Old Jun 04, 2012, 11:05 AM
warbirdboy is offline
Find More Posts by warbirdboy
Spring
Joined Sep 2008
Help!
E flite park 300 Brushless Outrunner motor Help!
Hey guys, i just built a flying wing and i picked up this motor at a LHS. I was looking at this motor and was confused by the construction of it and how to mount it. With the lack of mounting instructions for the motor itself and for the prop, i had to resort to my fellow RCgroups members to help me out here
Just in case you haven't seen this little motor before, it looks like this:
I'm mounting this motor on a firewall-type mount on the back of the delta wing for a pusher motor. The problem is, though, is the screw holes are on the side with the rotating shaft. how am i supposed to mount this thing? do i drill a hole through the firewall for the shaft and use the propsaver side? how would i mount a prop on the propsaver side?
warbirdboy is offline Find More Posts by warbirdboy
Old Jun 04, 2012, 03:39 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You can mount an L-bracket on the tail of your pusher wing, with the motor attached 'within' it by using the four standard threaded holes... then the shaft with stick out the back, and you can use a collet prop adapter.
http://justgofly.com/Order%20Form.htm#Mounts
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jun 04, 2012, 05:37 PM
Spring
Joined Sep 2008
My motor mount on the plane already looks like this. This is how i built it, look at 6:02 in this video:
Flite Test - F-22 Raptor - SCRATCH BUILD (9 min 49 sec)
Do you think i can remove the piece of plywood i glued and place the motor mount (pictured above in the first post) behind it, drill a hole for the rotating shaft to spin randomly in, and screw it in through the back using the prop-saver side for the prop?
Old Jun 05, 2012, 02:52 AM
Entropy76 is offline
Find More Posts by Entropy76
The Last Question
Entropy76's Avatar
United States, UT, West Valley City
Joined Oct 2006
Or if you have a vice and a socket wrench to support the bell just slowly close the vice and push the shaft in until its reversed. Then you could just use the collet adapter and use the mount like normal. Of course this would be safest if you have a c-clip in the groove at the end so the bell can't go anywhere put then again it is in a pusher config so no real danger.
Entropy76 is offline Find More Posts by Entropy76
Old Jun 05, 2012, 10:32 AM
Spring
Joined Sep 2008
I read somewhere that you can't reverse this one because of the pusher prop configuration on the back. That is a pusher prop thing on the back, right?
Sold (2X) Two E-Flite Park 300 Brushless Outrunner Motor (1380kV) sergek Aircraft - Electric - Power Systems (FS/W) 0 Mar 05, 2012 04:10 PM
Sold Two E-Flite Park 300 Brushless Outrunner Motor (1380kV) - EFLM1150 sergek Aircraft - Electric - Power Systems (FS/W) 0 Feb 20, 2012 11:31 PM
For Sale NIB E-Flite Park 300 Brushless Outrunner Motor, 1380Kv roberted5 Aircraft - Electric - Power Systems (FS/W) 0 Feb 10, 2012 04:18 PM
Wanted looking for E-flite EFLM1130 Park 250 Brushless Outrunner Motor 2200Kv cwolfe Aircraft - Electric - Power Systems (FS/W) 1 Nov 14, 2011 02:03 AM
Sold NIB E-flite Park 300 Brushless Outrunner Motor, 1380Kv JohnM Aircraft - Electric - Power Systems (FS/W) 2 Oct 22, 2011 10:30 AM
