Old Jun 05, 2012, 08:10 PM
eyeinsky1 is offline
Find More Posts by eyeinsky1
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro
Any one try this yet?
Eagle Micro Aeroplane Flight Controller A3
A3 is a flight control board designed specifically for fixed-wing airplane,which supports 3 model types including Normal Airplane, Flying Wing and V-Tail. With a high-precision MEMS digital three-axis gyro built in, it provides sound stability, flexibility and reliability by automatically correcting for channels of aileron, A3 has a 3-bit jumper for model type selection. Please match the type with your plane from among Normal Airplane, Flying elevator and rudder. Small size and light weight make it more adaptable for small airplane. ( In our test, it can significantly improve the control on small 3D airplane with wingspan under 50cm).
Features:
- Designed for 3 model types: Normal Airplane, Flying Wing and V-Tail, can be easily switched by the on-board jumper;
- Specifically optimized to work for 3D flight without undermining stability;
- Independent gyro gain adjustment for Aileron, Elevator and Rudder;
- Basic setting functions including stick centering and gyro reversing;
- Smaller and lighter, more adaptable for small airplane.
Specifications:
- Voltage Range: 4 - 6V DC
- PWM Output: 50Hz, 1020 ~ 2020us
- Full-Scale Range of Gyro: ฑ1000dps
- Sample Rate of Gyro: 1KHz
- Operating Temperature: -40 โ„ƒ to 85 โ„ƒ
- Dimensions: 30ื40mm
- Weight: 8 g
eyeinsky1 is offline Find More Posts by eyeinsky1
Old Jun 05, 2012, 08:23 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
JCX-M6 Flight Controller for RC Airplane RC Model Plane FPV Fixed-wing Airplane
Description:
JCX-M6 is a flight controller especially designed for fixed-wing airplanes. It can perform calculation for flying wings, elevators, and rudders and output compensation rudder volume for channels in real time to facilitate stability of airplanes during flight. JCX-M6 features special flight assistance function which can help control flight modes. Inverted flight, slanting flight, and hanging flight are available without compromise. Under a fourth or fifth wind force, airplane KT330 can still have inverted flight, slanting flight, and hanging flight. With proper power and driving force, wind is not a problem now. fixed wings, flying wings (triangular wings), and V-tails (aero-engine airplanes, CESSNA, and 3D devices) are supported.
Functions:
1.Stable flight: In enhanced-stability mode, the gyroscope automatically adjusts to compensate for fixed wings, elevators,and rudders. This enhances wind-resistance capability and reduces speed failure to allow for stable flight. 3D flights such as inverted flight, slanting flight, and hanging flight become easy and do not compromise the controllability of airplanes. Flight
become so easy for us.
2.Stunt flight assistance: Stunt flight modes, besides facilitating stability of flight, feature the flight locked function by high-precision digital gyro automatically locking the channels of Aileron, Elevator, and Rudder. This function makes inverted flight, slanting flight, hanging flight, and even 360-degree rotation available without compromise which indicates a more accurate flight control with flexibility at the same time. Take off and landing become quite easy, if without considering center of gravity had adjust, the difficult flight's plane also will be easy to control. More information will be demonstrated in the 8th item of Notice for the first use.
3.Independent gyro gain adjustment potentiometer and the algorithm of software gyro gain make the gyro into its best automatically.
4.4-digit DIP switcher makes the functional settings for board become easy and convenient.
5.Controlling switcher of flight manual is used through the channel of on-and-oไปŸ on the remote control to controlthe start function. When at high altitudes, flight manual control is able to be achieved by this switch so that you can feel the flight tunctions of plane whether it is controlled or not, practice flight control in none-flight manual mode, and improve your skills easily.
6.Red and blue LED lights make it easier to tell the work mode and the opposite.
7.Its small size of 30x42mm, the weight of 6g, and perfect configuration make it easily to be installed and used in any size of planes.
8.lt is supportive to various types of fixed-wing, flying-wing,and V-tail.
Technical Specifications:
- Dimension: 30 x 42 mm
- Weight: 6 g
- Voltage: 4-9 V DC
- Current:40 MA(max)
- Sample Rate of Gyro: 2 KHz
- PWM Input: 50Hz PMW
- PMW Output:50Hz PMW
- Operating temperature: -25โ„ƒ to 80โ„ƒ
Old Jun 06, 2012, 07:13 AM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
No, but I have pre-ordered an Eagle Tree Guardian 2D/3D stabilizer, which is supposed to be shipped by the end of this month. The features sound similar.
Tony
t-turley is offline Find More Posts by t-turley
Old Jun 06, 2012, 03:38 PM
eyeinsky1's Avatar
Halifax NS Canada
Joined Apr 2009
Tony
Nice! I been using the KK aeroplane and KK openaero the only issue with the KK Aeroplane is the arming and throttle still has to be connected to board. Openaero is much better no arming required. Another issue with the KK is the dimension of the board, it is a little large hard to fit into some fuselages.
Here's a tread I started on the subject: http://www.rcgroups.com/forums/showthread.php?t=1554249
Jerry
Discussion EAGLE Micro Aeroplane Flight Controller/ Stabilization A3 Heppy Ket Flight Accessories 13 Aug 27, 2012 11:05 AM
Discussion Micro 3-axis Gyro Unit - SubMicro Heli Group Design boredom.is.me Micro Helis 32 Jun 15, 2012 02:47 AM
Discussion Micro 3-axis gyro PCB for Airplane. < Eagle A3 > toirazi hobby Scratchbuilt Indoor and Micro Models 14 Jun 04, 2012 06:53 AM
Discussion KK MultiWii Multicopter Controller Board V5.5 for Y3 3-axis 4-axis Y6 6-axis single-a disneytoy Multirotor Talk 2 Feb 10, 2012 12:21 AM
Discussion MWC MultiWii Lite lightweight version 4-axis flight control board Erknie Multirotor Talk 0 Dec 05, 2011 06:58 PM
