Old Jun 05, 2012, 11:42 AM
bimmerland is offline
Find More Posts by bimmerland
bimmerland's Avatar
United States, NC, Cary
Joined Nov 2011
Got my first Dynam 10 - need some advice please
This is my first foray into EDF flying and I picked the Dynam A10 because of all the excellent reviews and how sturdy it is.
I decided the eliminate the landing gear and replaced it with skids.
I followed all recommendations regarding scraping away the paint before applying 15 minute expoxy to the vertical tail surfaces and the ducted fan assembly. Also put a dab of CA to make sure the servos will stay in place as well as using loctite on the control horn adjustment screws
Applied decals and added a AR600 receiver so now I am ready to take to the air but still have some questions regarding the strenghting of certain parts of the fuselage to make it a little more durable.
GC for is set for 72.5 from leading edge and it balances very well.
Where should I insert any straightening rods to reinforcenthe wing and tail. Any other tips greatly appreciated including any other places for reinforcement. Should I cut a hole in the fusey for more air or just run by 2200 30 pacs.
Should I cut holes in the fusey for better airflow around the esc's
Should I use recommended aileron and rudder throws. Can I come in slow or hot.
Lots of questions... sorry... just want to make it right the first time. Thanks again.
I want this first flight to be memorable and enjoyable. Please let me know if I have missed anything. Thanks.... New A10 newbee.
PS. How long should I expect a flight to last flying normal speeds at running a 2200mah 30c pack
bimmerland is offline Find More Posts by bimmerland
Old Jun 05, 2012, 12:31 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You should repost this in the foamy forum. That's where you will find the action is on your new bird. The have a large thread going on this one already.
http://www.rcgroups.com/foamy-edfs-377/
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 05, 2012, 05:15 PM
bimmerland's Avatar
Joined Nov 2011
Thanks... Tried there once...no response... will try again...
Question Need advice on purchasing my first quad please. Papa Raboon Multirotor Talk 4 Oct 26, 2012 07:06 PM
Discussion Looking for some advice on my first micro-ish build Piece Scratchbuilt Indoor and Micro Models 12 Jun 24, 2012 11:34 PM
Discussion Closed bimmerland Foamy EDFs 0 Jun 04, 2012 11:54 PM
Discussion Need some advice regarding the Dynam T-28! Please Help! aviator4934 Beginner Training Area (Aircraft-Electric) 4 Jan 20, 2012 11:07 AM
Build Log First Quad-X build: Need some advice PyroPanda Multirotor Talk 3 Dec 02, 2011 04:57 PM
