Old Jun 05, 2012, 10:47 AM
Gemini2 is offline
Find More Posts by Gemini2
Gemini2's Avatar
United States, NJ
Joined Aug 2011
Watt Meter - Which Plugs For Motor Test Bed??
I need to set up a Motor test bed to sort out some props for several different motors.
The Watts Up watt meter comes with bare leads & needs to be inserted between batteries & ESC's that have a variety of plug systems, including
Mini-JST, JST, EC3 & XT60.
I am wondering what people who have faced this one before do as regards putting connector plugs on the watt meter?
Do you put 'something' in the way of a plug on to the watt meter wire then look for adapters to be able to connect to the various Battery & ESC plugs?
If so, what 'something' do you go with?
Thank you
G2
Gemini2 is offline Find More Posts by Gemini2
Old Jun 05, 2012, 11:10 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
I put the largest one on the Watt's Up (Dean's Ultras for me at the time) and then made short adapters from the Deans to the other smaller connectors.
I later used some PowerPole connectors and made Dean's to APP adapters but the APPs would have been first choice had I known I would be using them. The APPs don't handle a lot more current than the Dean's Ultra but are much easier to work with.
I also made up some short male to male and female to female to gender changers too so that I could use the meter between a charger and a battery where the battery becomes the load instead of the source.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jun 06, 2012, 07:41 AM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Like Jack, I've always put my "standard" connectors (XT60 these days) on Wattmeters and loggers then made up various type and gender changing adapters but what HobbyKing have done on their latest 7in1 meter struck me as clever.
They put all female large bullets (6mm from memory) in the meter both In and Out and supplied short leads with bare tinned ends to fit your connector of choice.
That way the meter connection is very low resistance and current capable and you only need one pair of leads for every connector you have since you can swap the leads over to change from charge to discharge testing.
Neat.
Jack
jj604 is offline Find More Posts by jj604
For Sale Aviomodelli Watt 200 2-meter motor glider, ARF, NEW barchiola Aircraft - Electric - Airplanes (FS/W) 1 Dec 07, 2011 05:29 PM
Discussion Watts up guys? Watt Watt meter do you recommend? ZSimon Batteries and Chargers 17 Nov 11, 2011 05:04 PM
Discussion Deans plug, watt meter, what does it plug into? Xym Power Systems 8 Apr 23, 2011 11:55 PM
Discussion Battery Test Watt-Meter and results ... solentlife Batteries and Chargers 11 Aug 26, 2010 07:46 AM
Astro Super Watt Meter Or Sirius Super Test slabs Power Systems 5 Dec 18, 2001 06:40 AM
