United States, CA, South San Francisco
Joined Jun 2012
Thunder AC6 vs Thunder AC680 Chargers.
So i've been looking at these two chargers.
Thunder AC6 http://www.hobbypartz.com/thac6smbachw.html Specification Operating voltage: DC 11~18 volts Charge/discharge power: max. 50/5 Watts NiCd/MH: 1~15 cells LiIo/LiPo/LiFe: 1~6 series Pb: 2~20V Charge current: 0.1 to 2.2A Discharge current: 0.1 to 1.0A No. of cycle: 1 to 5 times Battery data memory: up to 5 data Weight: 260g Dimension: 140*95*28mm Computer USB port Temperature sensor port Built in AC adapter But for this, they say it charges up to 5 amps. but it specifies 2.2 Thunder AC680 http://www.hobbypartz.com/73p-ac680-accharger.html Specs Operating voltage: DC 11~18 volts AC in: 100v-240v 50/60Hz Charge/discharge power: Max. 80/10 Watts NiCd/MH: 1~15 cells LiIo/LiPo/LiFe: 1~6 series Pb: 2~20V Charge current: 0.1 to 6.0A Discharge current: 0.1 to 2.0A No. Of cycle: 1 to 5 times Battery data memory: Up to 5 data which one would you recommend purchasing? Or anything you guys suggest? Im not sure about Turnigy, but i heard its crap. |
I can guarantee you the AC6 does, in fact, charge up to 5A rate. I owned one. Of course, it's only a 50W charger, so it's not going to charge 6s packs at 5A. In fact, it'll only charge 2s packs at 5A. Even 3s packs can only be charged at ~4.0-4.5A.
Both are decent, although limited charges. If you do not need AC input, I'd recommend something with more power as you will most certainly grow into it. 200W and a 10A charge rate really come in handy for either 6s packs and/or parallel charging multiple lower voltage packs. HK has the EC06-10 for a great price, but it's backordered. If you don't mind spending a bit more for quality, however, its hard to beat an iCharger. |
Joined Jun 2012
Pretty much any charger will do multiple batteries simultaneously, either in parallel or in series, with the correct adaptors. Neither of the AC chargers are power houses, but you can do parallel or series charging with both. The difference between the AC6 and the AC680, as I understand, is 30W total power and a 6A vs. 5A charge rate. The AC680 will charge 4s packs at around 4.5-5.5A, so you could get a series adapter and charge two of your same capacity packs together as 4s. You would not want to charge a 5800mAh and a 5000mAh pack together is series, but you could do them in parallel.
I'm not familiar with other brands that accept AC input, so I can't help you there. Most chargers out there are DC only. |
| Thread Tools | |
| Wanted Thunder AC6 or AC680 | Reeefo | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Jun 04, 2012 02:58 AM |
| Discussion Who is using the Thunder AC680 Dual power charger? | southmaui | Batteries and Chargers | 7 | Jan 10, 2012 01:52 AM |
| Discussion Thunder AC680 Charger error | Da88th | Batteries and Chargers | 5 | Jun 23, 2011 08:27 PM |
| Discussion Sky Charger B6AC vs. Thunder AC6 | thayesii | Batteries and Chargers | 4 | Mar 12, 2010 06:57 AM |
| Discussion Imax B6AC + vs Thunder Power AC6 vs. E-Station 6 vs. Bantam BC6 vs. others. | Tedstrickland | Batteries and Chargers | 0 | Nov 23, 2009 03:03 PM |
