This thread is privately moderated by leccyflyer, who may elect to delete unwanted replies.
Old Jun 04, 2012, 04:22 PM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
BC050 - SWM Webbit
#BC050- SWM Webbit
Aircraft Name: Webbit
Manufacturer/Designer: Steve Webb Models -Peter Kent
Type: Electric sports
Construction: Built up balsa-liteply: Built-up balsa fuselage and wing sheet balsa wing and tail
First Flight: Warrington Model Club, 4/6/12
Wing Span: 40"
AUW:40 oz.
Power type -Electric
Motor: Mystery brushless outrunner
ESC: Hobbywing Pentium 30amp
Battery: 3s1p 2300mah Tipple lipos
Propeller: 7x4" APC-E
Receiver:Spectrum AR500
Flight Pack: BEC
Servos: Aileron (torque rods) -Futaba s148, Elevator (pushrod) - HS85MG, Rudder (pushrod) HS81
Throws -
Undercarriage - Dural
Accessories: none
Covering: Orange and yellow Solarfilm.
Current status: In service -maiden flights dodgy-check wing incidence and thrustline.
Two flights today - CofG just behind mainspar. Checked current draw with fitted 9x5 prop - over 30amps, so propped down to 7x4 apc-e for 28 amps. Took off, nose came up, and kept coming up - settled into a very dodgy half circuit very twitchy and node high. Down in one piece. Replaced 2300mah 3s1p pack with 3000mah 3s1p and a chunk of lead. Balanced on mainspar. Took off, nose came up, and kept on coming up. Landed in outfield, no damage save a broken prop.
leccyflyer is offline Find More Posts by leccyflyer
Old Jun 04, 2012, 11:26 PM
Whiskers is offline
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
In the pic it has a bit of 'up' on the elevator.
Is that the way it was when you were trying to fly it? If so, there's your answer.
Whiskers is offline Find More Posts by Whiskers
Old Jun 05, 2012, 01:32 AM
Sloping off....
leccyflyer's Avatar
Joined Sep 2000
That's just how she was sat on the ground for getting her picture taken. All the controls were fully checked out in the pre-flight and there wasn't any up trim. Thanks for the observation though.
Idea The 'WebBit TWIST' fixed wing convertible 3 in 1 model SafeLandings Auto Gyros 76 Jun 28, 2011 11:04 AM
MAF Webbit e-conversion leccyflyer Sport Planes 16 Apr 26, 2010 02:53 PM
