Dusted off my little A-4, I had parked it after the aileron trim kept changing inflight. Other jets had my interest so it never got looked into. So it's been 2 years, time to fix it!
Pulled the intake duct and fan out tonite. Good thing I parked it!
The aileron servo had unglued itself and was flopping around, the fan stator assy had broken free and slid forward with the rotor protruding into the duct, the outer fan mounting ring also broken free and the main bulkhead was broken in half.
Guess thats the price you have to pay for having 900watts in an alfa A-4!
Epoxied the servo down and CA'd the fan back together adding epoxy around the stators and outer mounting ring. Bulkhead also CA'd plus epoxy to reinforce the cracked area and some extra on the fuse/ bulkhead joints as well. Reassembled, need to get a 2.4 rx for it or I'll have to use my old optic6.
Mods: cutdown het rotor in the alfa shroud stator/motor assy moved back so rotor runs in the shroud. Mega 16/15/2 4600kv CC60A ESC on 4S2200s.
Smaller exhaust duct exit 57mm.
Foam shims added inside the inlets to shrink the too large intakes for higher top speed, Seemed faster but then the aileron issue started so I parked it.
I'm adding some red paint on the wings/tail to see it better inflight, the navy paint is tough to see and the jet is tiny and seriously fast. Maybe Herb can get a speed read on it saturday. I'm hoping somewhere around 145mph.
