Old Jun 04, 2012, 04:07 PM
VIDEOPRO is offline
Find More Posts by VIDEOPRO
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Build Log
F-22 single 70mm edf build w/plans coming
This will be my attempt to build this F-22 from plans that I am drawing up from the 3 views I have. I also used a contour gauge on a plastic kit to help me with some of the curve lines on the top and bottom.
My plans are not complete and I will be updating them as move along throughout the build. Some of the parts may change as well. Build at your own risk as parts are not complete or tested yet.
The building material will be the Dollar Tree foamboard sheet sizes 20 x 30 with a thickness of 3/8" (5mm). So, I will be laminating sheets together for the build. I will be using Gorilla Glue for most of the build. Epoxy in specific areas and Spray 77 for the laminating process.
Specs:
34" Wing span
Change Sun 10 blade fan unit
Cyclone 3300kv Outrunner witn 4mm shaft
Cyclone 85 amp esc (may need to use 110amp esc)
Turnigy Nano Tech 4s 4000 mah 45c - 90c battery
Plan to use tailerons along with ailerons and have flaperons mixed if possble.
Will not have thrust vectoring or gear on this model. I plan to belly land this and hand toss.
I will also be using the canopy and decals from the Banana Hobby 70mm F-22 that has a wing span of 33.5" My canopy making skills are not up to par so I will cheat on this one.
VIDEOPRO is offline Find More Posts by VIDEOPRO
Old Jun 04, 2012, 08:41 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Hi Doug, sounds like a great project and looks linke you've got a good start on it too! Good luck to you, I'll be watching! w.
Waltjg is offline Find More Posts by Waltjg
Old Jun 05, 2012, 12:19 PM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
cool! I'll be watching
I had a question though:
the $tree readyboard I just depapered measures 5mm's thick, its my first time using readyboard, does it come in different thickness'?
I like it though, sands a little smoother than the RCFoam depron I've been using, seems liter, definitely a little more noodely (not quite as stiff), but for a buck a sheet I can get used to it.
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Jun 05, 2012, 12:42 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
I'm not sure about the readyboard, I use FFF for all my builds, inexpensive, and extremely workable, not quite as stiff as depron, but it has it's advantages too... Great to see ya here too Joe! w.
Old Jun 05, 2012, 02:05 PM
VIDEOPRO is offline
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Joe
Joe your right! Just looked at mine and it is 5mm thick after peeling paper off. It is a little noodely but it is easier to sand. I also think it is easier to use for curved sections etc. Well anyway I was drawing my plans using the inch scale so it was 3/8" that I was thinking and not 3mm. I will make that fix on the next release (update) plans. Will post pictures throughout my build along with directions as to what I am doing.
Thanks for watching!
Old Jun 05, 2012, 03:51 PM
sloperjoe's Avatar
Joined Mar 2012
after I saw your post I ran out and re-measured my sheets to make sure....I would have had to revise my plans..
better you than me
Joe
Old Jun 12, 2012, 06:58 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Anymore progress?? W.
Old Jun 14, 2012, 03:50 PM
VIDEOPRO is offline
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Sorry Guys! No progress. If I continue this it will be slow going. A friend of mine decided to give me his second 70mm F-22 from Banana Hobbies. He had two of them and did not have the room for it so he gave it to me. What a sweet looking F-22 although not scale looking in certian areas but it sure flys nice and I am not complaining. I think he gave it to me to see how (mine now) will fly with the Cyclone 3300 kv motor and the Change Sun 10 bladed fan before he makes the changes to his airframe.
I will be building the twin 90mm version and hopefully get to that build late summer.
Old Jan 05, 2013, 09:47 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Not is a good motor for CHS-10.
Very hight Kv.
manuel v is offline Find More Posts by manuel v
Old Jan 05, 2013, 10:12 PM
VIDEOPRO is offline
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Very hight Kv.
What are you talking about! Very good combination and about the maximum kv you can use on the CS10 blade fan. Have been using it in my BH F-22 for the past 4 months with great results. That is why I did not build this home made model in this thread. Hand launches with ease. Will almost fly right out of my hands on its own without a toss. The Change Sun 10 blades have been holding up just fine. Just need to make sure they are balanced.
Old Jan 06, 2013, 08:34 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
3300 on 4s shouldn't be to bad. 2700-2850 is the sweet spot for them.
I would check the enamel color from time to time on the motor just to play it safe.
D_FAST is offline Find More Posts by D_FAST
Old Jan 13, 2013, 01:01 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
So, you're right.
Already check the numbers and the motor only works around 1290 watts which is 8.9 watts per gram of weight.
Where unable to work is with 5slipo.
For Sale AirField RC 70MM F-4E EDF RC Jet w/ Brushless Motor+ESC (Blue Angel) -[LPU] xlrDALLAS Aircraft - Electric - Jets (FS/W) 2 Apr 03, 2012 06:36 AM
Sold Hobbyking Fiberglass F-22 Twin 70mm edf $150 NIB sherlockshah Aircraft - Electric - Jets (FS/W) 3 Mar 31, 2012 08:54 AM
For Sale AirField RC 70MM F-4E EDF RC Jet w/ Brushless Motor+ESC (Blue Angel) -[LPU] xlrDALLAS Aircraft - Electric - Jets (FS/W) 1 Mar 25, 2012 06:35 PM
Sold Scale 70mm F-22 EDF Jet - Includes 4S battery Roswalt Aircraft - Electric - Jets (FS/W) 31 Feb 20, 2012 11:00 AM
