Old Jun 04, 2012, 11:43 AM
qwerty11 is offline
Find More Posts by qwerty11
Joined Dec 2009
About to put ailerons on my radian. What do I need? (Servos, etc)
Like the title says I'm about to put ailerons on. Could you guys please help me with the parts lists as for as servos, wires, horns, rods, etc. This is foreign territory for me.
qwerty11 is offline Find More Posts by qwerty11
Old Jun 04, 2012, 11:53 AM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
i just put ailerons on my cub last week. i used: servos, pushrods, horns, y-harness, wires, exacto knife (#11 blade), tape (which i also used as hinge), ruler, wire cutters, pliers. take your time with measuring and cutting.
cmdl is online now Find More Posts by cmdl
Old Jun 04, 2012, 01:08 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Will the rcvr allow you to add another servo? You may not have an open channel. If not, you will also need a new rcvr.
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Jun 04, 2012, 04:37 PM
qwerty11 is offline
Joined Dec 2009
Ive got an orange six channel with aux. Which servos, pushrods, horns, and y harness do you recommend?
Old Jun 05, 2012, 02:36 AM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
Why? the plane is designed for rudder only. Its especially designed to thermal really well which the rudder and wing shape helps it to do. With that dihedral built into the shape of the wings it is not going to like ailerons. And you simply end up making it heavier which makes it less able to thermal in light conditions which it is superb at.
Threshold is offline Find More Posts by Threshold
Old Jun 05, 2012, 06:26 AM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
Ditto to Threshold. This plane flies amazingly the way it was designed. It won't fly any better with ailerons and you'll be adding weight.
Why do you want to add ailerons to a plane that already can do rolling circles without them?
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Jun 05, 2012, 08:11 AM
ArneHu is offline
Find More Posts by ArneHu
Balsa Builder. With some foam.
ArneHu's Avatar
Eastern Norway Scandinavia
Joined Dec 2009
If the Radian had straight wings, ailerons will be useful. But with the bend wings, it don't need ailerons. But if you want you can make air brakes. Take a look at the big Radian thread in Electric Gliders Topic.
ArneHu is offline Find More Posts by ArneHu
Old Jun 05, 2012, 08:36 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
The Radian pro has the same design but with ailerons. The wing airfoil and dihedral can handle ailerons.
Radian Pro
EDIT:
I take that back, but I'm leaving my original statement.
The radian does have way more flex in it's design. I wouldn't do an aileron mod on it.
Ask Radian owners if the Pro wing will mate with the Radian. If so buy a Radian Pro replacement wing and mount it on your plane.
dedStik is offline Find More Posts by dedStik
Old Jun 05, 2012, 10:25 AM
Ed Couch is online now
Find More Posts by Ed Couch
Ed Couch's Avatar
North Richland Hills, Texas USA
Joined Aug 2000
For what its worth don't. I fly both quite a lot and the Radion is a much better thermal ship than the Radion Pro. On several occasions I have had the ailerons lock up while in a nose down attitude due to wing flex. Once causing me to roll into the ground. Cost me a new fuselage. I went back and did the same thing at altitude and danged if it did not do it again. Pulled throttle and brought the nose up and all was well. Got to looking and the flaps and ailerons would touch under g load. Other than the lighter motor on the Radion which is still plenty good for normal flight I prefer that over my Pro. On the Radion Pro I do like the flaps and I use a Go Pro camera mounted under one wing and the ailerons allow me to easily adjust the trim due to the camera mounted off the center line. It is your choice but I've been at this game for over 50 years and been there and done it many times. Follow the "KISS" principle and all will work out. KISS = Keep it simple stupid. ed
Ed Couch is online now Find More Posts by Ed Couch
Old Jun 05, 2012, 11:19 AM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
Radian Pro
EDIT:
The Radian Pro has a very different wing. It is a poor flyer in my opinion while the Radian is quite easy to fly. Mountiong it to the plane isn't easy either. The Pro wings attach with screws while the radian wings are held in place by friction. That's another reason not to put ailerons on it.
fmw is offline Find More Posts by fmw
Old Jun 05, 2012, 11:24 AM
dedStik is offline
dedStik's Avatar
Joined Feb 2012
Yeah I saw that looking closely at the pics about the wing shape, that's why I edited the post. I figured I'd leave it in case anyone else was thinking the same thing.
Discussion what do you think about my power system essadiq Electric Plane Talk 2 Jun 03, 2012 03:34 PM
Discussion If you had an extra Fox .45, servos, receiver, etc., what would you put them in? NeveSSL Fuel Plane Talk 8 Apr 18, 2012 10:18 PM
Discussion What do I buy to put these props on this motor? brianshell Multirotor Talk 8 Jan 31, 2012 08:54 PM
Discussion Question about motors, why do they put resistors on them? NorCalMatCat Beginner Training Area (Heli-Electric) 7 Oct 31, 2011 10:26 PM
What do I need to put a gearbox on my sky scooter?? e-flyer Parkflyers 6 May 25, 2001 01:45 AM
