| Thread Tools |
| This thread is privately moderated by michaelghammer, who may elect to delete unwanted replies. |
DIY CNC Foam Cutter version 1
Hi All
After the succes with my CNC Router build I started thinking about building a 4 axis CNC Foam Cutter. The CNC Router originally started as a low budget build with small second hand stepper motors, threaded rods and rods from old printers. But I ended up buying big Nema 23 steppers, ballscrews, linear bearings and Gecko 540 stepper driver etc. I donīt regret spending a lot of money on the CNC Router. It works great and will last for the rest of my life. BUT the idea of making a CNC machine with free second hand parts was still there. So I decided to build a quick and dirty Proff of Concept CNC Foam Cutter " without spending a single $ (well "kroner" in my case, as I live in Denmark). Parts list: 4 Nema 23 steppers salvaged from old thermo label printers. 8 drawer slides. Surplus from server racks 2 8mm threaded rods + nuts 2 6mm threaded rods + nuts Flexible fuel line as connectors Wood. Planks and plywood I had lying around. Screws for wood The whole thing came together rather quickly as the photos reveal. I opted to mount the vertical axis stepper motor at the bottom of the axis in order to avoid having too much weight at the top of the tower and risking toppling over. The wire was mounted in a bow and rested in a groove as shown in the photo. In spite of the crude design I was pleasantly surprised by how well the machine performed and the precision of the cuts. Of course the threaded rods with the ends flapping freely didnīt make things move fast - on the contrary But a Foam Cutter should only use cut feeds of 100 - 200mm/min. So all in all the machine cost me nothing and cuts with sufficient precision.More to follow on my version 2 of the CNC Foam Cutter - Michael Hammer |
| Thread Tools | |
| Help! Cnc foam cutter 4 axis plans | srkipa | Foamies (Scratchbuilt) | 1 | Apr 04, 2012 03:41 PM |
| Question Drivers and Steppers for CNC Hot wire foam cutter | sscherin | CAD/CAM | 1 | Feb 27, 2012 03:08 PM |
| Build Log diy CNC foam cutter. | nemoskull | DIY Electronics | 0 | Nov 09, 2011 05:02 PM |
| Wanted DIY 4 Axis CNC foam cutter wanted | mt92 | Non R/C Items (FS/W) | 0 | Jun 05, 2011 08:23 AM |
| Question DIY-CNC Foam Cutter | N2EC | The Builders Workshop | 1 | Nov 02, 2004 05:32 AM |
