Hobbypartz.com GENS ACE iMARS Charger Back in Stock!!
Pilots! We finally got our latest Gens Ace iMars Charger back in stock! The iMars charger has a sleek and modern design which is perfect to store anywhere! The iMars is touchscreen and is user friendly. Here are some key features:
-12-15V DC power supply:50 Watt output power -Microprocessor control -Easy four bottom program control -Charging and discharging over the 4mm main connectors -Balancing over the balance cable XH -12 data memories -1-16 NiCd/NiMh delta peak adjustable(mv) -1-6 LiPo cells -1-6 LiFe cells -2V-24V Pb batteries -Charge current 200mA-5A (50W limit) -Timeout limit: the charging stop automatically after a preset period of time. -3 different charge modes for LiPo and LiFe batteries: Storage (50%) , Fast charge (1/10C) and Full charge (100%). -Adjustable discharge Cut-off voltage for LiPo , LiFe , Pb , NiCd , NiMh batteries. -All settings visible on the 2 x 16 backlight LCD screen while charging. -Adjustable end of charge voltage for LiPo and LiFe batteries. -LiPo Recovery mode :enables to recover low voltage LiPo and LiFe cell. ![]() ![]()
Exclusively available at www.Hobbypartz.com http://www.hobbypartz.com/98p-imars-charger-6s-50w.html |
Latest blog entry: New Products
$39.00 nice. i got a question does this charger read the IR of the cells i am learning that, that is a important feature
Latest blog entry: on/off switch
still a good looking charger is there any review on it my hobbyking cheapo charger is dieing
Joined Feb 2011
Joined Jun 2012
imars charger
Pros>
The iMars charger from gens ace does in fact measure the IR of batteries. It is a very portable and sleek looking charger. works well with 12v car battery Affordable Cons> It's an ok charger so far but the balance board 2S, 3S and 4S plugs werent soldered onto the board and i had to do it myself,... which was tedious & a stressful operation. I have 3 different 12v AC adapters. the charger doesn't work with the 1.2 amp... lights just flash the .3 and .8 amp adapters work but ya can't really charge anything unless you're willing to wait many hours. It's an ok charger. Have yet to use with a power supply, so it may work great with adequate PS. if you need another charger.... a portable charger... $39 is hard to beat that measures IR. But I wouldnt want this to be the only charger. |
| Thread Tools | |
| Question Gens Ace (Hobbypartz.com) restocking time | Jetnfast | Batteries and Chargers | 26 | Jan 26, 2013 02:02 PM |
| Discussion Gens Ace iMars 50W 1-6S Smart LiPo/LiFe/NiMH/NiCD Battery Charger/Balancer in stock! | Nitro_Gary | Nitro Planes | 0 | Jun 05, 2012 05:14 PM |
| Discussion Gens Ace iMars 50W 1-6S Smart LiPo/LiFe/NiMH/NiCD Battery Charger/Balancer in stock! | Nitro_Gary | HobbyPartz.com | 0 | Jun 05, 2012 03:08 PM |
| Discussion Gens Ace 5K 3s 30C - when will these be back in stock ? | vashon10 | HobbyPartz.com | 2 | Feb 13, 2012 12:12 AM |
| Discussion Gens Ace iMars charger | YamahaBlue | Batteries and Chargers | 1 | Nov 20, 2011 01:44 PM |
