by dang
Old Jun 19, 2012, 05:22 AM
SleepySean is offline
Find More Posts by SleepySean
PEMAC
SleepySean's Avatar
Australia, New South Wales, Penrith
Joined Jul 2007
Very interested, I have a new samsung SII and have been looking for a telemetry display.
Would it be possible to create a wired connection, eg usb, instead of bluetooth?
SleepySean is offline Find More Posts by SleepySean
Old Jun 19, 2012, 07:21 AM
HaPe is offline
Find More Posts by HaPe
Germany, NRW, Bonn
Joined Jul 2010
Hello SleepySean,
as far as I understand Android – theoretically yes; practically no.
On your radio side you would need a RS232 to USB converter, while on your phone side you need to root your phone and to install an USB to virtual com driver by adding some C code to the linux kernel.
I don’t see any advantage in using USB. Beside of the difficulties to realize it you need an additional cable connection. The necessary RS232 Bluetooth module costs only a few $ and can easily be added to your FrSky radio system.
Regards
Hartmut
HaPe is offline Find More Posts by HaPe
Old Jun 19, 2012, 08:01 AM
Takilara is offline
Find More Posts by Takilara
Takilara's Avatar
Norway, Rogaland, Stavanger
Joined May 2008
Yes this is possible without rooting using http://www.elektor.com/magazines/201....2052326.lynkx
This basically uses the android debug tool to run TCP over USB to the device. The device hosts a TCP server that again converts to serial output.
App needs to be modified to support this though.
I have considered looking into this for my app, though interest has been limited.
(btw i am the creator of https://play.google.com/store/apps/d...mato.frskydash )
Takilara is offline Find More Posts by Takilara
Old Jun 19, 2012, 09:01 AM
dang is online now
USA, WA, Olympia
Joined Jan 2001
So I got this BT adapter,
http://www.ebay.com/itm/ws/eBayISAPI...E:L:OC:US:3160
How do I determine whether or not I need an inverter?
I'd also like to know whether or not I need to hook up both tx and rx. It seems to me that the displays like the FLD-02 only need one wire of signal which (I suppose) would got to rx on the BT.
Old Jun 19, 2012, 09:29 AM
Takilara is offline
Takilara's Avatar
Joined May 2008
Yes, I have it also. But its dont show others than RSSI, AD1 and AD2.
This here show the hub data.
Best regards
Andy
The one on android marked has alpha support for hub as well. but it is "hidden",
To enable it, you have to Hit "About", then hit my name 5-6 times, then "Debug" mode is enabled. Hit Debug, and enable Alpha hub support. You can now use hub channels as source, or show the hub dashboard..
Old Jun 19, 2012, 09:47 AM
dang is online now
USA, WA, Olympia
Joined Jan 2001
Sneaky!
Old Jun 19, 2012, 09:52 AM
Takilara is offline
Takilara's Avatar
Joined May 2008
I can't say for this app. For mine you will need both rx and tx if you want to program alarms.
I don't know if you need an inverter, but you will need a TTL to RS232 converter as the FrSky module is RS232 and not TTL level. I have more information regarding this here: http://projects.onomato.biz/projects...wiki/BlueTooth
Old Jun 19, 2012, 11:10 AM
HaPe is offline
Germany, NRW, Bonn
Joined Jul 2010
Hi Takilara,
an interesting module, which I didn’t know. But where is the advantage ?
- It’s more costly than the serial BT modules
- it has RS 485 port, which doesn’t fir to the serial FrSky in/out signals
- it requires to handle ADB packages
HaPe
Old Jun 19, 2012, 11:18 AM
HaPe is offline
Germany, NRW, Bonn
Joined Jul 2010
Hallo dang,
Right now you only need the rx-Pin of the Bt module.
As mentioned by Takilara FrSky used RS 232 logic, but not the RS232 defined voltage levels (V.24). Therefore a simple TTL signal inverter ( 1 transistor with necessary resistors will do)
HaPe
Takilara,
have you ever tested whether the Bt modules trigger on edges rather on level (0/1) at the serial TTL ports?
If so, not even an inverter would be necessary.
May be I will start some testing.
Old Jun 19, 2012, 11:21 AM
Takilara is offline
Takilara's Avatar
Joined May 2008
Originally Posted by HaPe View Post
Hi Takilara,
HaPe
I assume you mean the module that i use. I started this way back, and that was the only one with RS232 converter built in. I did not want to add components, but rather have one i could use directly. It is very true that a TTL level with a few added components will do the same job (and be cheaper), but will require making a pcb, stripboard or similar.
I was not aware of the 485 as i have no use for that. I only use the 232
Old Jun 19, 2012, 11:30 AM
Takilara is offline
Takilara's Avatar
Joined May 2008
Hi Takilara,
HaPe
Ah, you mean the AndroPod...
I have never tested this, and it seems very "clunky". However it achieves wired connection without root.
Alot of people, including FrSky themselves have expressed concerns to me regarding using Bluetooth as that runs on similar frequency as the telemetry itself. I have been in constant communication with FrSky while developing my app.
I have never experienced problems with the link, and i have flown alot while using my app.
The AndroPod could provide an alternative to those that are sceptical of using Bluetooth for this purpose.
Old Jun 19, 2012, 12:45 PM
HaPe is offline
Germany, NRW, Bonn
Joined Jul 2010
Hi Takilara,
I can understand the concern about Bt impact to the 2,4 GHz systems. But if that is a risk for the FrSky system – what is about WLAN, switched ON at the mobile phones. The RF power is much higher then the Bt signal !
I guess the radio system designers are asked to take care for impact protection.
HaPe
Old Jun 20, 2012, 06:38 AM
Takilara is offline
Takilara's Avatar
Joined May 2008
I tested out your app today, and realized that it is not only similar, but that alot of the source originates from my open source app. That is fine. But I was wondering if I you could please attribute where you got the source from? Both in the posts here and on your web page.
The nature of open source is of course that others can use the source and make it better. But it is normal good practice to also refer to the originating project or source when used.
It would be even better if you would decide to contribute to the existing open source project, so that everyone can benefit from the collective work.
Regards
Espen
http://projects.onomato.biz/projects/android-dash
Cool Android Phone App - Center of Gravity Calculator pardus Modeling Science 13 Apr 09, 2015 11:42 AM
New Product Android Phone App - RCEcalc - Electric Flight Calculator pardus Electric Plane Talk 0 Jan 14, 2011 02:43 AM
Cool Android Phone App - Center of Gravity Calculator pardus The Builders Workshop 6 Oct 18, 2010 02:02 PM
Cool Android Phone App - Center of Gravity Calculator pardus Electric Plane Talk 1 Oct 16, 2010 06:07 AM
