Old Jun 04, 2012, 09:24 AM
man1024 is offline
Find More Posts by man1024
man1024's Avatar
Joined Oct 2011
Help!
What could be a problem?
Just replaced all motors on my quad from no name 1000KV, to NTM 28-26 1200KV (5mm hub). quad flies shaky on stiff 10x4.5 props, however REALLY smooth on cheap flexy 8x4.5 (5mm hub). tried different 10x4.5 or 10x6 HK props, all balanced well, and works well on prior motors. What do you think the problem?
Im using MultiWii board (with 2.0).
man1024 is offline Find More Posts by man1024
Old Jun 04, 2012, 10:20 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
try balancing your motors... one might have a bell that is WAY off
MCrites is offline Find More Posts by MCrites
Old Jun 06, 2012, 08:34 AM
man1024 is offline
man1024's Avatar
Joined Oct 2011
ok. I will try. Thanks.
I tried to FPV with 8'' last evening, with NO GOOD results, it's really hard to controll my quad (I'm carrynig SONY HD handycam camera, with around 380g). I have to tune my quad for 10 inch props. rrrrrrrr.......
Old Jun 06, 2012, 08:56 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
1200kv motors with 10" props is not a great match in my view, too high kv for larger props. 8" is probably the max on those motors. Not really sure why so many people use those motors beyond Juz uses them but he flies very agressively on a fairly light FPV setup with 8" props I believe.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jun 06, 2012, 09:03 AM
man1024 is offline
man1024's Avatar
Joined Oct 2011
Juz also used 10'' props and has no problem.
Old Jun 06, 2012, 09:08 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Ok thought he was mainly using 8". Still seems too high a kv to me however.
Could just be a prop or motor balance issue then you are noticing on the larger props.
One thing you cna mayeb try is the following in the Multiwii config.h and then reload your firmware:
#define ITG3200_LPF_42HZ
You can try a higher value first as well and see if it helps get rid of any oscillations.
Site Sponsor
Old Jun 06, 2012, 09:45 AM
man1024 is offline
man1024's Avatar
Joined Oct 2011
Thanks. I'm going to do all these things tonight.
Balance motors
Check/rebalance 10'' props
add anti-vibration pad between motor and frame (I used them with my old motors)
test
if still some issues, will #define ITG3200_LPF_42HZ
Discussion Rotor could be a bit of a problem! cliffhanger Slope 15 Jun 03, 2012 01:48 AM
Video What could be the problem with my T-rex? BowerR64 Electric Heli Talk 7 Apr 27, 2008 08:38 PM
Discussion 2 batteries toast...what could be the problem? jeepson33s@yahoo Mini Helis 13 Feb 25, 2008 12:18 PM
What could my Dandy problem be? DsWright Parkflyers 17 Dec 21, 2004 01:42 PM
What could be the problem here - motor cutout after takeoff nose_first Beginner Training Area (Aircraft-Electric) 10 Aug 28, 2003 02:18 PM
